    Tridem's WIP with SU and Kerkythea
    31 Posts 9 Posters 4.5k Views 9 Watching
    • tridemT Offline
      tridem
      PS. For this last one I'd like getting some 'style' comments. I mean, I easily see myself the technical issues and possible improvements, but about the composition of the scene, color tones, point of view etc. better I need other people's impressions πŸ˜‰
        Swindel
        Although i am a complete render-noob, the thing that jumps to my eye is that in photo 1, the couch that is facing us, has 2 pillows that have the exact same shadow. This is maybe supposed to be, but it looks funny.
        • tridemT Offline
          tridem
          @swindel said:
          2 pillows that have the exact same shadow..
          😒 ..it means there was nothing more noticeable to comment
          well, I assume the rest is perfect πŸ˜†
            Swindel
            On the left window/door, the middle piece of wood has dark edges and a little lighter wood in the middle. (weirdly worded). This imo, looks very realistic!
            For the ceiling you could also model a mechanism wich closes. Because if it is dark outside that room will be rather dark aswell.
              Roger
              I would light the little light on the left just so the entire composition doesn't get lost in shadow on the left and my eye tells me the light shining directly off the water from the sun should put some sparkles on the ceiling.
              http://www.azcreative.com
                Roger
                Sort of like this.How my suggestions might look.
                  steelers05
                  i think you are starting to develope a style, but the graineness/quality of the materials really takes away from making a good assessment on your style
                  • tridemT Offline
                    tridem
                    thanks guys for precious comments
                    @Steelers: I know the sharpness is very bad but a such image takes 10 hours to cook, I'm trying to improve it before spending much more time to render.
                    @Roger: totally agree about the left light, thanks for letting me notice it. Since the sea is a background picture it doesn't produce reflections, I should add them in postpro like the reflection of the girl on the ground... but I'm not so sure those reflections could be so visible into the room...I'll think it over πŸ˜‰
                    • olisheaO Offline
                      olishea
                      how come you are using MLT preset? what's the advantage?
                      like the last image, nice mood. entourage well integrated too.
                      oli
                      • tridemT Offline
                        tridem
                        @olishea said:
                        how come you are using MLT preset? what's the advantage?..
                        as I know, there are no really alternatives for a interior nightime shot. apart MLT gives the best result in terms of realism, biased methods need very high settings to resolve the complexity of lights and reflections. perhaps wait anyhow 10 hours or more, and finally find the picture full of white dots... πŸ˜• no thanks
                          Roger
                          Angle of incidence equals the angle of reflection. The sun is low in the sky so light will reflect off the ocean from way out. When you can see that bright pool of light on the ocean, it means , you the viewer, are in line with the sun's reflection. This is why sailors and pirates used to wear eye patches. They were going blind taking sun sights. My daughter has a pool outside a west facing window and it send sun sparkes dancing all over the living room ceiling. Because the pool is small and close to the house this happens much earlier in the day. If the pool were stretched to the horizon you would see it closer to sunset.
                            D-space
                            MLT being unbiased is physically accurate but better tweaks on lightings are necessary esp for night shots. Probably can halves the noise and the rendering hrs.
                            Biased presets, ie Photon Map..would looks somewhat different compared, but decent rendering time is possible. But tweaking the presets is a tough call for most users IMHO.
                            Also couple of color or curves adjusments PP are needed to make the image look right.
                            Probably can achieve somewhat closer to what QMC GI can produce.
                            Btw..MLT is equivalent to preset #9 for TL πŸ˜‰
                            http://blibestmentalt.no/54981
                            • tridemT Offline
                              tridem
                              So, I've done some adjustements, in the meantime the girl has gone, I'm sorry πŸ˜’
                              raw KT view plus light flares added, I'm gonna work on Gimp.
                              I thought back to the environment reflections, I'll keep just the light coming from the spherical sky, I've seen the scene also from another point of view and I believe it's ok
                                Roger
                                A suggestion
                                The render has become much better although I do miss the girl. The interior, for me, just needs a touch more pop. I have done a little post processing on your latest image to illustrate what I mean. Good work by the way.
                                • tridemT Offline
                                  tridem
                                  Hi Roger, thanks for your suggestions once again. I like your version, there's another point of view I want to render (time permitting...) surely I'll take it into account.
                                  Luca
                                  • tridemT Offline
                                    tridem
                                    here is my last attempt...
                                      Roger
                                      The new view made me notice that the perspective is off. The vanishing point is somewhere in the middle of the water. It should be on or slightly above the horizon.
                                      • tridemT Offline
                                        tridem
                                        😲 not a thing escapes you! You're right, I noticed the sea surface was bended but didn't realize the background was too high πŸ˜†
                                        ...one more lesson to learn tridem...
                                        • tridemT Offline
                                          tridem
                                          this is a scene wich I've been played around for a while, now I'm just fed up with it πŸ‘Š
                                            Mocki010
                                            I think your renders need a lot of improvement. Specialy on the light and the
                                            textures. You should also not ignore the basics of furniture construction. 😞
