    How to install a Ruby Gem for use in SketchUp
    27 Posts 8 Posters 11.3k Views 8 Watching
    • AdamBA Offline
      AdamB
      I've build it on a Mac and works just fine. I had to remove some Rails stuff from the startup but it works pretty nicely too.
      Whaat, you should have in you plugins folder:
      ruby_prof.so
      ruby-prof.rb
      ruby-prof (folder)
      ruby-prof.rb just loads all the ancillary files as normal.
      Can you give the actual error you get.
      • W Offline
        Whaat
        ruby_prof.so
        ruby-prof.rb
        ruby-prof (folder)
        Hi Adam,
        I posted the error above. I'm not sure what you mean.
        And...I put the correct files in the plugins folder as you say. πŸ˜•
        Seems like a Windows issue. I'll have to try it on my Mac yet to see if I can get it to work.
        Thanks.
          Jim
          When I installed yaml, I noticed there may be a case issue - I had to use:
          require 'Yaml' (or require 'YAML') because require 'yaml' did not work; although the library file names were all lower case. (Windows XP SP 3)
          I unfortunately no longer have it installed so I'm going from memory here...
          • tbdT Offline
            tbd
            when in Sketchup, require 'ruby_prof.so' breaks in LoadLibrary function with 'Exception C0000139 Entry Point Not Found' which is weird as it works in normal Ruby
            http://plugins.ro
              todd burch
              Could it be a PATH issue?
              • tbdT Offline
                tbd
                there is only loading the .so file which has dependency only for kernel32.dll, msvcrt and msvcrt-ruby18 - all loaded by SU anyway.
                http://plugins.ro
                • AdamBA Offline
                  AdamB
                  Yep, I see the same thing here. On windows it simply wont load. I've rebuilt it locally too.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    What version is the msvcrt-ruby18.dll...
                    ...that works in normal ruby?
                    ...that does NOT work in the SU folder?
                    (I got a similar error when I tried to get SU to load the 1.9.1 version ruby dll)
                    I'm not here much anymore.
                    • tbdT Offline
                      tbd
                      Dan: thanks, that was the problem. in Sketchup there were msvcrt-ruby18.dll version 1.8.0 and in Ruby was version 1.8.6
                      replacing the dll in Sketchup dir with the one from Ruby dir I was able to load
                      RubyProf.measure_mode = RubyProf;;CPU_TIME
                      RubyProf.start
                        Sketchup.active_model.entities.each {|x| x.class}
                      result = RubyProf.stop
                      File.open "d;/profile.txt", 'w' do |file|
                         RubyProf;;FlatPrinter.new(result).print(file)
                      Thread ID; 32679270
                      Total; 7.168426
                       %self     total     self     wait    child    calls  name
                       48.70      4.38     3.49     0.00     0.89        1  Sketchup;;Entities#each
                       20.50      7.17     1.47     0.00     5.70        1  Global#[No method]
                       12.39      0.89     0.89     0.00     0.00       23  Kernel#class
                       11.84      0.85     0.85     0.00     0.00        1  <Module;;Sketchup>#active_model
                        6.57      0.47     0.47     0.00     0.00        1  Sketchup;;Model#entities
                      http://plugins.ro
                      • W Offline
                        Whaat
                        Awesome! Thanks everyone! I hope I can get it working too...
                          Dan Rathbun
                          replacing the dll in Sketchup dir with the one from Ruby dir I was able to load RubyProf
                          I thought so!
                          I always tell people, IF your using full ruby libraries with Sketchup... to make the msvcrt-ruby18.dll file in the Sketchup program folder/directory, the SAME version as your full ruby version. Otherwise your asking for Errors (such as newer library scripts calling methods that the older interpreter doesn't understand.)
                          I've given this advice several times over at Google Groups SU Developer's forum. Not sure if I have here. I also always say make a Sketchup/_BACKUP folder and drag the older DLL into that folder, before copying the newer 'full' DLL from the ruby/bin folder. (You never know, you may have a future need to test a script, running under the old DLL version.)
                          Glad I could help.
                          @Jim: Maybe this issue needs to be added to the Ruby Tips for Sketchup Sticky Links page?
                            Dan Rathbun
                            Re: Ruby Interpreter DLL: SketchUp vs Standard
                            I downloaded the normal standard v 1.8.0 patch level 10 DLL (msvcrt-ruby18.dll) from:
                            http://www.oldapps.com/Ruby.php?old_ruby=12
                            and compared it against the backup that was installed with Sketchup v7.0 application.
                            Both standard DOS command comp and the Support Tool WinDiff report both DLL files are identical.
                            *(WinDiff is a file comparison utility that is installed with Windows Support Tools. The Support Tools are not installed automatically with Windows. You must manually browse the WIN install CD to the "Support Tools" folder, and run a separate setup.exeto install the tools.)
                              Dan Rathbun
                              The Support Tool filever.exe displays versioning information inside exe and dll files:
                              DOS cmd shell, filever verbose listing, in folder:
                              C:\Program Files\Google\Google SketchUp 7_Backup
                              This is the DLL file distro'd with Sketchup 7.x
                              >filever msvcrt-ruby18.dll /v
                              --a-- W32i   DLL   -         1.8.0.0 shp    811,008 02-19-2009 msvcrt-ruby18.dll
                                      Language        0x0000 (Language Neutral)
                                      CharSet         0x04b0 Unicode
                                      OleSelfRegister Disabled
                                      FileDescription Ruby interpreter
                                      InternalName    msvcrt-ruby18.dll
                                      OriginalFilenam msvcrt-ruby18.dll
                                      ProductVersion  1,8,0,0
                                      FileVersion     1,8,0,0
                                      LegalCopyright  Copyright (C) 1993-2003 Yukihiro Matsumoto
                                      VS_FIXEDFILEINFO;
                                      Signature;      feef04bd
                                      Struc Ver;      00010000
                                      FileVer;        00010008;00000000 (1.8;0.0)
                                      ProdVer;        00010008;00000000 (1.8;0.0)
                                      FlagMask;       0000003f
                                      Flags;          00000000
                                      OS;             00000004 Win32
                                      FileType;       00000002 Dll
                                      SubType;        00000000
                                      FileDate;       00000000;00000000
                              This is the DLL file distro'd with Ruby ver 1.8.0-10
                              >filever v180-10\msvcrt-ruby18.dll /v
                              --a-- W32i   DLL   -         1.8.0.0 shp    811,008 08-11-2003 msvcrt-ruby18.dll
                                      FileVersion     1,8,0,0
                                      VS_FIXEDFILEINFO;
                                      Signature;      feef04bd
                                      Struc Ver;      00010000
                                      FlagMask;       0000003f
                                      Flags;          00000000
                                      OS;             00000004 Win32
                                      SubType;        00000000
                              *(filever is a file version utility that is installed with Windows Support Tools. The Support Tools are not installed automatically with Windows. You must manually browse the WIN install CD to the "Support Tools" folder, and run a separate setup.exeto install the tools.)
                              • AdamBA Offline
                                AdamB
                                Given there are many fixes between 1.8.0 and 1.8.6 - and using 1.8.6 doesn't seem to cause problems - I don't know why Google are shipping quite so old a dll. In particular, I noticed a few fixes in the changelogs to Ruby related to memory leaks.
                                FYI Mac Sketchup uses 1.8.5
                                Adam
                                  Dan Rathbun
                                  The Support Tool bindiff.exe reports both files are identical.
                                  DOS cmd shell in folder:
                                  >bindiff /c msvcrt-ruby18.dll v180-10\msvcrt-ruby18.dll
                                  Identical  811,008 bytes
                                  File Count Summary
                                     Identical;      1 files
                                     Near Identical; 0 files
                                     Different;      0 files
                                     Left Only;      0 files
                                     Right Only;     0 files
                                     Errors;         0 files
                                     Total;          1 files
                                  Byte Count Summary
                                     Matched;    0 bytes differ
                                     Left Only;  0 bytes
                                     Right Only; 0 bytes
                                     Total;      0 bytes
                                  *(bindiff is a binary file comparison utility that is installed with Windows Support Tools. The Support Tools are not installed automatically with Windows. You must manually browse the WIN install CD to the "Support Tools" folder, and run a separate setup.exeto install the tools.)
                                    Dan Rathbun
                                    @adamb said:
                                    ... I don't know why Google are shipping quite so old a dll. ...
                                    It may just be a staffing issue, they know it works with 1.8.0, but are probably reluctant to ship with 1.8.6 without massive testing. I can see management feeling such an task as being low priority.
                                    There was also at least one person at Google, who thought wrongly (the removed quote above,) that Ruby for Sketchup had to remain at v1.8.0 because the DLL (they thought,) had been extensively modified and compiled specially for Sketchup; and that to update to 1.8.6 or any other later release would be a huge project, not likely to occur any time soon.
                                    __Well, I think I've proved that assumption incorrect. The Ruby Interpreter DLLs are just copies of those distro'd with standard Ruby.
                                    @adamb said:
                                    Given there are many fixes between 1.8.0 and 1.8.6 - and using 1.8.6 doesn't seem to cause problems - ... In particular, I noticed a few fixes in the changelogs to Ruby related to memory leaks.
                                    A good reason to use 1.8.6 with Sketchup, and I have been since a few days after I installed 7.0 (and have had no problems, so far.)
                                    I would feel that 1.8.7 is still not ready (it just had a recent release to fix major security bugs.) But it's almost there.
                                    I tried to get Sketchup to load 1.9.1, but it did not like the DLL. I got the 'Entry Point Not Found' error. (Not sure if it was the Ruby guys who changed things, or if it was me renaming the msvcrt-ruby191.dll to msvcrt-ruby18.dll that was the problem.)
                                    There are those of us, who wish to run newer Ruby releases (especially the non-english users who need multibyte character support in the 1.9.x branch.) We should be able to run any Ruby release we wish.. and it would be nice if Sketchup was setup to facilitate our choice.
                                    I suspect because of the major differences in OSX and Win32 programming, that there are different people working on the two implementations.
                                    Does OSX Leopard come with ver 1.8.5 pre-installed?
                                    _
                                    • W Offline
                                      Whaat
                                      hmmm...I replaced the original DLL with the 1.8.6 version and I am now getting this message at Startup
                                      Error Loading File ruby-prof.rb
                                      no such file to load -- erb
                                      I have ruby-prof.so, ruby-prof.rb and the ruby-prof folder in my plugins folder. πŸ˜• Any ideas?
                                      • tbdT Offline
                                        tbd
                                        comment out these lines from ruby-prof.rb if you dont want pretty outputs or add erb.rb to your ruby-prof dir (I choosed the first one πŸ˜‰ )
                                        require "ruby-prof/graph_printer"
                                        require "ruby-prof/graph_html_printer"
                                        http://plugins.ro
                                          driven
                                          @dan rathbun said:
                                          Anyone want to make a Mac version out of this?
                                          _
                                          making one is out of my league, but I'd like to use it if someone does, I'm attempting to learn ruby as my first, ever, programming language, any tools that work with ruby, SU and Mac should aid may grasp on the mechanics...
                                          any other recommendations welcome.
                                          EDIT: I was digging around in systems library and came across this, can anyone shine a light on it's meaning and if it may be causing any of the many Mac ruby glitches that rear their heads.
                                          Notes on building the stand-alone reader.
                                          1. When trying to link with only MacWin and Utils, EqualTol came up as an unresolved external, so someone must be including Tol.h or something at the wrong level.
                                          2. Text.cpp in Model includes BaseApp/BaseAppServices.h. It is calling GetActiveView(). It should be restructured so that it doesn't need to call this.
                                          3. Model/MergeController.cpp is calling AppServices::GetUndoManager() which is not defined at the Model level.
                                          4. InstancePath.cpp and SectionPlane.cpp both reference CPickRecord which is not defined at the Model level.
                                          5. SteStatusText should be removed from PushPullController.cpp
                                          6. The output variable for OpenDocument should be of type IDocument rather than IDispatch.
                                          7. Need Mac implementations of OpenDocument and CloseDocument.
                                            (added in special reader version of XApplication.cpp)
                                          8. OpenDocument and CloseDocument are not implemented in the standard version of XApplicaiton. I have copied XAxpplication to the Reader folder so that I can implement this for the reader without changing SketchUp. After 3.0 releases, these implementations should be merged.
                                          9. IApplication::CloseDocument is a worthless method. There should really be a Close method on Document instead. Or at least CloseDocument should take an argument to tell you which document you should close. Maybe XDocument should delete the CSketchUpModel if it was created by a call to OpenDocument?
                                          10. Some methods still return IDispatch* rather than the real type. For example, get_Relationships.
                                            Dan Rathbun
                                            That looks like it refers to the C++ files for building the SKP Reader extension for a third-party application. So those 'issues' are C++ issues with the SKP Reader SDK, not Sketchup itself or the SU Ruby API.
