    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    JSLint - what's important, what's not?
    9 Posts 3 Posters 2.0k Views 3 Watching
    • chrisglasierC Offline
      chrisglasier
      Here is sampling from a JSLinting of one "core" js file, with some requests for help ... (Btw it runs OK on my machine and is IE only)
      ` Problem at line 15 character 5: 'window' is not defined.
      window.location = "skp:" + callback + "@" + params.join(';');`
      This seems very odd to me; surely it cannot be bad!
      ` Problem at line 29 character 9: 'nameDown' is not defined.
      nameDown(params);`
      nameDown is a function in another file; any problem with that? There will be other similar calls.
      ` Problem at line 103 character 65: Be careful when making functions within a loop. Consider putting the function in a closure.
      o.onmousedown = function() { coreDown(this , c , dv ); };`
      This one is more difficult. Here is the relevant part of the function:
      // o is a div
      o.className = p + cn;
      s = o.style;
      s.width = "100%";
      s.height = ch;
      Is the recommendation relevant, possible?
      Problem at line 141 character 5: Bad line breaking
      ... ,interval); in this code
      function coreAnimate(obj, elm, begin, end, duration, fps) {
      	var change,interval,steps,i;
      	change      = end-begin;
      	interval    = Math.ceil(1000/fps);
      	steps		= Math.ceil(duration/interval);
      	if(obj.coreStop){
      		window.clearInterval(obj.coreStop);
      	i = 0;
          obj.coreStop = window.setInterval(
      	function() {
      		obj.last = linearTween(i, begin, change, steps);
      		obj.style[elm]  = obj.last + 'px';
      		i+=1;
      		if (i > steps){
      	,interval);
      It certainly does not look good but is it bad?
      ` Problem at line 148 character 14: 'ActiveXObject' is not defined.
      fs = new ActiveXObject("Scripting.FileSystemObject");`
      I guess this is the same as window as noted in the last bit of the report:
      Implied global: window 7,15,130,133,139, nameDown 29, Refresh 63, ActiveXObject 148,162,171
      Any help and suggestions gratefully received.
      • tbdT Offline
        tbd
        window is defined only in browser environment and it is done by the browser, so JSLint doesn't know that.
        use option Assume a browser
        you can try to combine all js files and run it through jslint after.
        it is a warning as functions/variables are not what you expect to be when they are executed.
        kinda. if you add something before ,interval it screw things up
        see #1
        try with assume as browser activated and see what is left.
        JSLint comes with "Warning: JSLint will hurt your feelings" πŸ’š
        http://plugins.ro
          chrisglasier
          Thanks for that. Yes I did tick assume as browser but it says in the instructions
          The browser option does not include the aliases of the global object, window and self.
          So I thought I would ask the brains. As for feelings ... I think I lost them at the turn of the century.
            MartinRinehart
            In a browser, window is the global object so window.location difers from location only in the amount of typing you do.
            More exactly, window is one of the global objects. In a frameset, every frame has its own window. If you launch two WebDialogs, each has its own window (or, windows).
            For those who do not know, JSLint is Doug Crockford's JavaScript checker, analogous to the W3C HTML validators (although Crockford's work is cleaner). It is extremely picky and I have never found it wrong.
              chrisglasier
              Thank you Martin, I understand ... but when I untyped all window prefixed statements I still get one notification:
              Problem at line 15 character 5: Read only.
              and in another file, this:
              Error:
              Problem at line 6 character 17: 'window' is not defined.
              f.left = window.screenLeft;
              Problem at line 7 character 16: 'screenTop' is not defined.
              f.top = screenTop;
              which I find confusing.
              • tbdT Offline
                tbd
                without having the complete file to test it on jslint cant help much.
                maybe it depends on another variable defined before
                window is still used πŸ˜‰
                f.top = screenTop;
                as you removed window screenTop is undefined now as well
                do you want to make the .js warning/error free ? how many left ?
                http://plugins.ro
                  chrisglasier
                  @ TBD
                  I am jslinting the other files and will combine and retest them as you suggested. Error free would be optimal but understood non-harmful errors like window would be acceptable second best.
                  Thanks for your reply - will post any interesting (to me!) outcome.
                    chrisglasier
                    Another thing is that I removed all eval()s but I am very unsure why sourcing js files (not JSON) from remote locations over the Net seems not to be mentioned as similarly evil.
                      chrisglasier
                      @chrisglasier said:
                      @ TBD ... will post any interesting (to me!) outcome.
                      Error:
                      Problem at line 116 character 5: Bad line breaking before ','.
                      Problem at line 161 character 65: Be careful when making functions within a loop. Consider putting the function in a closure.
                      Problem at line 297 character 18: 'noldDown' was used before it was defined.
                      function noldDown(params){ //params = cell , sliderName , sliderNo , cnt...
                      Problem at line 389 character 18: 'moldDown' was used before it was defined.
                      function moldDown(params){
                      Implied global: ActiveXObject 16,34, window 43,44
                      Well not perfect but I think acceptable (please correct me if I am wrong).
