    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Does any SketchyPhysics Mac user exist ???
    10 Posts 4 Posters 2.1k Views 4 Watching
      Sandeman
      I really start to believe that this Ruby plugIn doesn't work on a MAC. I test a bunch of solution, read all the tutorials and forum existing on the subject.
      My Mac doesn't want to work with SketchyPhysics, and i cry.
      • W Offline
        willeykj
        It works on Intel Macs.
        I did the port of SketchyPhysics to the Mac.
        What particular problem are you having?
          Sandeman
          Sketchup doesn't recognize the file. I tried changing the code and write load "sketchup" at the begining of the code, nothing happen. I just have the tools present in the workspace.
          Mystery...
            tfdesign
            Sandeman, have you at any point installed Podium for Mac in the past?
              Sandeman
              No, i swear.
                tfdesign
                Is the plugin in your Mac or Home/User library?
                  Sandeman
                  The plug in folder is in the Mac directory. I tried to create one in the User library, but it didn't succeed anymore.
                  The real message is (in french)
                  "Erreur de chargement du fichier sketchyphysics.rb
                  Failed to load /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/dl.bundle"
                  It's seems to be the dl.bundle file that is problematic?!
                  • W Offline
                    willeykj
                    Does dl.bundle exist in the directory?
                    I know there was a release of Sketchy Physics that Chris put out awhile back that had a problem with dl.bundle. Try downloading the latest release and trying again. I know thet SP works on mac and I'm sure we can get it working for you.
                      Sandeman
                      OK
                      Now it works on my Mac (10.5.8) but not on the other one (10.4.5).
                      But "tant pis", i'll work on the first one.
                      Thanck you for the time spent to your answer
                        KSJ100
                        I use SketchyPhysics (at least I tried to) on mac and I fixed the joints and now the toolbar doesn't show up!!! Also I use a PowerPC Mac! ๐Ÿ˜ž
