    Skp to off format... plugin
    6 Posts 4 Posters 769 Views 4 Watching
    • V Offline
      venommax
      Hi all,
      I am looking for a plugin that can convert skp file format to off format (object file format)...
      right now i am converting skp file to stl file using a sketchup plugin and then converting it to off format using another software...
      Any direct ways to do the same...
      Hoping to get a quick reply as usual.....
      thanx...
        Aerilius
        I hope it's this what you mean (I know it as .obj files):
        obj exporter with materials
        For more plugins and exporters, you can have a look in the extensions index.
          remus
          The format seems relatively simple: http://shape.cs.princeton.edu/benchmark/documentation/off_format.html
          So just a case of finding someone with suitable ruby skills to write it.
          edit: ...or you could just hack jims .obj exporter. As aerelius mentioned the format of .obj and .off is very similar/the same.
            Not the same. You can't swap them around. The structure is somewhat different.
              Should be easy enough to write to this format. Using the PolygonMesh class you get everything organized in the manner the file format requires, with the exception that PolygonMesh's index starts at 1 instead of 0.
              • V Offline
                venommax
                can anyone write the plugin and give me... i am a newbie to both ruby and sketchup api...
                thanks..
