    Two jigs to share
    19 Posts 2 Posters 5.5k Views 2 Watching
      I found pictures of an adjustable box joint jig.
      http://www.mv.com/users/besposito/woodworking/SN_BoxJointJig1.jpg
      Here's a view from the front. The "spacer" or guide pin is attached to the front vertical fence as is the hardboard base on which the work sits. The front vertical fence is bolted to the rear fence though short slots. You might make those slots longer to accommodate a wide variety of widths. The guide pin on this jig is to the right of the blade from the operator's view.
      http://www.mv.com/users/besposito/woodworking/SN_BoxJointJig2.jpg
      View from the rear. there's supposed to be an adjusting screw in that little square brown piece at the near end. This is the fine adjuster.
      Does that shed an light?
      • bazB Offline
        baz
        @dave r said:
        I actually like the whooshing sound better than the high pitch whine of a single blade. And with proper methods including a slower feed rate, the thing isn't really any worse than a single blade. The worst part for me is that mine drags up sawdust out of the case under the table and blows it around the shop. I should be more religious about using my dust collector on the saw all the time.
        Let me see if I can do a quick sketch for you.
        While we are waiting,have a look at this.
        rosewood bits boxes.skp
        • bazB Offline
          baz
          [Does that shed an light?
          quote="Dave R"]I found pictures of an adjustable box joint jig.
          /quote
          no, it does not, but that could be me as i can hardly type at the mo, its my 58 birthday as we speak and i have overtrained and i cannot..... etc. think.....
          baz.
          ps: i would like to say how much i appreciate your friendship and others on this forum.
          g/nite-------------------
            Happy Birthday and good night.
            Nice work on the bits box. Very good.
            • bazB Offline
              baz
              donkey's ear?
                That, too. A good shooting board.
                • bazB Offline
                  baz
                  ta.
                  • bazB Offline
                    baz
                    Dave, sorry about that, had a bit of a meltdown last night.
                    But in the sober light of day the jig does make a lot of sense, I will have to knock one up for the next job.
                    baz
                      No worries, my friend. You had a good excuse.
                      I'm glad it makes more sense, now.
                      How's your head?
                      Dave
                      • bazB Offline
                        baz
                        How's your head?
                        Dave
                        my head? is that the thing between my ears thats pounding? 😞
                        baz
                          Maybe you need a little hair of the dog.
                          Actually, a litre of water would probably help.
