    New API doc - typos and questions
    370 Posts 35 Posters 263.4k Views 35 Watching
      sheeeesh! No wonder it was all confusing. πŸ˜†
      • Dan RathbunD Offline
        Dan Rathbun
        A TEMPORARY fix for dealing with the differing formats of color integers.
        Adds 4 methods to Integer (and subclasses Bignum and Fixnum.)
        Get it in the main Ruby Discussion forum, thread:
        [Ruby Extension] for Sketchup color integers
        I'm not here much anymore.
          PickHelper.path_at
          PickHelper.depth_at
          PickHelper.path_at
          PickHelper.transformation_at
          All these are described as index 1 being the root element. But that's not in my experience. I was using PickHelper.path_at and PickHelper.transformation_at for one of my scripts where I was drilling down through groups/components. When using PickHelper.transformation_at(1) to get the global positions I would get nil half the time. PickHelper.transformation_at(0) worked instead.
          Error 404 (Not Found)!!1
          (code.google.com)
            PolygonMesh.uv_at
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/polygonmesh.html#uv_at
            There are two arguments:
            PolygonMesh.uv_at(int_index, bool_front)
            PolygonMesh.uvs
            http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/polygonmesh.html#uvs
            This requires a boolean value as argument.
            true returns front UV data set.
            false returns back data set.
              PolygonMesh.add_polygon
              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/polygonmesh.html#add_polygon
              I can't seem to add points like the example does.
              Instead, I must first add each point using PolygonMesh.add_point and then provide PolygonMesh.add_polygon with index values that refers to the points.
              In general this PolygonMesh seem to have many errors in the description of the methods, arguments and usage. Recommend a closer revising of this section.
                Entities.fill_from_mesh
                http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#fill_from_mesh
                smooth_flags does not default to 0. Seems to default to 12 (soft and smooth)
                weld_vertices - what does this really do? I can't see any difference in the resulting geometry.
                  Entities.add_faces_from_mesh
                  http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#add_faces_from_mesh
                  Returns:
                  faces
                  an array of Face objects if successful
                  In my tests it returns 0 - not an array.
                    cjthompson
                    That's weird. It works just fine for me.
                      Can you post a quick example?
                        Ah! That's what I tried. Using a normal Array as substitute of Point3D. How odd that this method suddenly don't let you interchange arrays and Point3Ds... πŸ˜•
                          cjthompson
                          now I see why it doesn't work with arrays:
                          mesh = Geom;;PolygonMesh.new
                          mesh.add_point([0,0,0])
                          mesh.add_point([1,0,0])
                          mesh.add_point([1,1,0])
                          mesh.add_point([0,1,0])
                          mesh.add_polygon([1,2,3,4])
                          Sketchup.active_model.entities.add_faces_from_mesh(mesh)
                          you can use an array to index the points directly (for some reason, starting at 1)!
                          Can you test whether this is faster than point_at?
                            I will see over the weekend. I found some slowness by having to use .add_point and then later use .point_index to build the polygons. building my own hash of Point3Ds and the index I got from add_point was faster.
                            Hopefully adding points in the add_polygon methods directly will be faster.
                            Oh yea - the index start at 1 is annoying as well.
                              cjthompson
                              I think I found what your problem is.
                              This works:
                              mesh.add_polygon(Geom;;Point3d.new(0,0,0),Geom;;Point3d.new(1,0,0),Geom;;Point3d.new(1,1,0),Geom;;Point3d.new(0,1,0))
                              This doesn't:
                              mesh.add_polygon([0,0,0],[1,0,0],[1,1,0],[0,1,0])
                              EDIT:
                              You can put the arrays inside of another array to get it to work:
                              mesh.add_polygon([[0,0,0],[1,0,0],[1,1,0],[0,1,0]]) #this works
                                Using .add_points first and using index references for .add_polygon seems faster than using Point3d's.
                                • RichMorinR Offline
                                  RichMorin
                                  General
                                  Class and method names could be turned into links
                                  to the appropriate API page, for ease of navigation.
                                  Sentences should begin with a capital letter and end with
                                  a period (etc). Phrases should not.
                                  If a modifying phrase is used at the end of a sentence,
                                  a comma should be added for clarity:
                                    the name of the attribute dictionary  if successful
                                                              dictionary,
                                  Specific
                                  http://code.google.com/apis/sketchup/docs/ourdoc/animation.html
                                  animation -> animation
                                  ruby      -> Ruby
                                  ... to pause, only certain ...
                                         pause;
                                  http://code.google.com/apis/sketchup/docs/ourdoc/appobserver.html
                                  ... a 2nd    model ...
                                        second
                                  Useful for if you need ...
                                  This is useful if you need ...
                                  http://code.google.com/apis/sketchup/docs/ourdoc/array.html
                                  The SketchUp Array class adds ...
                                  SketchUp adds ...
                                  Specifically, it contains methods ...
                                  Specifically, it adds methods ...
                                  ... arrays of 3     coordinate ...
                                                three
                                  ... vector. it returns ...
                                              It
                                  http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                                  ... all of the attributes dictionaries.
                                                 attribute
                                  http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionary.html
                                  Although the page does not discuss this, setting a
                                  custom attribute with a key that contains upper-case
                                  letters does not work.
                                  The page does not indicate how to set an attribute
                                  (eg, '=LenX+20') to be used as an expression.
                                  In the entry for AttributeDictionary.each, the "value"
                                  argument is being formatted as part of the description
                                  for the "key" argument.
                                  Ditto for AttributeDictionary.each_pair.
                                    Dan Rathbun
                                    On the API docs pages, in the left nav column, whenever you have made a link bold, the cursor changes to a caret instead of the hand cursor. I suspect it's the <b> and </b> tags doing this.
                                    example from the API HTML source:
                                    <li><a href="/apis/..../model.html"><b>Model</b></a></li>
                                    Perhaps if the bold tags were outside the anchor tags?
                                    <li><b><a href="/apis/..../model.html">Model</a></b></li>
                                    If the css specifically set a tags such: a {cursor:hand} the nested bold tags should inherit their parent's cursor setting (according to the css reference.)
                                      The bold tag should not interfere with the cursor regardless if it's inside or outside the link element. It's default cursor property is inherit. It's either some override or other quirk. Could be a browser quirk.
                                      In FF3.5 I don't see this behaviour. What browser do you use?
                                        Dan Rathbun
                                        Currently still using MSIE 7
                                        P.S.: at MSDN it indicates if the cursor is not explicitly set, the browser decides; so it may indeed be a MSIE quirk. (I have MSIE 8 and FF on the computer in another room, I'll check and see how the site looks on that machine later today.)
                                          Tried with IE8 - cursor is normal.
                                          It certainly wouldn't surprise me!
                                            @dan rathbun said:
                                            Point3d.<
                                            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                                            Returns:
                                            true if the point2 is closer to the origin.
                                            Following the example, I get he opposite result.
                                            The Returns: should probably read,
                                            " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                                            And the anchor link http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/point3d.html#%3C doesn't work for me under FF3.5. Might be due to the < character.
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
