    I invite you to an orange juice!
    9 Posts 4 Posters 1.3k Views 4 Watching
    • N
      nacholo
      "Dear Sirs"
      I had made a glass with orange juice and two ice rocks, to improve a pool scene in a project. I'd share it.Good profit!
      (At me have been interesting to make the ice cubes, but i don't rounded the edges because I have thought that it was not necessary to this level of detail)
      Enlace:http://sketchup.google.com/3dwarehouse/details?mid=dd790b644c211cf27ce1512975119fcc&prevstart=0
      http://sketchup.google.com/3dwarehouse/download?mid=dd790b644c211cf27ce1512975119fcc&rtyp=lt&ctyp=other&ts=1259614426000
      Thanks and greetings
      • numbthumbN
        numbthumb
        Well, cheers then.
        Comfortably numb...
        • tridemT
          tridem
          I tried a close view but there are a lot of oddities in the model, like reversed face and interferences... so I modeled new from scratch, 😉 a good test for material development.
          cheers
          • N
            nacholo
            cheers
            Thanks, tridem
            What are reversed faces and interferences?. I am interested to learn. I'll be grateful a detailed explain.
            • numbthumbN
              numbthumb
              Well, you should check your model first - all the faces on the outside of the model should be white.
              There shouldn´t be any "blueish" faces.
              Therefore, you should reverse faces from the context menu.
              Comfortably numb...
              • tridemT
                tridem
                I'm not sure it's the same for others rendering engines, my little experience is about kerkythea. all the objects, divided by material, must have the front faces looking out, this means that looking into the empty glass you won't see any blueish face, it's a common beginners error. after that, you merged the orange juice with the glass, both materials have a common surface, this gets you faking refractions. there was also the ice material applied to the upper edge of the glass... all little things that in SU or in a wide scene you don't notice, if you made it for a pool model surely it runs well without loading the model with useless elements 😉
                • tridemT
                  tridem
                  this was a test with your model, apart the ice and juice bad materials ( 😕 what a troubles!) you can see the refraction between glass and liquid is not very realistic because lacks a surface that 'closes' the glass volume. also the flat edge looks not much pretty
                  • N
                    nacholo
                    OK!
                    Thanks to you, tridem. It's a full lesson!. Ususally i don't render without sketcup. I'll try to improve my models next time!
                    Thanks and greetings.
                    • K
                      KXI System
                      simple cup, I'll think I'll enjoy one too!
                      And I am still amazed by the realistic renderings!
                      Getting the perfect sig is hard...
                      Google it!
