    Some interesting serverless database. What do you think?
    11 Posts 4 Posters 1.7k Views 4 Watching
    • N
      NewOne
      It looks like nobody have nothing to say neither heard about it. And I'm trying to understand it. πŸ’š
      • Chris FullmerC
        So far I have not needed any database services in my scripts. But please do keep this updated if you get it working πŸ˜„
          Me neither, haven't dealt with databases since I was making websites.
          • N
            NewOne
            This one is slightly different from commonly used databases. It doesn't deals with tables, but with CLASSES. And as my knowledge about databases is at its beginnings, I have difficulties to understand how it works.
              Jim
              What is the problem you are trying to solve?
                Jim
                Well, if I take a guess at what you need , I think I can give a generalized solution in common use, and uses only open-source software.
                • select a computer to use as the server. It can be any computer on the network, or even your everyday computer you use for SketchUp.
                • Install the Apache web server, MySQL database, and PHP. If you are working on windows, there is a nice package called wamp. If you have a Linux machine to use as a server, the software is is almost certainly installed by default.
                • Create a test database with a table using Mysql command line, or PhpMyAdmin to make it easier. Set the database user and password. This will be used by the PHP script.
                • There will be a php script in the server /www folder that takes the POST data and send it to the database. PHP has a decent mysql library built-in. Use the username, password, and database name from the previous step to connect.
                • Use a WebDialog from SketchUp to send the post data to the PHP script.
                Obviously there are many details I left out, but maybe this gives you some idea what is involved without needing to install Ruby libraries for SketchUp.
                  Surely there are MySQL solutions already available for Ruby so you don't need to add the extra layer of PHP and webdialogs... ❓ That just sounds like begging for headache.
                    Jim
                    Of course there are, but I thought one of the problems was getting anything to work with SketchUp/Ruby.
                    The solution I gave should work on all platforms, and without adding anything to SketchUp.
                    • N
                      NewOne
                      I made MySQL working with SketchUp Ruby and was really easy to do it. But I didn't liked it because of the server. MySQL is too powerfull for some stand-alone small application. I tried same thing SQLite3, but I was unable to make it work under SketchUp Ruby.
                      In the end I found what I shown you. The concept is a little different from common databases, but is ruby πŸ˜„
                        Jim
                        I think CouchDB is an interesting project, too.
