    Scifi Sketchup Modeling
    454 Posts 57 Posters 105.5k Views 57 Watching
      Simon B
      Wow, the internet is getting smaller and smaller all the time.
      Glad to be of help.
      • olisheaO Offline
        olishea
        great work mate, so much detail it makes me dizzy!
        oli
          liam887
          Thanks for the comments everybody! It feels strange sometimes to post this type of work here as most of the stuff is architectural but its SU after all and everybody is great over here and gives lots of good advice and help!
          Well finished the rotating section at last! The outer modules provide a comfortable 1G at 1RPM. The inner modules I havent measured yet byt they are the exact same diameter as the other 4 large modules ive already created so should give the same gravity. As they are spinning at the same rate as the outer modules however ill have to do a load of working out, too late to think of maths now!
          Ill post some better pics but when I try to render it keeps on crashing ill have to assign more RAM to windows tomorrow.
          Anyway here is the rotating section, it also marks the midway point of the ship so halfway there, then go back to add the details and panels and radiators! So far the real worldy approach is making it look so much cooler than things I would usually just make up!
          @sepo said:
          Yes of course. have a look here. http://www.suplugins.com/index.php?p=page&page_id=materials
          sorry missed that you had wrote back, thanks for the link when ive got it running again ill give it a go, having some RAM trouble at the moment so just exporting the images you see here as jpegs straight from SU.
          VISIT MY ONLINE GALLERY
            dolphus
            Very impressive keep it up πŸ‘
              liam887
              Having trouble rendering the whole ship so did it in different parts so its easier to see. Also created a low poly truss for long shot renders.
                dolphus
                Looking very realistic (my opinion drop the shadow on the "floor) very good πŸ‘
                  liam887
                  Oh dont worry I will, these are only quick half renders to show the model, the ship isn't even textured yet for proper rendering.
                    liam887
                    Seem to have fixed my Memory issues so decided to try it on this beast, there was a lot of movement between SU and max for this so the geometry is tripled to what the SU file was. Anyway if I manage to render this then all should be well and I can carry on with the model. As for this shipyards model its been on the backburner for quite a while maybe ill get round to finishing it one day.
                      dolphus
                      My mind boggles at the thought of my nemesis "Polly Count" galloping rampant around your shipyard...fantastic it is fun watching it grow may the force.....
                        liam887
                        Thanks dolphus,
                        anyway getting rid of all the windows and having a big one at the front under the airlock. Added a little bryce man for a scale comparison. It will have metal shutters that go over it but I havent modelled them yet trying to work out a mechanism that will work, maybe a camera like iris on the inside or some metal blades on the outside?!?
                        Getting snow leopard OS tomorrow a big strp up from tiger so ill be able to install windows xp or 7 on bootcamp and finally get 3dsmax2010 up and running for some sweet texturing and renders! Watch this space (...)
                        Note: green bryce should actually be upside down as the cylinder spins the roof is actually the floor (in space anyway) but thought andbody looking at the image would think it was confusing, hes only for scale anyway!
                        • E Offline
                          ENG. YASEEN
                          u have a v good render here πŸ‘
                          well done β˜€
                          My Website:
                          http://xyz4studio.blogspot.com/
                            liam887
                            I have to laugh tho, when the render was done I looked it over and noticed all the buildings in the shipyard where floating many meters off the ground! Dont know how I managed that, they are all grouped together you see still a shame tho, oh well!
                              liam887
                              Doh!managed to delete some of my work when I upgraded to OSX 10.6 from tiger 😞.
                              Anyway the first image is what I had deleted a few days ago but since then ive rebuilt it slightly smaller but more detailed. Used marians shuttle for the basis of the second ships hull and little spaceman is by max grueter.
                              Working on the windows atm making them have depth and defining the frames to make them look more than just simple transparent geometry
                              original model i deleted by mistake all following images are rebuild using marians hull
                                dolphus
                                Nice ....very nice clean crisp lines and brilliant rendering ( I like the reflection of the Astronaut )
                                nice concept for a shuttle (show the launch vehicle too......)great stuff keep going πŸ‘
                                  liam887
                                  Thanks, there wont be a launch vehicle its a SSTO (single stage to orbit) using the aerospike engine. Its based off the NASA/Lockheed X-33 that got cancelled. However have added some solid rocket boosters for extra lift.
                                    liam887
                                    !Work In Progress!
                                      liam887
                                      work in progress
                                        dolphus
                                        Way cool Liam i like the Cockpit concept i can see myself piloting this craft int battle.......dream on πŸ‘
                                        • olisheaO Offline
                                          olishea
                                          Liam i saw your screenshot, how come you are still using podium 1.5? is it cos ur on tiger? black UI looks sweet! took me a minute to work out which OS you are using!
                                          some great work here, keep it up πŸ‘
                                          oli
                                            liam887
                                            Thanks Oli!
                                            Well ive upgraded to Leopard last week but haven't installed all my previous software its all archived on my drive so I just opened an old podium trial dmg from a pendrive for quick renders for the moment. Ive just upgraded to CS4 and still trying to get windows 7 on bootcamp with no luck SU & podium are next after that. I havent even got round to installing all my plugins again except for weld lol.
                                            Got webdesign module due on thursday and a presentation on Friday then im done till Jan so it will be render heaven come Christmas. One of the other reasons I havent got round to it is that I just got kerk renderer which didtnt work for me on tiger because my X11 was messed up but it going full power on my new OS so have been playing round in that. Do muss the one click wonder of podium tho lol!
                                            EDIT: ahh lol I was confused to what yo meant by 1.5, thats not on my mac those images are from a PC, my models but not my computer its my mates he renders stuff for me now and again like the big Star Trek ship as it will eat my MAC alive lol. Ive got the up to date Podium on my MAC ill be installing it soon like I mentioned above!
                                            Been looking at an 8core Mac Pro for the new year 😲 we will see the state of my wallet after christmas lol
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
