    Asking For Help Points are not planar (resolved)
    9 Posts 3 Posters 879 Views 3 Watching
      Mcdull
      i am trying to read polyline from xml document,then to generate three-dimensional wall.now there is a problem that just lines in the X direction can be drawn,the others in the y direction can not be drawn,and show a message that
      Error: #<ArgumentError: E:\test\RubyApplication1\lib\main.rb:250:in `add_face': Points are not planar>
      // if i draw the lines in the y -direction by it self,it can be done, i dont know why?pelese help me!
      thank u very much!
      [code][code][code][/code][/code][/code]
      [attachment=1:3jpuek0d]<!-- ia1 -->main.rar<!-- ia1 -->[/attachment:3jpuek0d]
        Would help if you enclosed your code in the CODE tag so it doesn't get smileys in the code - and it will preserve formatting. And with such a long code it's probably easier to just attach it.
          Mcdull
          ok,i have done.thank u
            Have you outputted the loopVertices to the Ruby Console content before passing on add_face? Just to visually inspect the data?
            Have to look further into what the code does before I can say anything more.
            But this code, right before line 250.
            loopVertices = []
            for v in loop
              loopVertices.push([v.x,v.y,v.z])
            Should that not say for v in loop.vertices ?
            I gather that you want an array of 3D points?
            That can be written:
            loopVertices = loop.vertices.collect { |v| v.position }
            Vertex.position returns a Point3D for that Vertex.
              Mcdull
              > loopVertices = []
              > for v in loop
              > end
              yes ,i have inspected all the loopvertices to the Ruby Console content,every wall has 6 faces.
              but if passing on add_face,the error will come out with the message points are not planar.
                Jim
                I think I got that error sometime when I had only 3 points. I thought there must be some mistake as any 3 points are planar. I found out later that the 3 points were in fact linear, and thus not planar.
                Maye this is what is happening?
                pts = [ [0, 0, 0], [1, 0, 0], [2, 0, 0] ]
                Sketchup.active_model.entities.add_face pts
                Error; #<ArgumentError; (eval);65;in `add_face'; Points are not planar>
                  Mcdull
                  i have solved the problem ,thank u
                    And what was it?
                      Mcdull
                      @thomthom said:
                      And what was it?
                      when i generate 3d wall,some points are not planar.i have changed the function.
