    Render this: SSS
    174 Posts 44 Posters 27.9k Views 44 Watching
    • daleD Offline
      dale
      Tried an experiment. Copied the dragon, pasted it in place, scaled one copy down by 10%, placed it inside the other dragon to give it a real subsurface, assigned the outer skin a transparent material, and the inner a green translucent material. Didn't turn out like I expected, but was fun.
      The mint jello dragon
      • jeff hammondJ Offline
        woulda sounded better if you called it sour apple or something 😄
        • EscapeArtistE Offline
          EscapeArtist
          Hmm, if the IoR is the same it may have negated the effect. Perhaps applying a mild fresnel effect to the outer layer?
          • david_hD Offline
            david_h
            Looks more like Lime Green Life-Saver.
            • olisheaO Offline
              olishea
              great renders guys. man this is getting technical!
              how about some sub surface scat?! im sure a good old dump has some sss haha, so come on guys lets polish a turd 😄
              oli
              • E Offline
                Ecuadorian
                @woodtick said:
                I had to give it a try with this little guy.Twilight #9....let it render while I was at work yesterday for about 12 hrs.
                Rich
                http://www.forums.sketchucation.com/download/file.php?id=37074&t=1
                Woodtick, this looks very interesting. Could you share how you did it?
                -Miguel Lescano
                • arail1A Offline
                  arail1
                  modo with drag and drop presets
                  • soloS Offline
                    Playing again.
                    • W Offline
                      woodtick
                      Ecuadorian,
                      Well, since I'm really new to this I'm just trying different ideas to see what happens. Nothing scientific to my approach, but I'll share as best I can.bowl,dome.JPG
                      Dragon sits in the bowl: high reflective template
                      Dome goes on top for the render:diamond glass
                      spotlights as shown
                      Two small red omnis, nose& throat
                      skinny spotlight on tongue
                      tiny orange omni eye
                      started with rubber ball material and tweaked :material.JPG
                      SU fog on
                      TW preset #9
                      That covers most of it I think.
                      Lots of great images here folks......keep 'em coming.
                      Rich
                        richcat
                        Pete that's not the Lockness monster is it 😮
                        • daleD Offline
                          dale
                          [/quote] escapeartist wrote: Hmm, if the IoR is the same it may have negated the effect. Perhaps applying a mild fresnel effect to the outer layer?[/quote]
                          I haven't had much time to play lately, but when I do I'll give this a try. Thanks
                          • E Offline
                            edmund
                            playing
                            http://www.hyndman-hyndman.com/Ryan/dragons2.jpg
                            • soloS Offline
                              Edmund, those look fantastic, what render app?
                              • E Offline
                                edmund
                                twilight
                                preset 9
                                let it run overnight
                                Thanks Solo.
                                • boofredlayB Offline
                                  boofredlay
                                  That is excellent. I've not been able to get that kind of result from Twilight. Will have to have another go at it. Do you mind showing your lighting setup?
                                  Does the orange dragon have an eyepatch?
                                  • E Offline
                                    edmund
                                    of course
                                    http://www.hyndman-hyndman.com/Ryan/dragon setup.jpg
                                    http://www.hyndman-hyndman.com/Ryan/omni setup.jpg
                                    It was an accident that my light bulb size(radius) was at 50.8 😲
                                    I also used a HDR lighting for the sky probe. Oli posted the link to said hdr images a little while ago.
                                    Thanks Oli.
                                    and you did spot my eyepatch... haha
                                    • daleD Offline
                                      dale
                                      edmund, you nailed it 👍
                                        Chris_at_Twilight
                                        50.8 is millimeter equivalent of 2 inches, the default light size. 😄
                                        http://www.TwilightRender.com
                                        • E Offline
                                          edmund
                                          thank god. I was looking at it like "really?" thats what I made the light bulb size.
                                          thanks for clarification
                                          Thanks Dale
                                          • E Offline
                                            Ecuadorian
                                            Those looked really good, Edmund. 👍
                                            Now, they say imitation is the most sincere form of flattery, so I hope Remus doesn't mind my try to achieve a similar look to his blue rubber dragon:
                                            -Miguel Lescano
                                            • 7 / 9
