    PushPul not removing faces.
    4 Posts 3 Posters 427 Views 3 Watching
    • G
      Gruff
      I was trying to make the simple chair model shown in one of the tutorials run from a program and ran into a problem with PushPull.
      I started with a rectangular cube based on the overall dimensions.
      1. Pushed the seat down from the cube top. Okay.
      2. Pushed the space between the legs side view through the cube. Okay.
      3. Pushed the space between the legs front view to the intersecting space from step 2. Fail.
      It creates the projected rectangle but does not remove it.
      My numbers look correct. I am creating faces for the PushPull.
      How do I do this?
      #pseudo code
      wt = width
      dp = depth
      ht = height
      stht = seat height
      ss = stock material size (Leg side)
      cube = wt x dp x ht
      Top cube face
      face_1 = [0,0,ht], [0,dp-ss,ht], [wt,dp-ss,ht], [wt,0,ht]
      push face1 -(ht-stht)
      Right side cube face
      face_2 = [wt,ss,0], [wt,ss,stht-ss], [wt,dp-ss,stht-ss], [wt,dp-ss,0]
      push face_2 -(wt)
      Front side cube face
      face_3 = [ss,0,0], [ss,0,stht-ss], [wt-ss,0,stht-ss], [wt-ss,0,0]
      push face_3 -(ss)
      #Fails to remove space at this point.
      Resistance is .... Character Forming. Grin
        Screenshot?
        • G
          Gruff
          Actually I found I could duplicate the problem manually.
          Create a cube.
          The push manually entered the right distance does not go through the wall.
          Sample
          • Chris FullmerC
            Interesting, I did it manually with no problems. Perhaps this is yet again coming back to SU tolerance issues?
