    Use Sketchup default cursors
    23 Posts 7 Posters 7.8k Views 7 Watching
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#create_cursor
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#set_cursor
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#onSetCursor
      • C
        confitex architure
        Right thomthom, thanks
        It changes it with an image. How to replace it by a square that fits values you entered previously? By putting a temporary component that draws the square and that follows the mouse path?
        Or how to get the same effect that I see on this advertisement from 3skng i see on the bottom?
          Not sure if this is what you're talking about, but there are methods you can use to draw things directly to the viewport without adding geometry to the model.
          Error 404 (Not Found)!!1
          (code.google.com)
          • C
            confitex architure
            Nothing happens...Not even errors on Ruby console.
            I tried
            model = Sketchup.active_model
            view = model.active_view
            point1 = Geom;;Point3d.new 0,0,0
            point2 = Geom;;Point3d.new 10,10,0
            point3 = Geom;;Point3d.new 10,20,0
            point4 = Geom;;Point3d.new 10,30,0
            status = view.draw_polyline point1, point2, point3, point4
            Or
            point = []
            point[0] = Geom;;Point3d.new 0,0,0
            point[1] = Geom;;Point3d.new 10,10,0
            status = view = view.draw GL_LINES, point
              The draw method is used to do basic drawing. This method can only be called from within the draw method of a tool that you implement in Ruby.
              • C
                confitex architure
                I don't get it.
                What does that mean? Can you give me a short example?
                  You can only use the .draw methods from within a custom ruby Tool.
                  You must create a Tool http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html
                  Implement the Tool.draw method http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#draw
                  and do your drawings from that method.
                  I've attached a quick and dirty test code.
                  test.rb
                  • C
                    confitex architure
                    Thank you for such a "dirty" code! 😄
                    Now I get it
                    • C
                      confitex architure
                      In the onMouseMove definition, view.invalidate match better. (I've seen that thanks to an old post from Jim)
                      		def onMouseMove(flags, x, y, view)
                      			view.invalidate
                      I don't really understand why in deactivate(view) refresh makes it and not in onMouseMove. Nevermind.
                      It's now easy to follow the mouse move and to replace the cursor with the .draw method.
                      Thanks again!
                        ah, the .refresh method is new to 7.1 I think - I was just testing it - comparing it to the old .invalidate.
                        Also, note that my test code is by no means a standard for best practice. For a real tool that draws you probably want to add extra code to ensure you only draw when you have new changes to draw. Drawing on every mousemove isn't very efficient - it's just a quick'n dirty way to test some code.
                          Do SU use .cur files? Isn't it just .png?
                            Jim
                            I've only used .pngs', but I suspect the extension is less important. I think SU uses the freeimage lib which supports many formats. (I'm clearly making a lot of guesses about how things work.)
                              If it reads .cur format, I wonder how it deals with the hotspot point of the cursor. Since the .cur format has that stored within, but .png does not. And the method that creates the cursor expected you to input hotspot co-ords.
                              Only way is to test it.
                                Yea, weird that the .cur format isn't supported. With these PNGs you always have to remember where the hotspot for the cursor is...
                                • Dan RathbunD
                                  Dan Rathbun
                                  UPDATED!
                                  Here are 4 Yellow pencil cursors I made myself with Visual Studio (and converted to png with Paint.NET)
                                  They point NorthEast, NorthWest, SouthEast & SouthWest.
                                  Given in Windows .curformat, so you may use with any Windows Application; .. OR..
                                  and in .pngimage format for use with Sketchup custom tool(s) / plugins.
                                  • 32x32 png cursor images have hotpoint as part of filename
                                  • button images have size (16 or 24) as part of filename
                                  I grant permission to use freely for NON-COMMERCIAL purposes. I however reserve and retain Copyright under US code, and International Treaty (Berne Convention.)
                                  [read Copyright.txt for tips on use with Ruby, where to install etc.]
                                  UPDATED! Originally only in .cur format; Now given in png format with small and large button images as well. Cleaned up the bmp after conversion to png, and did anti-aliasing work on edges. ENJOY!
                                  Four Directional yellow pencil Cursors.
                                  Free for NON-COMMERCIAL use.
                                  Author retains Copyright.
                                  [read Copyright.txt for tips on use with Ruby.]
                                  I'm not here much anymore.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    %(#408000)[Yellow Pencil Cursors UPDATED!
                                    Now also in png image format; w/ new anti-aliasing edge work, small and large button images.
                                    See original post link below:
                                    http://forums.sketchucation.com/viewtopic.php?f=180&t=22204&p=198338#p198338
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Yes your right Thom, I boo-boo'd. Posted before I tested.
                                      SU does NOT recognize ****.cur**** files. If you try it the id for the cursor = 0. (I'm once again flabbergasted at whomever wrote the SU ruby API. They've earned 20 lashes with a Nerf-Noodle!)
                                      The API states 'image' but does not say what formats are acceptable.
                                      I've already begun extracting the 4 images files from the cursor files, decided to do a bit of anti-aliasing work on the edges of the pencils.
                                      DONE (Original posting now has updated zip with png images for SU cursors and buttons.)Get them...
                                      Will also look at the Windows API and see if I can cobble up a system call to load a cursor file instead of making a call to UI.create_cursor, as UI.set_cursor should not care how the cursor got loaded into memory, it only wants a pointer (id). [Some testing has shown the UI.set_cursor canNOT deal with Windows Cursor resources, so a 'special' set_win_cursor method would be needed, using a direct Win32 API call.]
                                      • eneroth3E
                                        eneroth3
                                        These links you give me 404 errors 😢 . I know I've read about this somewhere else recently but can't remember where now.
                                        EDIT:
                                        It might have been from when I read in TT lib the other day to understand how the win32api works. Found this page now: https://bitbucket.org/thomthom/tt-library-2/src/9ff3a5f08604ed477eb4b17fd63612bfc42832dd/TT_Lib2/cursor.rb?at=Version%202.9
                                        My website: http://julia-christina-eneroth.se/
                                        • tt_suT
                                          tt_su
                                          http://www.sketchup.com/intl/en/developer/docs/ourdoc/ui#set_cursor
                                          http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool#onSetCursor
