    [WIP] house - C&C
    12 Posts 5 Posters 1.7k Views 5 Watching
      21D
      Hi there folks,
      I've been working lately on a small house and i just started doing the interior,
      i started with the living, dining and kitchen,
      from there I'm going to the bedrooms and bathroom,
      i want to show you the renders so i can get some C&C, it's still not done, because there are still a lot of things i need to add so it can feel more PR.....
      Comments are very welcomed.
      Update (exterior)
      http://forums.sketchucation.com/download/file.php?id=42236
      http://forums.sketchucation.com/download/file.php?id=42239
      http://forums.sketchucation.com/download/file.php?id=42240
      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
      Le Corbusier
      • dermotcollD
        dermotcoll
        not a fan of the mirror on the island showback - understand why you would use it though.
        Don't like the colour of the worktop - would be better using a colour similar to your cabinet doors in a kitchen style like that.
        All the other aspects of the render are spot on in my very "un-render-educated" opinion. I would be very pleased if I could produce something half as good as that.
        When you burn your arse - you gotta sit on the blisters!!
          d12dozr
          Looks pretty good, although I would expect more lights in the ceiling, and maybe not as shiny a ceiling.
          http://goo.gl/f7ooYh
          • dermotcollD
            dermotcoll
            Just spotted another wee error on the model - the extractor hood is way too low to be practical - need at least 600mm between the top of the cooking surface and the bottom of the extractor to give a workable height for moving pots & pans easily. Sorry to criticise
            • honoluludesktopH
              honoluludesktop
              You left your rangetop on. Could burn the house down:-)
                21D
                first of all, thank you all for your C&C
                wouldn't it make the area to WHITE?
                I really do apreciate your advice, because this might be the house that i end up building to live in, so any advice does help.
                I'm going for an indirect illumination, this is why i have the reflective ceiling
                I'll post later on some images of the window/doors so you can see that even without turning on the light it's still going to have enough light coming through.
                actually it is exactly 650mm 😄
                maytbe because of the angle of the shot it looks a bit narrow,
                but there's quite enough space.
                I sat down with my "Neufert's Architects' Data"book when i was drawing up this house 😄
                oooops let me go turn it off hahaha 😉
                Le Corbusier
                  21D
                  a small update....
                  in the second image you can see that the windows are big enough to let a lot of natural light come trough....
                  added a couple more stuff to make it more PR, and changed the counter tops to mach the cabinets, like suggested. I'm quit pleased with the change.
                  An overview of the house....
                  Le Corbusier
                  • F
                    FoXar
                    Hmm looking nice, as a point of view from an interior architecture student I would add some more color as the following;
                    -It looks like you like the color red, white and red are a good combination you've made IMO but I would make the color
                    come back on some spots, like on some walls, here an example of which walls I would make red (btw, if you plan to use it don't
                    use plain red, but a somewhat deeper red which will create a nice mood with your indirect illumination.
                    -Also you could try to use a warmer coloured wood, don't get me wrong by saying warmer more 'red', but a darker
                    wood with more brown in it.
                    Hope this might help you and you like it, of course this is just based on what I would prefer to have and some knowledge from school..
                    Cheers,
                    FoXy ^^
                      21D
                      Cheers,
                      FoXy ^^
                      Yes it does help, because i did kind of feel like it was getting a little too white, if you know what i mean, i do appreciate your input and insight, i really love your ideas, and will be implementing them pretty soon. the wall will be no problem, but I'll have to find a good texture for the floor material, because right now i have non hahahaha, but I'll try to find something that fits your description, so i can implement it in,
                      and again thank you for you help.
                      Le Corbusier
                      • F
                        FoXar
                        Great to hear these were helpful, yes you were right, it was getting to white, if I may suggest an other thing, I get why you're making a mirror in the island, it
                        'creates' more space, but I really wouldn't do that tough, if you still want to create a somewhat larger looking space I recommend you to make it anodized aluminum (doesn't scratch too easy) with an indirect illumination that comes from the countertop down to the ground, you get what I mean?
                        And not to forget, here you have the wood texture (I took this from the maxwell material library: http://resources.maxwellrender.com/ and credits go to paxreld.
                        Diffuse
                        Bump
                        Specular
                        Preview
                        Cheers,
                        Mr. Fox ^^
                          21D
                          A little update on my Project
                          your C&C again are welcomed,
                          oh and thnx again to everyone for there help and advice,
                          hope you like the final outcome 😄
                          http://img24.imageshack.us/img24/1531/post001b.th.jpg
                          http://img20.imageshack.us/img20/4982/post002b.th.jpg
                          on the left is the original v-ray output and on the right, a PostPro image
                          http://img513.imageshack.us/img513/7117/post003b.th.jpg
                          http://img264.imageshack.us/img264/1874/post004b.th.jpg
                          http://img24.imageshack.us/img24/3264/post005b.th.jpg
                          http://img20.imageshack.us/img20/5356/post006b.th.jpg
                          http://img691.imageshack.us/img691/835/post007b.th.jpg
                          http://img691.imageshack.us/img691/1522/post008b.th.jpg
                          http://img513.imageshack.us/img513/38/post009b.th.jpg
                          http://img513.imageshack.us/img513/9876/post010b.th.jpg
                          Sorry i was not able to uplad the images directly to SketchUcation... 😞
                          Le Corbusier
                            21D
                            Hi again guys,
                            another update here,
                            i used VUE to render the exterior of the house
                            and photoshop to PP the render
                            hope you guys like it, and every comment and crit is very welcomed
                            RAW Vue render
                            Photoshop Post Processed image
                            NPR render
                            Le Corbusier
