    [script] Sketchup 7.1 all hiden action :lol:
    12 Posts 5 Posters 19.3k Views 5 Watching
      gavvy
      chinese: δΈ‹ι’ζ˜―SKETCHUP ηš„ιšθ—ε‘½δ»€ 使用方法 Sketchup.send_action + ζ•°ε­— πŸ˜†
      here is all the actions of sketchup
      Sketchup.send_action number
      eg: show hide the Large tool set
      Sketchup.send_action 23056
      πŸ˜†
      5 Bytes read: %d
      102  %1 uses characters which might lead to problems in certain applications.
      103  %1 uses characters which might lead to problems in certain applications.
      105  Could not load file %s.  %s.
      106  Could not connect to the 3D Warehouse. %s.
      107  You must have Google Earth running to use the snapshot capabilities.
      108  Are you sure you want to cancel?
      109  Google Earth Snapshot
      110  Camera altitude too high in Google Earth.
      111  Google SketchUp is unable to connect to Google Earth.
      112  An error occured while taking a snapshot from Google Earth.
      126  Photoshop (*.psd)
      127  SketchUp
      128  Google SketchUp (beta)
      129  Are you sure you want to cancel the import?
      130  All image files
      131  Windows Bitmap (*.bmp)
      132  JPEG Image (*.jpg)
      133  Portable Network Graphics (*.png)
      134  Tagged Image File (*.tif)
      135  Targa File (*.tga)
      139  Get current view from Google Earth
      140  Toggle between terrain and plan views
      141  File upload was unsuccessful; the error code was %d
      142  You cannot insert a component while you are in the middle of another operation.
      143  The file was rejected; the size of the submission (%dk) may be too big
      144  Go to the main 3D Warehouse page
      145  View your model in Google Earth
      146  The model being imported is located at a specific place on Earth, which may be far away from the current model.
      147  3D Warehouse
      149  Bytes sent; %d
      153  file=
      154  Could not find Google Earth exporter library (%s).
      155  Compatibility
      156  To extend the use of SketchUp beyond the evaluation period, you must fill out the boxes below with information obtained from Google Inc.  Please make sure all entries match exactly.
      157  If this doesn't work for some reason, or if you received your license in some other format than an email from us, click on the 'Skip' button below to skip to the manual license entry screen.
      158  Pro [EVAL]
      159  SketchUp Files (*.skp)
      160  Get More...
      161  Pro
      162  Free
      163  Pro [EXPIRED]
      164  Your SketchUp Pro license will expire on
      165  Continue
      166  Sketchup Pro License
      167  Get Pro 3D Exporters...
      168  Section Slice...
      170  Pro [LICENSE UNAVAILABLE]
      171  Your model contains unused items such as; components, materials, layers or styles. Purging these items may reduce the file size of your model.
      176  You should have received an email from us with your new license information in it. Copy and paste the text of that email into this window, then your new SketchUp Pro license should be set up automatically.
      177  Instructor
      211  Full Tool Set
      355  Face Style
      360  Camera
      362  Standard Views
      475  Construction Tools
      477  Section Tools
      499  Edit Tools
      501  Drawing
      717  Do you want to delete these scenes?
      794  Really stop downloading this file?
      795  Download Model
      796  Really stop uploading this file?
      797  Upload Error
      803  Sign-in error. Try signing in to your Google Account from a web browser.
      804  Service is not available. Try again later.
      805  Sign-in error. Verify username and password.
      807  Unable to connect. Check your internet connection settings.
      808  Before using this service, you must choose a nickname.
      960  Preserve location
      961  Choose new location
      962  Imported model location
      1097  Adjust the date
      1098  Adjust the time
      1212  Activate the shadow dialog
      1213  Toggle shadow display
      1301  Length
      1302  12.345
      1303  Measurements
      2021  Return to previous results
      2024  Go forward in history
      2027  Browse
      2032  Refresh current view
      2791  Are you sure you want to cancel this export?
      2792  Exporting ...
      2793  Download Error
      2794  An error occurred when connecting to the 3D Warehouse.  %s.
      2795  This model already exists in the 3D Warehouse and does not need to be uploaded.
      10000  Camera
      10001  Standard
      10003  Drag to orbit.  Shift = Pan
      10004  Drag in direction to turn camera
      10005  Drag in direction to pan
      10006  Click and drag to walk.  Ctrl = run, Shift = move vertically or sideways, Alt =  disable collision detection
      10007  Drag window area to zoom to
      10008  Drag cursor to zoom.  Up is in, down is out. Shift to change Field of View.
      10009  This does not appear to be a SketchUp model!
      10010  Angle must be between 0 and 360 degrees!
      10011  W
      10012  N
      10013  E
      10014  S
      10015  Alaskan Time
      10016  Pacific Time
      10017  Mountain Time
      10018  Central Time
      10019  Eastern Time
      10020  Atlantic Time
      10021  UTC
      10022  Cannot open location database
      10023  SketchUp was unable to initialize OpenGL!
      10024  The file was created in a newer version of SketchUp.
      10025  Print Error; Insufficient memory.
      10026  Unable to preview this view.
      10027  Focal Length
      10028  Field of View
      10029  %.2f deg.
      10030  %.0f mm
      10031  OpenGL hardware acceleration will be enabled
      10032  OpenGL hardware acceleration will be disabled
      10033  Unknown
      10034  %1!d! by %2!d! pixels
      10035  %1!d! Colors
      10036  High Color (16 bit)
      10037  True Color (24 bit)
      10038  True Color (32 bit)
      10039  %1!d! bit Color
      10045  High
      10046  Medium
      10047  Low
      10048  Yes
      10049  No
      10050  Precision
      10051  Shadows
      10052  Colors
      10053  Noon
      10057  Version;
      10059  Front
      10060  Back
      10061  Right
      10062  Left
      10063  Top
      10064  Bottom
      10065  Eye Height
      10066  To play an animation, you must have at least one scene that is included in the animation.
      10067  Inches
      10068  Feet
      10069  Millimeters
      10070  Centimeters
      10071  Meters
      10072  Edit value must be between %d and %d.
      10073  R
      10074  G
      10075  B
      10076  H
      10077  S
      10078  L
      10079  Points
      10080  More than 9 pages selected for printing
      10081  Draft
      10082  Standard
      10083  High Definition
      10084  Large Format
      10085  B
      10086  Face Style
      10087  Ultrahigh Definition
      10088  Display in wireframe mode.
      10089  Display in hidden line mode.
      10090  Display in shaded mode.
      10091  Display shaded using textures.
      10092  Display shaded using all same.
      10093  E&xit
      10094  &Orbit
      10095  &Pan
      10096  &Look Around
      10097  W&alk
      10098  &Zoom
      10099  Zoom &Window
      10100  Zoom &Extents
      10101  Display in X-Ray mode.
      10102  Display
      10103  Details
      10104  Anti-Alias
      10105  Show Dialogs
      10106  Hide Dialogs
      10107  Original Image Not Found
      10108  Right Click to Locate
      10501  Top View
      10502  Front View
      10503  Right View
      10504  Left View
      10505  Back View
      10506  Bottom View
      10507  Iso View
      10508  Orbit
      10509  Zoom
      10510  Display the sketch in wireframe mode
      10511  Display the sketch in hidden line mode
      10512  Display the sketch in shaded mode
      10513  Enable X-Ray Mode
      10514  Orbit the camera
      10515  Pan the camera
      10516  Zoom the camera
      10517  Walk with the camera
      10518  Turn (pan) the camera
      10519  Toggle perspective viewing on or off
      10520  Walk with the camera
      10521  View preferences dialog
      10522  Show or hide the sketch axes
      10523  Moves the camera viewpoint while maintaining view direction
      10524  Zoom Window
      10525  Pivots the camera view about a stationary point
      10526  Zoom Window
      10527  Zoom to extents
      10528  Zoom Window
      10529  Restore last viewing orientation
      10530  Exit camera operation
      10531  Show or hide the standard toolbar
      10532  Show or hide the camera toolbar
      10533  Display Shadow Information
      10534  Show or hide the scene tabs
      10535  Display the next scene
      10536  Display the previous scene
      10537  Show or hide the standard views toolbar
      10538  Display Model Info Display Properties
      10539  Display the sketch in shaded mode with textures
      10540  The OpenGL changes will not take effect until SketchUp is restarted.
      10541  SketchUp has checked your computer for compatibility with Fast
      10542  View
      10545  Toggle Shadow Display On or Off
      10546  Show or hide the shadow toolbar
      10547  Shadows
      10548  WARNING; SketchUp has detected that you are using a 16 bit Windows display setting.
      10549  WARNING; Your OpenGL Properties settings have been reset to
      10550  SketchUp Models (*.skp)|*.skp|All Files (*.*)|*.*||"
      10551  Toggle between large and small toolbar buttons.
      10552  Show an animation of all scenes.
      10553  Pause
      10554  Play
      10555  Invalid length entered.
      10556  Invalid angle entered.
      10557  Stop
      10558  Unicode
      10559  %I;%M %p
      10560  Arial
      10561  J,F,M,A,M,J,J,A,S,O,N,D
      10562  Tahoma
      10563  Preferences
      10564  Print Preview
      10565  Not on the list
      10566  Printer '%s' does not support required functions.
      10567  This choice is for specific video cards which have a face selection problem.
      10576  Show or hide the display style toolbar
      10579  File Properties
      10580  Show or hide the display settings
      10585  Drag mouse or enter field of view.
      10586  The walk tool is only active
      10590  Change model location
      10593  Monochrome
      10596  X-ray Mode
      10597  Wireframe
      10598  Hidden Line
      10599  Shaded
      10600  Shaded With Textures
      10601  Monochrome
      10602  Shadows
      10603  Profile Edges
      10604  Extended Edges
      10605  Jitter Edges
      10617  Google Toolbar
      10629  Restore next viewing orientation
      19000  Importing Layers ...
      19001  Importing Blocks ...
      19002  Importing Entities ...
      19003  Merging Entities ...
      19004  Import Finished
      19005  Importing Block %1 ...
      19006  Merging Entities in Block %1 ...
      19007  Exporting Extents ...
      19008  Exporting Named Views ...
      19009  Exporting Layers ...
      19010  Exporting Components ...
      19011  Exporting Entities ...
      19012  Export Finished
      19013  Model too far from the Origin
      20000  In Model
      20003  Did you know...
      20004  There are no tips to display.
      20007  Page Properties
      20008  Macro
      20009  OK
      20010  Show Details...
      20011  Don't Panic!
      20014  Everything's OK now.
      20015  Always fix my models
      20016  Fix later
      20017  Fix now
      20018  Your model has been checked carefully, and all problems have been fixed.
      20019  Non-default material found for %s
      20020  Non-default layer found for %s
      20021  Intersection
      20022  Endpoint
      20023  Midpoint
      20024  On Edge
      20025  On Axis
      20026  On Face
      20027  From Point
      20028  On Line
      20029  Parallel to Edge
      20030  Perpendicular to Edge
      20031  Guide Point
      20033  &Exit
      20034  adjacent face has holes
      20035  Illegal offset string
      20036  Cannot move face - face touching at corner must be a triangle.
      20037  Undo
      20038  Redo
      20039  Draw Line
      20041  Erase
      20042  Push/Pull
      20043  Cut
      20044  Paste
      20045  Move
      20046  Guide
      20047  Move Axes
      20048  Set Length
      20049  Polyline
      20050  Reset Axes
      20051  Hide
      20052  Unhide
      20053  Reverse Face
      20054  A zero length offset is not allowed
      20055  Component
      20056  Explode
      20057  Create Face
      20059  Back
      20060  Forward
      20061  Home
      20062  Refresh
      20063  Browse
      20066  Create Arc
      20071  Length
      20072  Radius
      20074  Length of last edge cannot be changed
      20075  Rejecting zero length segment
      20076  Assign Material
      20077  Select bulge distance or enter value.
      20078  Bulge
      20079  Half Circle
      20081  Purge
      20082  Reload
      20085  Fillet Radius
      20086  Add Material
      20087  Properties
      20089  Edit Material
      20090  Delete Material
      20091  Paint
      20092  Make Component
      20093  In Model
      20094  Load Component
      20095  Text
      20096  Copy
      20097  Stretch would result in non-planar face
      20098  Rectangle
      20099  Polygon
      20100  Circle
      20101  Select center point
      20102  Select point on edge
      20103  Select start point
      20104  Select end point or enter value.
      20105  Select first corner.
      20106  Select opposite corner or enter value.
      20108  Dimensions
      20109  Set Rectangle Dimensions
      20110  Unable to initialize OpenDWG Toolkit
      20111  The file adinit.dat was not found.
      20112  Angle
      20113  %1 has been modified outside of SketchUp!
      20114  Offset
      20115  Cannot change width
      20116  Cannot change height
      20117  Cannot set a dimension to zero
      20118  Set Angle
      20119  Export Options
      20120  Drawing
      20121  Import
      20123  Check Validity
      20124  Merge
      20126  Origin
      20127  Red Axis
      20128  Green Axis
      20129  Blue Axis
      20130  Distance
      20131  Select fillet radius or enter value
      20133  Explode Curves
      20134  Explode Curves
      20135  Reset Insert Point
      20136  Scale Model
      20137  Do you want to resize the %1?
      20138  Press Left Mouse Button and Drag to Draw
      20139  Pick face to push or pull.  Ctrl = toggle create new starting face.
      20140  Drag to push or pull face or enter value.  Ctrl = toggle create new starting face.
      20141  Select point or edge to measure from.  Ctrl = toggle create guides.
      20142  Select point to measure to or enter value.  Ctrl = toggle create guides.
      20143  Select items to erase or drag across multiple items. Shift=Hide, Ctrl=Soften/Smooth
      20144  adjacent face has non-parallel edge
      20145  Rotate
      20146  Layers
      20147  You can not hide the current layer.
      20148  Invalid Layer Name.
      20149  Invalid Layer Name.
      20150  Layers
      20154  Set current layer
      20155  Change layer of selected geometry
      20156  Convert curve to polygon
      20157  Download Failed!
      20159  The component name must be unique.
      20160  Edge
      20161  Face
      20162  Component
      20163  Component Definition
      20164  Guide
      20165  Guide Point
      20166  3d Polyline
      20167  No Internet connection available!
      20168  Cannot Push/Pull curved or smoothed surfaces
      20169  Properties
      20170  Internet file (no local copy)
      20171  Internet file (cached locally)
      20172  Local file
      20173  Never
      20174  File not found or invalid
      20175  Pick point for origin of axes.
      20176  Pick point for red axis.
      20177  Pick point for green axis.
      20178  Select objects. Shift to extend select. Drag mouse to select multiple.
      20179  Use Select tool, or pick one thing to move/rotate.
      20180  Pick rotation plane and origin.  Ctrl = toggle Copy, hold Shift = align to face.
      20181  Align bottom of protractor.  Ctrl = toggle Copy.
      20182  Pick rotation angle or enter value.  Stay close to protractor for snapping, Ctrl = toggle Copy.
      20183  You must select objects to rotate!
      20184  Pick entity, rotation plane and origin.  Ctrl = toggle Copy, hold Shift = Align to face.
      20188  Place center of protractor. Ctrl = toggle create guides, hold Shift = align to face.
      20189  Align bottom of protractor.  Ctrl = toggle create guides.
      20190  Define guide angle.  Ctrl = toggle create guides.
      20191  Pick point from which offset will be measured.
      20192  Pick point to define offset or enter value.
      20193  You must first select a single face or
      20194  Select face or edges to offset.
      20195  (Never saved)
      20196  (Unassigned)
      20197  Download Cancelled
      20198  Download Failed
      20199  Close
      20200  Define guide angle.  Option = toggle create guides.
      20201  (Internal Component)
      20202  Place center of protractor. Option = toggle create guides, hold Shift = align to face.
      20203  Align bottom of protractor.  Option = toggle create guides.
      20204  Pick rotation angle or enter value.  Stay close to protractor for snapping, Option = toggle Copy.
      20205  Pick rotation plane and origin.  Option = toggle Copy, hold Shift = align to face.
      20206  A component with that name already exists
      20207  A component with that name already exists.
      20208  <-- Choose Material
      20209  Pick entity, rotation plane and origin.  Option = toggle Copy, hold Shift = Align to face.
      20210  Align bottom of protractor.  Option = toggle Copy.
      20211  Place component.
      20212  Place clipboard contents.
      20213  Select point to measure to or enter value.  Option = toggle create guides.
      20214  The file this %1 was last loaded
      20215  The file this %1 was last loaded
      20216  The %s file has not changed.
      20217  Select point or edge to measure from.  Option = toggle create guides.
      20218  Place copied elements or enter value.
      20219  Can not place component!
      20220  Some of the geometry that you added
      20221  Nothing selected. Use select tool
      20222  Cannot move selected objects!
      20223  Use Select tool, or pick one thing to move/rotate
      20224  Pick two points to move.  Ctrl = toggle Copy, Alt = toggle Auto-fold, hold Shift = lock inference
      20225  Pick two points to rotate.
      20249  Tangent to Edge
      20250  Downloaded; %1 Kb of %2 Kb
      20251  Set Insert Point
      20252  Edges
      20253  Faces
      20254  Component Definitions
      20255  Component Instances
      20256  Guides
      20257  Guide Points
      20258  Layers
      20259  Materials
      20260  Name
      20261  Count
      20262  Arc
      20263  Name
      20264  Visible
      20265  Color
      20266  Layer
      20267  Invalid Image File
      20269  Pattern
      20270  Invalid Name.  Material name must be unique.
      20271  Export Failed.
      20272  Material Libraries (*.skm)|*.skm||
      20273  File read error; Abort/Retry?
      20274  critical error; disk full
      20275  critical error; write abort
      20276  "critical error %1!d!, aderror %2!d! (%3!s!), terminating"
      20277  Tangent at vertex
      20278  Error; WriteBlockInstance
      20279  This should never happen - contact Google, please
      20280  You must first select a single face and
      20281  The specified radius is too small
      20282  Extrude
      20283  Encapsulated Postscript (EPS) Hidden Line Options
      20284  Select object to paint
      20285  Select object to match paint from
      20286  Architectural
      20287  Engineering
      20288  Decimal
      20289  Fractional
      20290  Invalid Snap Length!
      20293  Offset
      20294  Offset limited to
      20295  Beta version %1 is expired.
      20296  Your evaluation license for Google SketchUp Pro has expired.
      20297  SketchUp currently requires Internet Explorer
      20298  %2.2lf Hours
      20299  %d Minutes
      20300  Not Licensed - Expired
      20307  Version;
      20308  Assertion failed in File; %s at Line %d
      20310  The model name or path is not valid.
      20311  The auto saved version of this file is newer than the file.
      20312  Could not open component file!
      20313  Unable to make component
      20314  AutoCAD 2000 DWG|*.dwg|AutoCAD 2000 DXF|*.dxf|AutoCAD R14 DWG|*.dwg|AutoCAD R14 DXF|*.dxf|3D Studio (*.3ds)|*.3ds||
      20315  Error opening DWG file
      20316  Error writing DWG file
      20317  JPG Document|*.jpg|BMP Document|*.bmp|TIF Document|*.tif|PNG Document|*.png|Epix Document|*.epx||
      20318  Failed to save file "%s"
      20319  All Supported|*.dwg;*.dxf|AutoCAD DWG|*.dwg|AutoCAD DXF|*.dxf||
      20320  File Properties
      20321  Component Creation Cancelled!
      20322  You must select something which can be exploded/ungrouped.
      20323  Bad Entities were found that could not be fixed
      20324  Do you want to resize the %1?
      20325  Serial number is not valid
      20326  Serial Number = %1
      20327  Evaluation; time remaining = %1
      20328  %1 hours
      20329  %1 minutes
      20330  1 Hour
      20331  Evaluation time set to %1
      20332  Failed to load file %s.
      20333  Failed to save file.
      20335  You have %1 remaining in the evaluation.
      20340  For Evaluation Use Only
      20342  Sides
      20343  Drawing size limited to 100 inches (254 cm)
      20344  Cannot extrude curved face
      20346  Extrude path is not continuous
      20352  Export Raster Image
      20353  Untitled
      20354  Export Model
      20355  Export
      20356  Export &type;
      20357  Import
      20358  Validity Check
      20360  %s is currently used by %s.
      20361  View/Rendering/
      20362  No problems found.
      20363  The curve radius for %s is not valid
      20364  The plane equation for %s not valid.
      20365  Rendering
      20367  AutoCAD Entities Imported;
      20368  	Layers;		%1!d!
      20369  	Blocks;		%1!d!
      20370  	3d Faces;		%1!d!
      20371  	Arcs;		%1!d!
      20372  	Circles;		%1!d!
      20373  	Ellipses;		%1!d!
      20374  	Inserts;		%1!d!
      20375  	Lines;		%1!d!
      20376  	Points;		%1!d!
      20377  	2d Poly-lines;	%1!d!
      20378  	3d Poly-lines;	%1!d!
      20379  	3d Poly-Meshes;	%1!d!
      20380  	Poly-Face Meshes;	%1!d!
      20381  	Rays;		%1!d!
      20382  	2d Solids;		%1!d!
      20383  	Traces;		%1!d!
      20384  	X-Lines;		%1!d!
      20385  	Variable widths on poly-lines;	%1!d!
      20386  	Degenerate faces;	%1!d!
      20387  	Splines;		%1!d!
      20388  	M-Lines;		%1!d!
      20389  	Shapes;		%1!d!
      20390  	3d Solids;		%1!d!
      20391  	Bodies;		%1!d!
      20392  	Regions;		%1!d!
      20393
      20394  	AttDefs;		%1!d!
      20395  	Attributes;		%1!d!
      20396  	Dimensions;	%1!d!
      20397  	Hatches;		%1!d!
      20398  	Images;		%1!d!
      20399  	Leaders;		%1!d!
      20400  	M-Texts;		%1!d!
      20401  	Ole Frames;	%1!d!
      20402  	Texts;		%1!d!
      20403  	Tolerances;	%1!d!
      20404  	Viewports;	%1!d!
      20405  	X-Refs;		%1!d!
      20406  	Anonymous Blocks;	%1!d!
      20407  	Purged Blocks;	%1!d!
      20408  	Zombies and Others; %1!d!
      20409
      20410  	Variable Width Poly-Lines; %1!d!
      20411  	Degenerate Faces;	%1!d!
      20412  	Fit Poly-Lines;	%1!d!
      20413  	Fit Poly-Meshes;	%1!d!
      20414  	Coords out of range	%1!d!
      20415  Image Width must be greater than 0.
      20416  Image Height must be greater than 0.
      20417  Scale
      20418  Unhide
      20420  	Anonymous Block Inserts;  %1!d!
      20421  Are you sure you want to cancel the import?
      20423  	Empty Blocks;	%1!d!
      20424  	Empty Block Inserts; %1!d!
      20425  Select North Reference Point
      20426  Select North Direction.
      20429  Merge faces
      20430  Orient Faces
      20432  Do you want to revert back to the saved version of %1?
      20433  Constrained
      20434  Line
      20435  Plane
      20436  Constrained on %1
      20437  Intersect Line
      20438  Intersect Plane
      20439  from Point
      20440  Select the camera position.
      20441  Select a point that the camera is aimed at.
      20442  Evaluation; Valid through %1
      20443  Evaluation date set to %1.
      20444  Evaluation ends %1
      20445  %B %d, %Y
      20446  All Supported Image Types|*.bmp;*.jpg;*.png;*.psd;*.tif;*.tga|JPEG Image (*.jpg)|*.jpg|Portable Network Graphics (*.png)|*.png|Photoshop (*.psd)|*.psd|Tagged Image File (*.tif)|*.tif|Targa File (*.tga)|*.tga|Windows Bitmap (*.bmp)|*.bmp||
      20449  Hidden line
      20450  Import &type;
      20451  Merging coplanar faces
      20452  Height Offset
      20453  Select a face.  All faces in the model with matching paint will change.
      20454  Select a face.  All connected faces with matching paint will change.
      20455  Select a face.  All faces on the same object with matching paint will change.
      20456  Add Scene
      20457  Scene Properties
      20458  Update Scene
      20459  Move Scene
      20460  Square
      20461  Scene #
      20464  Component
      20465  Layer0
      20466  %s is a reserved layer name.
      20467  Cannot rename the default layer!
      20468  Authorize
      20469  Need to authorize before; %1
      20470  Authorization Number (if available);
      20471  The Authorization Number does not match the Registered
      20473  Registered To;
      20474  Unable to find "SketchUp6.lf" License File.
      20476  Export 2D Graphic
      20479  Authorization aborted.
      20482  Authorization aborted.
      20483  The UNC conversion for the selected path failed.  Either the path is not shared or the automatic conversion code failed.  Please type the path in UNC format into the folder edit field.
      20484  A valid UNC formatted folder path must be entered.
      20485  Your network license has been lost and cannot be reconnected.  Would you like to save your work before exiting?
      20486  Unable to find specified directory path.
      20487  Your network license has been lost and cannot be reconnected.  SketchUp will exit now.
      20488  USA
      20489  Boulder (CO)
      20491  Material
      20492  Edge is on hidden layer; '%s'
      20495  Paint
      20496  Sample Paint
      20497  Paint Bucket
      20498  Default
      20499  File is Read-Only.
      20500  	Self-referencing Blocks;	%1!d!
      20502  Radius is too small.
      20503  Flip
      20504  Divide Edge
      20505  Mix New Material To Paint With
      20506  Edit Material
      20507  Radius too large
      20508  Array
      20510  In Model
      20512  Add mixed material to the model
      20513  Undo Color Changes
      20514  Match Color of object in model
      20515  Match Color from collection sample
      20516  Reset color to original image color
      20517  Browse for Material Image File
      20518  Lock/Unlock Aspect Ratio
      20519  Undo width/height changes
      20520  Red Value
      20521  Green Value
      20522  Blue Value
      20523  Hue Value
      20524  Saturation Value
      20525  Lightness  Value
      20526  	Proxy Objects;	%1!d!
      20527  Material Names may not start with '*'
      20528  Material image file not found.
      20529  Find Image File
      20530  Invalid Material Collection Path
      20531  Choose Image
      20532  Material Browser Collection has been modified.  Save it?
      20533  Change Axes
      20534  Reset Scale
      20535  Unglue
      20536  Close
      20538  Open
      20539  Models
      20540  Components
      20541  Material Libraries
      20542  File Type
      20543  Location
      20544  Texture Images
      20545  Raster Images
      20546  Import/Export Models
      20547  Styles
      20549  Unable to load image file '%s'.
      20550  H
      20551  S
      20552  L
      20553  R
      20554  G
      20555  B
      20556  Force all texture colors to the same Hue
      20557  Choose material from model to edit.
      20558  Choose material from model to create new material from.
      20559  Edge is used by a Face that is on hidden Layer '%s'
      20560  AutoSave_
      20561  An auto saved file; '%s' exists.
      20562  Distance
      20563  You cannot hide the Current layer.
      20565  Edit
      20566  Make New
      20567  Import Preferences
      20568  Export Preferences
      20569  SketchUp Data Files (*.dat)|*.dat||
      20570  Unable to save to read-only file.
      20571  Backspace
      20572  Tab
      20573  Clear
      20574  Space
      20575  PageUp
      20576  PageDown
      20577  End
      20578  Left
      20579  Right
      20580  Down
      20581  Insert
      20582  Delete
      20583  Home
      20584  NumPad0
      20585  NumPad1
      20586  NumPad2
      20587  NumPad3
      20588  NumPad4
      20589  NumPad5
      20590  NumPad6
      20591  NumPad7
      20592  NumPad8
      20593  NumPad9
      20594  NumPad*
      20595  NumPad+
      20596  NumPad-
      20597  NumPad.
      20598  NumPad/
      20599  F1
      20600  F2
      20601  F3
      20602  F4
      20603  F5
      20604  F6
      20605  F7
      20606  F8
      20607  F9
      20608  F10
      20609  F11
      20610  F12
      20611  F13
      20612  F14
      20613  F15
      20614  F16
      20615  F17
      20616  F18
      20617  F19
      20618  F20
      20619  F21
      20620  F22
      20621  F23
      20622  F24
      20623  Ctrl
      20624  Alt
      20625  Shift
      20626  Up
      20627  Radius
      20628  Select or enter number of segments
      20629  Segments
      20630  %d segments
      20631  Opacity
      20632  Length; %s
      20633  You are currently in Color by Layer mode.
      20634  Choose Watermark
      20635  Brightness
      20636  B
      20637  Center
      20638  Results of non-planar check.
      20639  Select object to attach text to or position on screen.
      20640  Position Text.
      20641  Enter text string.
      20642  Text
      20643  Edit
      20644  Default Text Font
      20645  Bold
      20646  Italic
      20647  Point
      20648  Text Style
      20649  Dimension Style
      20650  Select new directory
      20651  Select components directory.
      20652  Invalide Latitude Value
      20653  Invalid Longitude Value
      20654  You have opened an auto-saved file (%s).  Examine the file and if you would like to use this file in place of (%s), save it right away.
      20656  Unable to export the size requested.  Using the view size instead.
      20657  Error initializing DWGDirect libraries
      20658  Error opening AutoCAD import file
      20659  No Selection
      20660  Bad Selection
      20661  Curve
      20662  Surface
      20663  %d Entities
      20664  Unglue
      20665  Reset Scale
      20666  Reset Skew
      20667  Soften/Smooth Edges
      20668  Flip Along
      20669  %s Red
      20670  %s Green
      20671  %s Blue
      20672  Explode
      20673  Edit Component
      20674  Edit (Just This One)
      20675  Reload
      20676  Replace
      20677  Save As
      20678  Change Axes
      20679  Scale Definition
      20680  Properties (&All Like This)
      20681  This does not appear to be a valid AutoCAD DWG or DXF file
      20682  Reveal in Browser
      20683  E&dit Text
      20684  Type
      20685  Horizontal
      20686  Vertical
      20687  Aligned
      20688  Radius
      20689  Diameter
      20690  Arrow
      20691  &None
      20692  &Dot
      20693  &Closed
      20694  &Open
      20695  Leader
      20696  &View Based
      20697  &Pushpin
      20698  &Hidden
      20699  Soften
      20700  &Divide
      20701  E&xplode Curve
      20702  Convert to Polygon
      20703  &Area
      20704  &Selection
      20705  &Layer
      20706  &Material
      20707  Intersect with Model
      20708  Align &View
      20709  Align A&xes
      20710  &Reverse
      20711  &Orient Faces
      20712  Position
      20713  Reset Position
      20714  Edit &Group
      20715  Explode
      20716  Make &Component
      20717  Parent for %s is NULL
      20718  Export
      20719  Use As Material
      20720  &Properties
      20721  Entity &Info
      20722  &Erase
      20723  &Hide
      20724  Shadows
      20725  Cast
      20726  Receive
      20727  Zoom Extents
      20728  Select
      20729  Bounding Edges
      20730  Connected Faces
      20731  All Connected
      20732  All on same Layer
      20733  All with same Material
      20734  Active Cut
      20735  Create &Group from Slice
      20736  This material is being used.  Replace its use with the default material?
      20737  <no template>
      20738  Browse for Template
      20739  Guides
      20740  Reverse Faces
      20741  Red Direction
      20742  Green Direction
      20743  Blue Direction
      20744  Make &Group
      20745  Close Component
      20746  &Place
      20747  &Move
      20748  &Reset
      20749  Close Group
      20750  Component Browser
      20751  Position Texture
      20752  Reset Texture Position
      20753  Project Texture
      20754  Drag pins to position texture.  Click=Lift pin, Shift=Toggle Fixed, Ctrl=No snapping
      20755  Click to finish.
      20756  Click to lift pin.
      20757  Drag pin to move texture.
      20758  Drag pin to scale/rotate texture.
      20759  Drag pin to scale/shear texture.
      20760  Drag pin to distort texture.
      20761  Drag to move texture.
      20762  Place pin and drag to move texture.
      20763  Place pin and drag to scale/rotate texture.
      20764  Place pin and drag to scale/shear texture.
      20765  Place pin and drag to distort texture.
      20766  Done
      20767  Reset
      20768  Delete Pin
      20769  Flip
      20770  Left/Right
      20771  Up/Down
      20772  Rotate
      20773  Fixed Pins
      20774  Initial Pins
      20775  Pin Location
      20776  Best Tile
      20777  Face Bounds
      20778  Texture
      20779  Projected
      20780  Finish positioning texture.
      20781  Reset texture to default position.
      20782  Toggle texture projected state.
      20783  Delete texture pin.
      20784  Flip texture left/right.
      20785  Flip texture up/down.
      20786  Toggle whether pins have fixed meaning by default.
      20787  Rotate texture 90 degrees counter clockwise.
      20788  Rotate texture 180 degrees counter clockwise.
      20789  Rotate texture 270 degrees counter clockwise.
      20790  General
      20791  Files
      20792  Drawing
      20793  OpenGL
      20794  Shortcuts
      20795  Component's Red
      20796  Component's Green
      20797  Component's Blue
      20798  Group's Red
      20799  Group's Green
      20800  Group's Blue
      20801  Template
      20802  Golden Section
      20803  %d Instances
      20804  1 Instance
      20805  Definition
      20806  Statistics
      20807  %d Faces
      20808  %d Edges
      20809  %d Arcs
      20810  %d Curves
      20811  Linear Dimension
      20812  Radial Dimension
      20813  %d Text
      20814  %d Linear Dimensions
      20815  %d Radial Dimensions
      20816  %d Images
      20817  %d Groups
      20818  %d Components
      20819  %d Guides
      20820  %d Guide Points
      20821  %d Section Planes
      20822  %d 3d Polylines
      20823  Circle
      20824  Polygon
      20825  You are about to unauthorize the use of this copy of Google SketchUp. You will not be able to run this copy of Google SketchUp again without authorizing the product with a valid license. Are you sure you want to do this?
      20826  Load this directly into your Google SketchUp model?
      20827  Load Into Model?
      20828   (All Locked)
      20829  Parent for %s is different than edge parent
      20830  The connectivity for %s is bad
      20831  The reference count for %s is incorrect
      20832  The start or end vertex for %s is not valid
      20833   (%d Locked)
      20834  The plane equation for %s is invalid - fixed
      20835  Non planar %s split into %d faces and %d edges
      20836  The entity %s was not found in %s
      20837  Your license for Google SketchUp Pro has expired.
      20838  The material for %s is not valid
      20839  %d Dimensions
      20840  One of the vertices for %s is NULL
      20841  The start and end vertices are identical for %s
      20842  %s is not referenced by %s
      20843  Dimension Properties
      20844  The edge use (%s) for %s is not valid
      20845  %s has no Loops
      20846  The outer loop for %s is not valid
      20847  %s does not refernce %s
      20848  This does not appear to be a valid AutoCAD DWG or DXF file
      20849  Loop Orientation is wrong
      20851  %s for %s has a bad first EdgeUse
      20852  %s for %s has too few edges
      20853  %s for %s has too many edges
      20854  	 This probably indicates a cycle within the list
      20855  Edges are not connected in %s for %s
      20856  The plane equation for %s is not valid
      20858  %s for %s has bad EdgeUse (%s)
      20859  Edge parent for %s does not match Face parent in %s
      20860  %s for %s is not closed
      20861  %s for %s has zero area
      20862  %s for %s is oriented wrong
      20864  zero length edge (%s) removed from %s
      20865  Repeated edge (%s) removed from %s
      20867  %s references %s that does not use it
      20868  %s references %s more than once
      20869  Vertex %d is used by edges with different parents
      20870  Error Loading File %s
      20871  Make Unique
      20872  Make each selected set of like instances reference a new, unique definition.
      20873  Key cannot be used as shortcut.
      20874  Rename
      20875  Expand All
      20876  Collapse All
      20877  Sort by Name
      20878  Do you want to delete %s?
      20879  Model
      20880  Intersect with Context
      20881  Intersect Selected
      20882  You must save your SketchUp model before sending it to LayOut.
      20883  Cannot launch LayOut.
      20923  0%
      20924  100%
      20926  infinity
      21011  Orbit the Camera
      21012  Test tool
      21013  Place Component
      21014  Line
      21016  Zoom
      21017  Sketch
      21019  Erase
      21020  Draw straight lines
      21021  Erase the selected geometry
      21022  Selection Tool
      21023  Test
      21024  Measure distances and create guides
      21025  Convert Curves to Polygons
      21026  Paste
      21030  Do Freehand drawing
      21031  Do freehand drawing
      21032  Show the properties dialog for the selected object
      21033  Align the view with the selected face
      21034  Move the selected Sketch context
      21035  Align view
      21036  Reset the sketch axis to its original orientation
      21037  Hide the sketch axes
      21040  Dump selected objects to debug window
      21041  Push/Pull
      21042  Reverse the orientation of the selected faces
      21043  Erase all guides
      21044  Erase all guides
      21045  Test DWG
      21046  Export in a different format
      21047  Dump model
      21048  Move/Copy the selected objects
      21049  Connect to a NetMeeting conference
      21050  Start or connect to a NetMeeting conference
      21051  Exit a conference
      21052  Hide selected geometry
      21053  Unhide all hidden geometry
      21054  Redline
      21055  Create redlines
      21056  Create a face from the selected edges
      21057  Measure angles and create guides.
      21058  Explode the group or component into its constituent objects.
      21059  Set the location of the project
      21060  Show or hide the component browser
      21061  Show or hide the drawing toolbar
      21062  Set the date and time.
      21063  Show Bounds
      21064  Move/Rotate Components
      21065  Draw arcs
      21066  Move
      21067  Add a new scene
      21068  Update the current scene
      21072  Texture the selected face
      21073  Assign Material to this Face
      21074  Paint
      21076  Show the properties dialog for the selected model
      21078  Delete the current scene
      21080  Show Scene Info
      21081  Reload the selected component definition.
      21082  Test Macros
      21083  Make a component from the selection set
      21086  Purge unused components
      21087  Reload all components from original file
      21088  Purge the selected component
      21089  Save Component to a file
      21090  Toggle the display of the conference dialog on or off
      21091  Text\Text
      21092  Set Default Font
      21094  Draw a rectangle from its two opposite corners
      21095  Draw N-sided polygons
      21096  Draw Circles
      21098  Insert a component
      21099  Unhide the last geometry hidden
      21100  Offset a face or selected edges
      21101  Select all visible objects
      21102  Clear the selection set
      21103  Dump view
      21104  Align the sketch axes with the selected face
      21105  Hide all guides
      21106  Reverse the normal of all selected faces
      21108  Set Material to Paint with to Default
      21109  Unhide guides
      21110  Reload bar state
      21111  Explode/Ungroup selected objects
      21112  Import / Insert a DWG or DXF drawing
      21113  Align the view with the sketch axes
      21114  Export model as an AutoCAD or 3D Studio File.
      21117  Record a Journal File
      21118  Playback a Journal File
      21119  Save a Journal Configuration File
      21120  Restore a Journal Configuration File
      21122  Remove any unused materials from the model
      21123  Properties for all components like this one.
      21124  Check the validity of the model and fix it if possible
      21125  Do Merge
      21126  Reposition the sketch coordinate system
      21127  Reset Insert Point
      21129  Rotate
      21130  Add/Remove/Edit layers
      21131  Set Current layer or change layer of selected geometry
      21132  Show or hide the layer toolbar
      21133  Display the sketch using color by layer
      21134  Toggle Journal Menu
      21135  Toggle Debug Menu
      21136  Save a copy of the active document
      21137  Go to the SketchUp web page
      21138  Select a face and highlight its edges
      21139  Test the input point finder
      21140  Test Picking
      21141  Show the window coordinates at the cursor
      21142  Test the geometry finder
      21144  Do timing tests on the display
      21145  Time picking performance
      21146  Time display performance
      21147  Test picking performance
      21148  Explode polyline
      21149  Export Model
      21150  Customize the keyboard shortcuts
      21152  Unhide selected geometry
      21154  Toggle the display of hidden geometry on or off
      21155  Test Feedback Manager
      21157  Run sample demo scripts
      21158  Hide or unhide selected objects
      21163  Enable/disable automatic merging of coplanar faces
      21164  Enable/disable consistent face orientation
      21166  Merge all coplanar faces in the current model.
      21167  Orient all faces in the current model so that adjacent faces have the same sense.
      21168  Orient adjacent faces consistently
      21169  Set the camera position and direction
      21170  Show the Animation Settings dialog.
      21171  Show/Hide nested components
      21172  Merge all coplanar faces in this model
      21174  Generate Hidden Line drawing
      21176  Delete Scene
      21177  Move selected scene right
      21178  Move selected scene left
      21179  Update the selected scene
      21180  Add a new scene after the selected scene
      21181  Start an animation with the selected scene
      21182  Create a group from the selected geometry
      21183  Group
      21184  Group
      21185  Components/Groups
      21186  Groups
      21187  3d Polylines
      21188   Outside Active
      21192  in Component
      21193  in Group
      21194  in Image
      21195  Image
      21196  Images
      21197  Intersect
      21199  Reload the selected image.
      21200  Insert an image from a file.
      21201  Edit the selected group.
      21202  Stop editing the active group or component.
      21203  Width;
      21204  Height;
      21205  Pick the first corner of the image.
      21206  Pick the opposite corner of the image.
      21207  The selected object should cast shadows.
      21208  The selected object should receive shadows.
      21214  Intersect selected faces
      21215  Unite selected faces
      21216  Remove face 2 from face 1
      21219  Map Overlay
      21220  View written tutorials in the help file.
      21224  Show or hide the material browser
      21225  Face body intersection test
      21226  Import 2D Graphic
      21227  Image file invalid!
      21228  Reload Image
      21229  Cast Shadows
      21230  Receive Shadows
      21231  image
      21232  component
      21233  Compute the area of the selected face(s)
      21234  Compute the area of all faces on the same layer
      21235  Compute the area of everything with the same material
      21236  Scale
      21237  Export 2D Graphic
      21239  You must select objects to scale!
      21240  The objects you have selected cannot be scaled.
      21241  Select objects to scale.  Escape or Return when done.
      21242  Select a grip and move it to scale the objects. Ctrl = About Center. Shift = Toggle Uniform.
      21243  Show/Hide image components
      21244  Show/Hide group components
      21246  Edit Selected Material
      21247  Insert New Material Into Collection
      21248  Insert New Material Into Collection
      21251  Reset the sketch axis to the active component axis.
      21252  Unglue the group or component from the object it is attached to.
      21254  Make the selected component unique before editing it.
      21256  Copy Material
      21257  Delete Material
      21258  Open Collection
      21259  Clear Collection
      21260  Save Collection
      21261  Save Collection As
      21262  Purge Unused Materials
      21263  Merge Collection
      21267  Reset the scale of the selected group or component.
      21268  set the skew of the selected group or component.
      21271  Add this material to the model
      21274  Flip along the red direction
      21275  Flip along the green direction
      21276  Flip along the blue direction
      21277  Change the axes for the selected component.
      21278  model
      21279  active group or component
      21280  Apply the component scale to the definition
      21281    Enter value to resize %1.
      21282  Fix Unique ID
      21284  Edit the selected component (and all its copies).
      21285  Make a component from the selected group.
      21286  Least squares test
      21287  Divide selected edge into N segments
      21288  Create Material
      21289  Cannot find help file!
      21290  Cannot hide layer the active group or component is on.
      21291  Cannot put active component on a hidden layer!
      21292  The component has been edited.
      21293  Invalid image dimensions!
      21294  Place image. Ctrl=By Center.
      21295   Shift=Uniform.
      21296  Pick first point of image. Dbl Click=Drop.
      21297  Pick second point of image.
      21298   Ctrl=By Center.
      21299   Shift=Uniform.
      21300   Shift=Non-Uniform.
      21301  Scale
      21302  Red Scale
      21303  Green Scale
      21304  Blue Scale
      21305  Red,Green Scale
      21306  Red,Blue Scale
      21307  Green,Blue Scale
      21308  Red,Green,Blue Scale
      21309  Invalid Scale!
      21310  Uniform Scale
      21311  Non-Uniform Scale
      21312   about Center
      21313   about Opposite Point
      21314  Select a grip and move it to scale.
      21315  Hide Soft Edges
      21316  Select a single face and a simple connected path of edges
      21318  Scale Definition
      21319  Display Large Thumbnails
      21320  Reset Skew
      21321  Display Medium Thumbnails
      21322  Display Small Thumbnails
      21323  Toggle Utilities menu
      21324  Show the coordinates of points in the model
      21325  Display In Collection Image Size
      21326  View/Component Edit/
      21327  Hide Rest of Model
      21328  Hide Similar Components
      21329  Compute the area of everything with the same material
      21330  Export Google SketchUp Preferences
      21332  Select entity to scale
      21333  Import Google SketchUp Preferences
      21334  Reverse the selected section
      21335  Activate cutting for the selected section.
      21336  Align the view with the selected section
      21337  Place a section plane
      21338  Section Planes
      21339  The selected component has a non-default scale.
      21340  Section
      21341  Reverse Section
      21342  Place section plane on face.  Shift = Lock to plane.
      21343  Activate Section
      21344  Deactivate all sections.
      21345  Hide all sections.
      21346  Show all sections.
      21347  Toggle section plane display on and off
      21348  Toggle section cuts on and off
      21349  On Section
      21350  The file "%s" is currently locked by another user
      21351  The file %s was opened as Read-Only.  It cannot be saved
      21352  Create a group from the geometry on the current section
      21355  Hide Soft Edges
      21357  Export Image
      21358  Replace Material with Another In the Model
      21359  Export the active section slice.
      21360  Debug; Purge all materials even if they are being used.
      21365  Import / Insert a DWG or DXF drawing
      21367  %.2lfKB (%d Bytes)
      21368  Average Soft Normals
      21369  Cannot create a recursively defined model or component!
      21370  An older version of that file was already
      21371  Cannot place component there!
      21372  Section Plane
      21373  JPEG Image (*.jpg)|*.jpg|Portable Network Graphics (*.png)|*.png|Tagged Image File (*.tif)|*.tif|Windows Bitmap (*.bmp)|*.bmp||
      21374  Export failed! Your model contains too many faces
      21375  The following texture files could not be converted to
      21376  PDF Error initializing exporter
      21377  PDF Error opening file for export
      21378  PDF Error writing export file
      21379  Soften Edges
      21380  Unsoften Edges
      21381  EPS Error initializing exporter
      21382  Soften selected edge.
      21383  Soften/Smooth selected edges
      21384  Unsoften selected edges
      21385  Unsoften
      21386  Export the animation as an avi or series of images
      21387  Full Frames (Uncompressed)
      21388  Avi File (*.avi)|*.avi||
      21389  Sort Materials
      21390  Unable to create avi file.
      21391  Unable to initialize compressor.
      21392  Failed to write avi file.
      21393  The codec is incompatible with the video size you selected!
      21394  Frame; %1!d! of %2!d!
      21395  Sort Collection By Name
      21396  Delete incomplete AVI file?
      21397  Export Animation
      21398  JPEG Images (*.jpg)|*.jpg|Portable Network Graphics (*.png)|*.png|Tagged Image Files (*.tif)|*.tif|Windows Bitmaps (*.bmp)|*.bmp|
      21399  Animation export failed!
      21400  Delete image files created?
      21401  EPS Error opening file for export
      21402  Soften
      21403  EPS Error writing export file
      21404  Drawing
      21405  Create Text
      21406  Fog
      21407  Change Dimension type to Horizontal
      21408  Change Dimension type to Vertical
      21409  Change Dimension type to Aligned
      21410  Create Dimension
      21411  Edit Text
      21412  Change Dimension type to Radius
      21413  Change Dimension type to Diameter
      21414  Convert curve to polygon
      21415  Display Crosshairs
      21416  Convert Curves to Polygons
      21418  Change style of leader arrow
      21419  Change style of text leader
      21421  None
      21422  Slash
      21423  Dot
      21424  Closed
      21425  Open
      21426  Pushpin positioned Leader
      21427  View Based Leader
      21428  Leader is hidden
      21429  Extrude along a path
      21430  Text
      21433  Show or hide the edit toolbar
      21434  Choose Font
      21435  Select an edge, curve, or two points to dimension, or drag one to move.
      21436  Select second point for linear dimension.
      21437  Place the dimension.
      21438  Dimension
      21439  Edit Dimension
      21440  R
      21441  DIA
      21444  Bigger
      21445  Smaller
      21446  Bold
      21447  Italic
      21448  Place Sketch Axes
      21450  Select all edges that bound a face
      21451  Select all faces that are connected to the selected entities
      21452  Select everything that is connected to the selected entities
      21453  Select everything that is on the same layer as the selected entities.
      21454  Select everything with the same material as the selected entities.
      21455  Screen text was ignored.
      21456  Can't place component there!
      21457  Can't insert empty component.
      21458  Can't insert a component with just screen text.
      21459  Select everything with this material
      21460  Dimension Properties
      21461  Display license information
      21462  Authorize a new SketchUp license
      21463  Unauthorize a SketchUp license
      21464  Create a network license file
      21465  Uninstall a network license file or create standalone license
      21466  Display the Quick Reference Card
      21467  Show licenses in use on local network
      21468  Test software clipping
      21469  Zoom Extents
      21477  Show all shortcuts
      21478  Show the Ruby console
      21479  Ruby Console
      21480  Sort components by name
      21481  Sort Components by Creation Date
      21483  Reset OpenGL
      21485  Revert
      21486  Print to Scale
      21487  Material Editor
      21488  Entity Info
      21490  Soften Edges
      21491  Profile Edges
      21492  Extended Edges
      21493  Jitter Edges
      21494  Field of View
      21495  Enable BugSplat (TM) crash reporting
      21507  You must select one or more faces
      21510  Replace this component with another in the model.
      21511  Select all instances in the active context.
      21512  Highlight the component in the browser view.
      21515  Position texture on the face
      21516  Reset original texture position
      21517  Invalid name.  Style names must be unique.
      21521  Use selected image as a material
      21522  Intersect the select set with the model
      21523  Intersect select set with Model
      21524  Intersect with Model
      21525  Follow along a path
      21526  Intersect with Context
      21527  Intersect Selected
      21528  Debug Show Image Materials
      21529  Drag face to extrude  Alt = face perimeter
      21530  Select face to extrude
      21531  Edit Items
      21532  Curve segments must be in the range from %d to 999
      21533   Alt=Paint.
      21534  On Red Axis
      21535  On Green Axis
      21536  On Blue Axis
      21537  Delete Layer
      21539  Purge unused layers
      21540  Display using color by layer
      21542  Insert an image from a file as a material.
      21543  Pick first point on face to paint with image. Dbl Click=Drop.
      21544  No intersections found between selection set
      21545  WARNING!
      21551  Cast Shadows
      21552  Receive Shadows
      21553  Use as material
      21581  Show Scene Info
      21582  Filename path too long
      21583  Unknown Error
      21584  Intersect
      21585  This does not appear to be a valid path
      21586  Directory is Write Protected
      21589  	Splines;		%1!d!
      21590  No 3D model exporters installed.
      21591  It appears that you are missing some section exporters.
      21592  It appears that you are missing some 2D graphic exporters.
      21594  Hidden
      21596  Collection Path
      21600  Model Info
      21601  Units
      21602  File
      21603  Colors
      21604  Components
      21608  Location
      21609  Behavior
      21610  Statistics
      21611  Animation
      21612  Year must be less than 2038!
      21613  SketchUp Models (*.skp)|*.skp|SketchUp Version 6 (*.skp)|*.skp|SketchUp Version 5 (*.skp)|*.skp|SketchUp Version 4 (*.skp)|*.skp|SketchUp Version 3 (*.skp)|*.skp||"
      21614  Warning!  You may experience a significant slow down when using maximum texture size.
      21617  Component
      21618  Authors
      21621  ,
      21700  NULL pointer to a CEntity
      21701  This entity (%d) should be a CEntity but it is not
      21702  The entity at address %x has an invalid id (%d)
      21703  The attribute pointer for %s is not valid
      21704  The parent of this entity (%d) is wrong
      21705  The parent of Entity (%d) is bad
      21706  The face for %s is not a CFace
      21707  The parent of %s is not a CFace
      21708  %s is missing from this component (%s)
      21709  The parent of %s is invalid
      21710  The first edge use pointer for %s is not a CEdgeUse
      21711  An edge use for %s is not a CEdgeUse
      21712  Entity %s should be a %s but it is not
      21713  Entity %d (%s) is not a %s
      21714  Unknown Error while validating %s
      21715  Edge %d in %s is not a CEdge
      21716  Loop %d for %s is not a CLoop
      21717  The definition list for %s is not a CDefinitionList
      21718  A component definition in component %d is not a CComponentDefinition
      21719  The start or end edge for %s is not a CEdge
      21720  The parent of %s is not a CComponent
      21721  The start or end vertex for %s is not valid
      21722  The parent for %s is incorrect (stack empty)
      21723  The parent for %s is wrong
      21724  The parent of %s is NULL
      21725  Component definition %d for %s is not a CComponentDefinition
      21726  The parent of %s is not a CEntity
      21727  The material for %s is not a CMaterial
      21728  The model's material manager (accessed from %s) is not a CMaterialManager
      21729   - fixed
      21730  Loop %d of %s is an invalid inner loop
      21731  The parent for loop %d is not NULL
      21732  Attribute %d for %s is not valid
      21733  Snap-to for %s is not valid
      21734  The insertion point for %s is not valid
      21735  Instance %d of %s is not valid
      21736  The behavior for %s is not a CComponentBehavior
      21737  The type for %s is not valid
      21738  The thumbnail for %s is not valid
      21739  The definition for %s is not valid
      21740  The transformation for %s is not valid
      21741  The line for %s is not valid
      21742  The position for %s is not valid
      21743  The from position for %s is not valid
      21744  The start or end edge for %s is NULL
      21745  The start or end edge for %s is not valid
      21746  The start or end edge for %s is not on the curve
      21747  The start or end vertex for %s is NILL
      21748  The image cache for %s is not valid
      21749  The font for %s is not valid
      21750  The font type for %s is not valid
      21751  The arrow type for %s is not valid
      21752  The highlight non-associative color for %s is not valid
      21753  The hide out of plane value for %s is bad
      21754  The color for %s is not valid
      21755  The text color for %s is not valid
      21756  The text position for dimension style %d is not valid
      21757  Point reference 1 for %s is not valid
      21758  The normal vector for %s is not valid
      21759  The X axis for %s is not valid
      21760  The Y position for %s is not valid
      21761  The dimension type for %s is not valid
      21762  The X position for %s is not valid
      21763  The model pointer (accessed from %s) is not valid
      21764  The back reference manager (accessed from %s) is not valid
      21765  The arc edge for %s is not valid
      21766  The back reference to the arc edge for %s is not valid
      21767  The arc for %s is not valid
      21768  The ratio value for %s is not valid
      21769  The edge for %s is not valid
      21770  The loop for %s is not valid
      21771  The previous or next edge use for %s is not valid
      21772  The partner for %s is not valid
      21773  The plane for %s is not valid
      21774  The back material for %s is not valid
      21775  The bounding box for %s is not valid
      21776  The front or back texture coordinates for %s is not valid
      21777  The font face for %s is not valid
      21778  The point size for %s is not valid
      21779  The reference count for %s is not valid
      21780  The FT font for %s is not valid
      21781  The font file for %s is not valid
      21782  The scale factor for %s is not valid
      21783  The font type for %s is not valid
      21784  Font %d for %s is not valid
      21785  Layer %d for %s is not valid
      21786  The current layer for %s is not valid
      21787  The name for %s is not valid
      21788  The texture for %s is not valid
      21789  The transparency value for %s is not valid
      21790  The type for %s is not valid
      21791  The colorize type for %s is not valid
      21792  The name for %s is not valid
      21793  The material for %s is not valid
      21794  The behavior for %s is not valid
      21795  The material %d in %s is not valid
      21796  The front material for %s is not valid
      21797  The texture info for %s is not valid
      21798  The scene %d for %s is not valid
      21799  The selected scene for %s is not valid
      21800  The curve pointer for %s is not valid
      21801  Edge %d attached to %s not a CEdge
      21802  Point reference 2 for %s is not valid
      21803  Loop %d of %s is an invalid outer loop
      21804  Point %d for %s is not valid
      21805  The driving pointer for %s is not valid
      21806  The driven pointer for %s is not valid
      21807  Relationship %d for %s is not valid
      21808  The rendering mode for %s is not valid
      21809  The display style for %s in not valid
      21810  The edge color mode for %s is not valid
      21811  The face color mode for %s is not valid
      21812  The fog type for %s is not valid
      21813  The fog density for %s is not valid
      21814  The inactive fade setting for %s is not valid
      21815  The instance fade setting for %s is not valid
      21816  The transparency sort setting for %s is not valid
      21817  The soft edge limit for %s is not valid
      21818  The section transparency mode for %s is not valid
      21819  The plane for %s is not valid
      21820  The bounds rectangle for %s is not valid
      21821  The section slice for %s is not valid
      21822  The sun direction for %s is not valid
      21823  The sun rise time for %s is not valid
      21824  The sunset time for %s is not valid
      21825  The shadow time for %s is not valid
      21826  The longitude, latitude or time zone for %s is not valid
      21827  The north direction for %s is not valid
      21828  The default longitude, latitude or time zone for %s is not valid
      21829  The origin for %s is not valid
      21830  The X axis for %s is not valid
      21831  The Y axis for %s is not valid
      21832  The Z axis for %s is not valid
      21833  The X offset value for %s is not valid
      21834  The Y offset valid for %s is not valid
      21835  The leader direction for %s is not valid
      21836  The original view direction for %s is not valid
      21837  The font for %s is not valid
      21838  The arrow type for %s is not valid
      21839  The leader type for %s is not valid
      21840  The leader extension direction for %s is not valid
      21841  The DIB for %s is not valid
      21842  The X scale for %s is not valid
      21843  The Y scale for %s is not valid
      21844  The camera for %s is not valid
      21845  The DIB for %s is not valid
      21846  The parent for %s is not NULL
      21847  The vamera for %s is not valid
      21848  The rendering options for %s are not valid
      21849  The shadow info for %s is not valid
      21850  The SketchCS info for %s is not valid
      21851  The hidden drawing element %d for %s is not valid
      21852  Layer %d for %s is not valid
      21853  Section plane %d for %s is not valid
      21854  The transition time for %s is not valid
      21855  The delay time for %s is not valid
      21856  The active layer for %s is not valid
      21857  The "bits" pointer for %s is NULL
      21858  The watermark info for %s is not valid
      21859  The position value for %s is not valid
      21860  The DIB for %s is not valid
      21861  Reset Insert Point
      21862  Select Instances
      21863  Replace Selected
      21864  Update Thumbnail
      21865  Delete
      21866  Warning!  All instances will be deleted.
      21867  The name for %s is not valid
      21868  The position for %s is not valid
      21869  Entity %s should be erased
      21870  Results of Validity Check.
      21871  *** Problems were found that could not be fixed! ***
      21872  Errors have been detected in this model!
      21873  Errors were detected while loading this model!
      21874  Errors have been detected in what you are trying to copy!
      21875  Edge/All Same
      21876  Errors were detected in what you were trying to paste!
      21877  Edge/By Material
      21878  Construction
      21879  Edge/By Axis
      21880  Reparent
      21881  Edge/None
      21882  Hide Details
      21883  Show Details
      21884  Lock
      21885  Unlock
      21886  Make Unique
      21887  Layers to delete are used by locked groups or components.  Continue?
      21888   - done
      21889  The Layer Manager for this model is not valid
      21890  The Material Manager for this model is not valid
      21891  Rename
      21892  The Rendering Options for this model are not valid
      21893  The Shadow Info for this model is not valid
      21894  The Sketch Coordinate System for this model is not valid
      21895  The Root Component for this model is not valid
      21896  The start vertex for %s is not a CVertex
      21897  The end vertex for %s is not a CVertex
      21898  The layer for %s is not a CLayer
      21899  The model's layer manager (accessed from %s) is not a CLayerManager
      21900  The layer for %s is not valid
      21901  %s and %s connect the same 2 vertices
      21902  Something minor is messed up in your component.
      21903  Text Position
      21904  The active section plane for %s is not valid
      21905  The Font Manager for this model is not valid
      21906  Outside Start
      21907  Show or hide the construction toolbar
      21908  Show or hide the sections toolbar
      21909  Centered
      21910  Corrupt the model to test Check Validity
      21911  Outside End
      21914  Unlock all geometry
      21915  Unlock selected geometry
      21917  %s outside %s
      21918  %s inside hole of %s
      21919  %s coincident with inner loop of %s
      21920  Glued %s not on or parallel to glue plane.
      21921  Detected redundant %s on %s
      21922  Found dangling %s
      21923  Found %d unreferenced fonts
      21924  Found %d fonts with incorrect reference count
      21925  Found %d missing fonts
      21926  Hide dialogs
      21929  Show or hide the principal toolbar
      21930  Show or hide the walk toolbar
      21931  Check Web for newer SketchUp
      21933  Inches
      21934  Feet
      21935  Meters
      21936  Centimeters
      21937  Millimeters
      21939  Insert clipboard contents at original location.
      21940  Create 3D Text
      21941  3D Text
      21942  Enter text
      21943  SketchUp can not make any valid characters from the font you selected.
      21947  Display Very Large Thumbnails
      21952  Regular
      21953  Italic
      21954  Bold
      21955  Bold Italic
      21956  Place 3D text
      21980  Toggle display of Guides on and off
      21982  Select styles directory
      21984  The name for %s is not valid.
      21988  Get a model from the 3D Warehouse
      21989  Share your model in the 3D Warehouse
      21992  Getting Started
      21996  An invalid style %s was found in the style manager.
      23003  Exit
      23006  Match Photo
      23009  No faces available to project photo on to!
      23010  Match Photo
      23011  Project Photo
      23012  Zoom Matched Photo
      23013  Overwrite existing materials?
      23014  Move grips to locate vanishing points.
      23015  Adjust origin to a useful starting
      23016  Adjust red vanishing point.
      23017  Adjust red axis bars to
      23018  Adjust green vanishing point.
      23019  Adjust green axis bars to
      23020  The blue vanishing point
      23021  Adjust horizon to move the
      23022  Zoom in or out.
      23023  The center of projection
      23024  Click outside the
      23025  This will delete the page you've created.  Continue?
      23026  Done
      23027  Start Over
      23028  Cancel Match
      23029  Zoom Vanishing Points
      23030  Rotate 90 Right
      23031  Rotate 90 Left
      23032  Rotate 180
      23033  Undo
      23034  Redo
      23035  Sketch Over
      23036  Two Point
      23037  Edit Matched Photo
      23038  The opacity value for %s is not valid
      23039  The DIB for %s is not valid
      23040  The background image for %s is not valid
      23041  No background image
      23042  Select background image file
      23056  Show or hide the large tool set toolbar
      23057  Not signed in
      23058  Signed in as %1
      23060  No known contributor
      23061  Credits; %1
      23062  Credits; %1 + 1 more
      23063  Credits; %1 + %2!d! more
      24129  Locate Photo...
      24130  Scene
      24131  Image File
      24132  Found
      24133  Link
      24134  Reload Photo
      24135  Found and up to date
      24136  Embedded
      24137  Linked
      24138  Select directory for images
      24139  Locate other images in this directory?
      24140  Overwrite existing images?
      24141  Failed to write all images!
      24142  The image file %s has changed size from %d by %d to %d by %d.
      24143  Your photo match may be invalid if you use this image.
      24144  Do you want to use it anyway?
      24145  Failed to read image file!
      24146  Locate the photo match image
      24148  Edit Texture Image...
      24149  Failed to start image editor.
      24150  Executable Files (*.exe)|*.exe|All Files (*.*)|*.*||
      24151  Image Editor Browser
      24152  Applications
      24153  Edit texture image in external editor
      24154  An external image editor can be used to customize texture images
      24155  Edit Texture Image
      24156  Measurements
      24159  Geo Location
      24160  Attribution
      24161  Instructor
      24167  Enable/Disable SceneGraph
      24173  Make Unique Texture
      24174  Combine Textures
      24175  The texture will be made unique before editing.  Continue?
      24176  Do you want to erase interior edges?
      24188  Upload component to the Google 3D Warehouse
        All of these don't look like actions though.
        That sounds more like a string. Did you get a string returned by the method?
        • tbdT Offline
          tbd
          it looks like it contains also the String resource which is something different than .send_action (which is a WM_COMMAND menu wrapper)
          http://plugins.ro
            Yea, I'm confused. I thought the send_action only returned a boolean value...
              @gavvy said:
              20408 Zombies and Others: %1!d!
              Sketchup.send_action(20408)
              > true
              • Chris FullmerC Offline
                HEhehehe. Good one Thom.
                Very interesting.
                  gavvy
                  hehe
                  i just to use
                  Sketchup.display_name_from_action to get these and i don't know why some actions do not work .
                  is there some def in the "sketchup module"? or Can we redefined these unuse actions just as "60000~100000"
                  but i don't know :"Sketchup" is a module or a class in the api of GoogleSketchup ? 😳
                  these day i 'm rewroting Jim's Customtoolbar and i get some trobules
                  RubyScript:
                  module F
                  require PipeAlongPath.rb
                  def self.A
                  eval "pipe_along_path"
                  def self.B
                  	eval pipe_along_path
                  def self.C
                  	send "pipe_along_path"
                  def self.D
                  	cm
                  def cm
                  RESULE:
                  F.A > undefined local variable or method `get_vertices' for F:Module
                  F.A > no But other work well
                  F.C> ok But other donsn't work
                  F.B> ok BUT i don't know how to translate a string to a command
                  F.D > ok ALL,and i don't want to use this way
                  I am going to create a Module to contain each rubyscript so they won't interup with eachother
                  is there anything wrong ?
                  or is anyone can tell me the other way to run a command just to send the command name to the sketchup
                    That does not sound like a good idea. Best not to redefine base classes and methods.
                      cjthompson
                      I was browsing Object.constants and I found these.
                      just use them with Sketchup.send_action as constants, not strings.
                      CMD_ARC
                      CMD_CAMERA_UNDO
                      CMD_CIRCLE
                      CMD_COPY
                      CMD_CUT
                      CMD_DELETE
                      CMD_DIMENSION
                      CMD_DISPLAY_FOV
                      CMD_DOLLY
                      CMD_DRAWCUTS
                      CMD_DRAWOUTLINES
                      CMD_ERASE
                      CMD_EXTRUDE
                      CMD_FREEHAND
                      CMD_HIDDENLINE
                      CMD_LINE
                      CMD_MAKE_COMPONENT
                      CMD_MEASURE
                      CMD_MOVE
                      CMD_NEW
                      CMD_OFFSET
                      CMD_OPEN
                      CMD_ORBIT
                      CMD_PAGE_DELETE
                      CMD_PAGE_NEW
                      CMD_PAGE_NEXT
                      CMD_PAGE_PREVIOUS
                      CMD_PAGE_UPDATE
                      CMD_PAINT
                      CMD_PAN
                      CMD_PASTE
                      CMD_POLYGON
                      CMD_POSITION_CAMERA
                      CMD_PRINT
                      CMD_PROTRACTOR
                      CMD_PUSHPULL
                      CMD_RECTANGLE
                      CMD_REDO
                      CMD_ROTATE
                      CMD_RUBY_CONSOLE
                      CMD_SAVE
                      CMD_SCALE
                      CMD_SECTION
                      CMD_SELECT
                      CMD_SELECTION_ZOOM_EXT
                      CMD_SHADED
                      CMD_SHOWGUIDES
                      CMD_SHOWHIDDEN
                      CMD_SKETCHAXES
                      CMD_SKETCHCS
                      CMD_TEXT
                      CMD_TEXTURED
                      CMD_TRANSPARENT
                      CMD_UNDO
                      CMD_VIEW_BACK
                      CMD_VIEW_BOTTOM
                      CMD_VIEW_FRONT
                      CMD_VIEW_ISO
                      CMD_VIEW_LEFT
                      CMD_VIEW_PERSPECTIVE
                      CMD_VIEW_RIGHT
                      CMD_VIEW_TOP
                      CMD_WALK
                      CMD_WIREFRAME
                      CMD_ZOOM
                      CMD_ZOOM_EXTENTS
                      CMD_ZOOM_WINDOW
                        Are they shipping with SU - or is it a plugin that added them?
                          cjthompson
                          I just emptied out my plugins folder and they were still there. Is it even possible for a plugin to add actions to Sketchup?
                          BTW, this is the command I used to find them:
                          Object.constants.grep(/CMD./).sort.join("\n")
                            No - but these where just constants. I was just wondering if a plugin had defined them to simplify things.
