    Office Render - Its better but not much!!!
    16 Posts 6 Posters 1.7k Views 6 Watching
    • olisheaO
      olishea
      i think this will be helpful for all twilight users, cheers
      oli
      • dermotcollD
        dermotcoll
        Hi Frederik
        Just got in and saw your comments - thanks for taking the time to look at the model. Some questions:
        1. How do I load your IES file when I open the light editor I cant get it to load as the option is "greyed out".
        2. Where can I find the thin glass material in the materials editor - i didnt see it as an option?
        3. I didnt realise the point light components were in the ceiling - I have never placed them in a model before and was therefore unaware that it was a component in the model - i thought it was just a light source placed in the model and did not have a physical presence. - Your model shows Pot lights as a physical item - is this generated by the point light button in the Twilight render toolbar or is it an SU component?
        4. How do I stop a wall from being refelctive - do I go into the materials in Twilight and adjust a setting and if so wqhich one?
        Thanks for the feeedback - Ecuador has asked me to try the Twilight forum for more help and feedback so I should get plenty of good direction from all the pro's
        Cheers
        Dermot
        When you burn your arse - you gotta sit on the blisters!!
        • FrederikF
          Frederik
          Open the model I've attached above...
          Click the TWR Light Editor icon
          In the top-bar click the "From Scene" menu and select the Spotlight[1]
          Now click the tab "IES"
          Click the "Load" button and select the "10.IES" file, which I've attached in the above zip-file...
          @dermotcoll said:
          1. Where can I find the thin glass material in the materials editor - i didnt see it as an option?
          Click the TWR Edit Material icon (eye-drop tool on color palette)
          Point the "Eye-drop tool" on the window
          In the TWR Material Editor you'll see what material I've applied
          (The thin glass material can be found in the TWR Material Library - Architectural_Twilight)
          @dermotcoll said:
          1. I didnt realise the point light components were in the ceiling - I have never placed them in a model before and was therefore unaware that it was a component in the model - i thought it was just a light source placed in the model and did not have a physical presence.
          Not sure I understand you here... πŸ˜•
          The TWR point-lights have a physic precense in SU, just like spot-lights and IES components...
          Can't you see them in SU...??
          The spot-lights in my model is a component I've created myself, but you can easily make your own... πŸ˜‰
          In the Kitchen "Contest" thread, I've explained how you make such light components... πŸ˜‰
          @dermotcoll said:
          1. How do I stop a wall from being refelctive - do I go into the materials in Twilight and adjust a setting and if so wqhich one?
          Click the TWR "Edit Material icon...
          Click the wall material with the TWR eye-drop tool
          In the TWR Material Editor top-bar menu, select "Templates"
          Click "Generic" and select "Reset" in the sub-menu
          The material is now a flat default SU material...
          I can also encourage you to do so... πŸ˜‰
          And above all, look at some of all the video- and written tutorials we've made available... πŸ˜„
          Cheers
          Kim Frederik
          • honoluludesktopH
            honoluludesktop
            Many ways to skin a cat. I like figures for scale. Adjusted lighting, added texture (color) to ceiling, and rescaled the wood texture in SU. Thanks for the model to play with. Maybe a little too bright?
            • dermotcollD
              dermotcoll
              Cheers Guys
              I have tried what u said and managed to get this. Much better but windows still black!!!
              I am using an image of my own for the background and it is still not showing up.
              I will need that holyman to work a bloody miracle for me honolulu!!!!! (I know its a model cos I will never have a priest in my office!!!!)
              Wotyacollit Office.skp
              • FrederikF
                Frederik
                @frederik said:
                1. The background was not the physic sky, but a background image that didn't exist, hence the reason why it was black outside.
                But you can see the sun on the floor, which means that the material you've used for the windows is correct... πŸ˜‰
                Not sure I understand what you mean here...
                Just as a test purpose, can I please ask you to download the Spherical Skies Pack 1 and follow the steps Fletch has given...??
                I can also see that you didn't manage to remove the reflective material used on the walls...
                Once again, I can only encourage you to look at some of all the video- and written tutorials we've made available... πŸ˜„
                Cheers
                Kim Frederik
                • dermotcollD
                  dermotcoll
                  Hi Frederik
                  Can you give me a link to the videos as I cant find them on the Twilight forum - my blindness amazes me sometimes - probably why I missed the reflections on the walls!!! πŸ˜’
                  • FrederikF
                    Frederik
                    Cheers, James...
                    I also recommend that you download the TWR User Manual as a pdf-document... πŸ˜„
                    Cheers
                    Kim Frederik
                    • K
                      kwistenbiebel
                      Hi dermotcoll,
                      I had a quick go at your SU file.
                      Another render engine was used, but setup should be quite universal, so I guess it could apply to Twilight as well.
                      Some general observations:
                      1. use a groundplane around the subject and make it big enough. This way, the physical sky will bounce around light in the interior (ceiling) more realistically.
                      2. If render time is not an issue, render the room as fully enclosed without the back wall missing. More realism, but I know...render time...
                      3. thin glass is the way to go.
                      4. Create some background in the exterior. In my example I placed a 2D clipmap treeline surface.
                      Here's what came out:
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/office.jpg
                      and the SU setup:
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/Wotyacollit-Offic2b.jpg
                      • P
                        Pg09
                        Kwistenbiebel,
                        i always find your posts very helpful! Thanks for taking the time!
                        • dermotcollD
                          dermotcoll
                          Cheers kwistenbiebel
                          Really like the output you got. As I said all the help here is fantastic - i need to go away, improve my models, materials, lighting, composition, read manuals, look at videos and then when I take my tail from between my legs and post a new render I will see how well I have progressed.
                          Thanks again everyone for all your help.
                          Cheers
                          Dermot
