    SelectionObserver and get attributes....
    3 Posts 3 Posters 331 Views 3 Watching
      Pauline01
      Hello,
      I see the classe http://code.google.com/intl/fr-FR/apis/sketchup/docs/ourdoc/selectionobserver.html, i use this to run a ruby script when i click on a component in skecthup.
      for example:
      My component "Component#1" has in "Component Attribute" an identity, adress, and others descriptions... i want when i click on this component, run my ruby script (I already did that), but i don't know to retrieve "Component Attribute". I wish put for example the attribute "identity" of "Componente#1" in a variable in ruby.
      require 'sketchup.rb'
      class MySelectionObserver < Sketchup;;SelectionObserver
             def onSelectionBulkChange(selection)
      		wd=UI;;WebDialog.new( "Somfy Controller", true, "",950, 700, 100, 100, false )
      		wd.show
      		#I WANT TO PUT IDENTITY ATTRIBUE OF MY COMPONENT#1 IN THIS VARIABLE
                      identity= '000003'
      		wd.set_url("http://localhost/final_programme/index.php?identity="+identity+"")
           # Attach the observer.
           Sketchup.active_model.selection.add_observer(MySelectionObserver.new)
      # end of sample.rb
      thx to help me
      Pauline
        How to set attributes?
        entity.get_attribute http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#get_attribute
        entity.set_attribute http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entity.html#set_attribute
          Jim
          Hi Pauline, the attributes for a Dynamic Component are in the the "dynamic_attributes" attribute_dictionary.
          # Check  "dynamic_attributes" dictionary for a Dynamic Component
          identity = selected[0].get_attribute("dynamic_attributes", "identity")
          # the Definition may have the attribute, so...
          if identity.nil?
            identity = selected.definition.get_attribute("dynamic_attributes", "identity")
          if identity.nil?
            # there is not attribute named "identity"
          else
            # Yes, we found "identity"
