    Script request -- drop to touch
    11 Posts 5 Posters 1.5k Views 5 Watching
      MartinRinehart
      I'm thinking that a picture of what you want would help.
        agamemnus
        Hi, sure. Just pretend these circles are complex 3d polygons and the blue circle doesn't necessarily hit any anchor point on the green circles such that no other geometry.
        The object is for the lowest relative point (not anchor point) on the green circle to just touch the highest relative point on the blue circle.
        To do this manually i'd need to find the lowest point on the blue circle, draw a line down, intersect the line with the bottom geometry and get an anchor point at the intersection of the line and the green circles, while hoping that the blue circle geometry does not intersect any other green circle geometry on the way down.
          Sketchyphysics3 makes that automatically πŸ˜‰
          Just set your volume as "Sphere" or "Convex" (so "surface" must have minimum thick)
          Run animation
          Save / Exit
          Reload you have your result! (here with SPh 2.1 )
          PS Look if maybe my little thread about drop can help don't make that?
          Cylinder.skp
            agamemnus
            Thanks for the idea. Sketchyphysics 3 might do the trick. Might not work for complex objects, though, and it is a bit of a clumsy method...
            The undrop multiple sounds fun, but I can't find a link to the final version.
            • Chris FullmerC
              Sketchyphysics is the closest thing out there to what you want. Its seriously complicated to write a script like that IMO.
              • X
                xrok1
                wouldn't it work to draw a construction line from blue center to green center, then move from intersection point blue to intersection point green? πŸ’­
                • X
                  xrok1
                  example:
                  • Chris FullmerC
                    That won't work on complex shapes though.
                    • X
                      xrok1
                      WELL... if you want to get picky! 🀣
                        About Sketchyphysics
                        A little trick if you want that your objets are still straight fall down at the end
                        Just put 2 big boxes (one in front of, one behind) so objects are jamed in! πŸ’š
                        About undrop
                        just copy/past that in the Web console
                        Select yours groups and press "Eval" πŸ˜„
                        Change z = z + 100.cm as you want πŸ˜„
                        (for copy all Code follow click blue "Select All" πŸ˜„
                            model = Sketchup.active_model
                            model.start_operation("Move in Z")
                            entities = model.entities
                            selection = model.selection
                            zeds=[]
                            index=0
                            sorted_groups=[]
                            groups=[];selection.each{|entity|groups.push(entity) if entity.kind_of?(Sketchup;;Group)}
                            groups.each{|group|zeds.push([group.bounds.min.z, index])
                               index+=1
                            zeds.sort!
                            zeds.each{|z|sorted_groups.push(groups[z[1]]) }
                            ### sorted_groups is now groups sorted by z
                            z = 0.0
                            sorted_groups.each do |e| # update!
                              # Now we process the groups
                              t = Geom;;Transformation.new(Geom;;Point3d.new(0,0,z))
                              # Apply the transformation
                              e.transform!(t)
                              z = z + 100.cm
                          model.commit_operation
                          return nil
