    Windows 7
    110 Posts 20 Posters 21.0k Views 20 Watching
    • soloS
      A friend of mine very recently bought a new laptop with Window 7 pre-installed, he came by last night as we are collaborationg on a project in downtown Dallas anyway he noticed I had a USB powered scanner that was not being used as it does not work with Vista (Visioneer onetouch) anyway he plugged it into his USB jack and it was recognised and worked straight up without even needing the driver disk. Just that compatability alone is amazing (Visioneer does not work on a Mac)
      • C
        chango70
        Just some basic SU experience in Windows 7. It appears that SU running in Windows 7 loads up a LOT faster. When I was in Vista 64 bit home premium I had to wait say like 20 sec (loads of ruby scripts) before the application becomes usable. Now it is more like 10 sec. This is a substantial improvement.
        • honoluludesktopH
          honoluludesktop
          Solo, did he do that without running VMWinXp? If so, perhaps Win7 default drivers include stuff not found in Vista. Fantastic.
          • soloS
            Honolulu, I believe his machine is stock, and probably not running any virtual machine setup, at least not what I know of.
            • N
              notareal
              @solo said:
              ...he noticed I had a USB powered scanner that was not being used as it does not work with Vista (Visioneer onetouch) anyway he plugged it into his USB jack and it was recognised and worked straight up without even needing the driver disk. Just that compatability alone is amazing (Visioneer does not work on a Mac)
              I have one usb dvb-t stick, that was never working properly in XP nor in Vista. It did not have a driver for any 64 bit win. Best of all, the manufacturer got buyed out and the product line was closed.
              Guess what - it works just fine in Win7 64-bit, just stink it in and enjoy the show 😄
              • E
                Ecuadorian
                Ok, guys, you won. 😄
                I've just returned from the local distributor with Windows 7 Pro 64. The border of the disc has some funny holograms with sparkles that makes it look like the disc is scratched; MS should rethink this design. Anyway, I'll be installing it this weekend and will be reporting my experiences. 😛
                -Miguel Lescano
                • honoluludesktopH
                  honoluludesktop
                  In addition to the new drivers, I wounder if those older Win programs that would not run in WinXP might run in Win7. Now where did I put that disk.......
                    remus
                    If you dont post for a couple of weeks we'll know whats happened to you 😄
                    • E
                      Ecuadorian
                      Small update: I have two hard drives, the first one with two system partitions and the second one with all my data. The first one contained XP and Ubuntu so I decided to delete the Ubuntu partition and install Windows 7 there. I can now dual boot XP and 7.
                      Now, for the dark comedy part: Windows 7 can't read my second hard drive. No matter what I try, it simply can't. Every time I boot 7 it messes up my data drive file structure and I have to repair it with XP later. Not only that... the first time I booted 7 with the data drive it offered me to format it. Imagine what could have happened. 😲 My data hard drive is NTFS and was formatted in XP. Any ideas of how to make it readable by 7? It has no fancy features turned on besides XP's Index Server, but then again my XP system partition also has this feature enabled and it's perfectly readable by 7. I guess I'll have to move all my stuff to one of the system partitions, format the data drive and move all my stuff again so I can finally start to actually use 7. 😡
                      The ironic part: Ubuntu had no problems reading my data disc. It's infuriating that Linux can read an XP-formatted disc with no problems (in fact, it can read pretty much any format you throw at it), while 7 can't.
                      The scary part: Imagine what would have happened had I not kept XP. I would now be Simply Outta Luck, completely unable to access my data. sigh Now I know why Linus Torvalds poked fun at 7.
                      -Miguel Lescano
                      • honoluludesktopH
                        honoluludesktop
                        Didn't you install Win7 64 bit? Will it read 32 bit dirves? I know that you can have 32 bit data, and programs, but????
                        • E
                          Ecuadorian
                          Yes, I installed Win 7 Pro 64-bit. I still haven't installed any software on it, but for some obscure reason it won't read my second hard drive, a 500GB Samsung SATA disk I bought just months ago. XP 32-bit and Ubuntu 32-bit can read the drive without any problem, but Win7 can't and prompts me to format it. 😕
                          -Miguel Lescano
                          • E
                            Ecuadorian
                            I would highly recommend installing Win7 in dual boot instead of wiping out your XP. Then you can see if your hard drive is read automatically by Win7, and if it isn't, you can still access your data.
                            My two discs are formatted in NTFS and both use the SATA interface, so it's weird the one is being read and the other not. The one that does work is a Western Digital, while the other is a Samsung.
                            When I tried to install the Release Candidate of Windows 7 it was not compatible with my LG DVD writer, but the retail version works perfectly with it, so I guess the odd problem with Samsung my hard drive is just one of those little things that will be ironed out sooner or later by MS. Until then, I've started moving all my stuff and I'll soon be reporting how things go after formatting the disk.
                            -Miguel Lescano
                            • honoluludesktopH
                              honoluludesktop
                              Will Win7 64 bit read a Hard Drive formatted in 32 bits? I did a quick google but didn't find a answer.
                              MS list of compatible "external drives" are all 64 bit. You may have to run VPC 64 with WinXP 32 bit connected to your drive, then connect Win7 via a Virtual Network to the VPC, and copy your date to the 64 bit drive. Once done, you can reformat the old 32 bit drive as 64 bit, and copy the data back. Before doing this, make sure that MS has a 64 bit driver for your old drive.
                              • honoluludesktopH
                                honoluludesktop
                                Miguel, I don't think that you get it. Win7 reformatted its partition on your primary hard drive to 64 bits when it installed itself. Your primary drive is half 32 bit (WinXp) and half 64 bit (Win7).
                                I do not think that Win7 can read the other hard drive that is formatted as 32 bits. Its got nothing to do with NTSF or SATA requirements. But I could be wrong. Hope that you work things out.
                                  remus
                                  Im almost certain that the fact your last OS was 32 bit has very little to do with why 7 cant read your hard drive. Just did a quick test and was able to read and write data from a 32 bit OS to an external hard drive thats only previously been used by a 64 bit OS. I cant offer an alternative theory, though 😕
                                  • E
                                    Ecuadorian
                                    Disc 0 is my Western Digital. It has a partition for WinXP (C:) and another for Win7 (D:).
                                    Disc 1 is my Samsung. It has only one partition (L:) for my data.
                                    Windows XP can read all three partitions.
                                    Windows 7 can only read partitions C and D in Disc 0. The other disc is recognized but it shows up as unformatted in Windows 7.
                                    All three partitions are formatted in NTFS. Both discs are connected via SATA.
                                    -Miguel Lescano
                                    • honoluludesktopH
                                      honoluludesktop
                                      Well, I stand corrected. Sorry, if I confused the issue.
                                      • N
                                        notareal
                                        Quite freaky. Had a bit similar configuration, but I connected the data disk after Windows 7 RC (64-bit) was fully installed. Worked fine. Perhaps if you try to connect that disk to a different sata port...
                                        • soloS
                                          Please note that there are different Windows 7 packages, to some the differences are irrelevant and others that use 64 bit with tons of ram for 3d apps (myself included with 12GB ddr3) the different packages have various memory capabilities.
                                          Windows 7 64 Bit Memory Capabilities
                                          • Starter: 8GB
                                          • Home Basic: 8GB
                                          • Home Premium: 16GB
                                          • Professional: 192GB
                                          • Enterprise: 192GB
                                          • Ultimate: 192GB
                                            remus
                                            Looking forward to the day i can afford 192Gb of RAM.
                                            • 3 / 6
