Some high quality 3D models... hope you will find usefull
All this models can be found on 3D Warehouse.
author: NewOne
It took me two days to make the socket... in a time when rubies were not as complex as now
The pillows for the Sofa are not as I'd like to be. Is somebody can make better ones, please contact me to update the model. Thanks!
and finally a present for you all!... in a few months you'll need it
many many thank you mate
. wich render engine you've used to render models? -
. wich render engine you've used to render models?maxwellrender v1.7
(I cry because v.2 it's not coming...) -
Nice renders Marumures
Thanks -
Some new models...
The models are superb, but the rendering is absolutely wonderful. The tap looks so good
Nice to see some higher quality models make it into the warehouse! The low poly stuff just doesn't cut it for use in maxwell!
Two more sinks... as usual, you will find them on 3dwarehouse
Woah those sinks are pretty amazing, the rendering is flawless!
The scratches on the first one are very realistic!
thx bro!!! and great models and renders!!
Pretty cool! Amazing stuff! It looks better than real.
Would it be possible to do this level of quality render with other software?
I'm pretty new to rendering, has anybody done a rend-off between packages?
s
Great job man!
Thanks, I'm glad that you like the models. I would like also to see that somebody used them in it's work.
P.S. More to come!
very,very nice..
take care
Elisei
hy man, were are the links for download this?
thanks solo... one mor question, where did you maped those textures and maps, sketcup or maxuel?
Sketchup! Well, on some I worked a little, but in the end I did it...
