    Time Tracker?
    13 Posts 9 Posters 4.1k Views 9 Watching
      Jim
      Can anyone recommend a time tracker that can be used to generate a report for invoicing?
      • E Offline
        Ecuadorian
        Did you try the one at Smustard?
        http://www.smustard.com/script/TimeTrack
        -Miguel Lescano
          I was also going to suggest it but then I realised Jim might want something different as the one at Smustard can track how much you are modelling but not how much you are scripting plugins.
            Jim
            Maybe I'll just use Legos.
              MtnArch
              You could also check out BillQuick (http://www.billquick.com). It's very powerful, but also has a "Lite" version that is free (it's the full demo version that locks out some features after the trial period).
              Highest Regards,
              Alan T. Hendry, RA
              Architect
                d12dozr
                I just came across this - its an ancient program but appears to work great.
                http://www.cratchit.org/TimeTool/
                http://goo.gl/f7ooYh
                  Jim
                  Thanks for the suggestions. Still looking, although looking these sites over has gave me some ideas about my own workflow. In the meantime, I am using a clock and pencil and paper (high tech.) I am planning on registering for quickbooks or freshbooks to track clients and create invoices (still looking at that.)
                  "My" time tracker would not be a hard programs to write - with a task editor, and the ability to clock in and out on tasks... so I may end up slapping together something.
                    blair
                    SPERICAL TIMESHEET
                    I thought I posted this before but must not have clicked something correctly. I have used this for years and seen nothing better. You can set up jobs, task, paste from old to new etc. and it will keep track of EVERY MINUTE OF TIME you use (in the background-do not have to start/stop etc.)on the computer by screen, drawing or just about any way you want to compole it and print the time sheet in a number of ways. One thing I like to use it for is historical estimating of previous jobs or task.
                    http://www.sphericaltech.com/
                      Jim
                      I found a couple open-source projects for project time-tracking which have some of the features I was looking for - mainly simplicity, multiple projects/tasks, being able to switch projects/tasks frequently, and basic reporting.
                      http://rubyforge.org/projects/worktimer (screen shots)
                      http://code.google.com/p/simpletasktimer (screen shots)
                        Jim
                        Xnote Stopwatch/Clock is an on-screen timer, and you can insert time snapshots into its built-in table or into a running Excel spreadsheet. Might be useful as a work timer.
                        http://www.xnotestopwatch.com/
                          kobus
                          Late to this topic, but I found this to be helpful at times:
                          http://www.myhours.com/
                          cheers
                          you should be interested in the future. you will spend the rest of your life there
                          • KrisidiousK Offline
                            Krisidious
                            SU Clock by Fredo... awesome time tracker.
                            http://forums.sketchucation.com/viewtopic.php?f=323&t=36699
                            By: Kristoff Rand
                              jaxcoffee
                              I would check out FreshBooks.
                              It's a great invoicing program, with plugins to track time and incorporated that information directly into a clients invoice.
                              http://www.freshbooks.com/
