    Art Gallery Design
    13 Posts 8 Posters 1.5k Views 8 Watching
      d12dozr
      Looks good - nice design! πŸ‘
      Have you given thought to ventilation of auto exhaust in the basement? From what I can tell the only vent to outside is the ramp, then on the other end of the basement the stairwell opens up inside the building - this would cause fumes to enter the building directly.
      http://goo.gl/f7ooYh
      • B
        benwheels
        Hi d12dozr,
        Thanks for the comment, glad you like it πŸ˜„ You have a very good point, I will have to mechanically ventilate the basement in order to avoid this. Thanks for the tip.
        • C
          cadmunkey
          You've done a real nice job for a college project. Good luck with the rest of it.
          • DanielD
            Daniel
            Very nice, benwheels. Both design- and presentation-wise.
            There's a few inconsistencies you might want to address:
            Your ground plan has shadows, but the other two do not.
            Your title is in the lower right corner on the first two boards, but in the middle on he third; plus, it's partially obscured by the image.
            On the first two boards there is a clear separation between the images, but on the third one you've attempted to blend them together.
            No graphic scale!
            Are you required to worry about handicap accessibility at this time?
            My avatar is an anachronism.
            • olisheaO
              olishea
              lovely presentation on the sections πŸ‘ πŸ˜„
              oli
              • T
                teofas
                superb presentation!!
                http://www.spazioarquitectura.com
                • B
                  benwheels
                  Thank you all for the kind words πŸ˜„
                  Daniel on Wed Oct 14, 2009 5:43 pm
                  Hi Daniel,
                  Thanks for your comment, I agree with you on the inconsitencies in the presentation, this was done quite quickly for a critique a few weeks ago, I plan on tidying these up for the final presentation, I will take your comments on board. I also plan on adding some materiality to the dark grey mass (Still not entirely sure what I'm going to use yet) Any sugestions anyone? I was thinking some sort of perforated composite panel, possibly encorporating some white leds into the facade, making it look like a glistening stone lit up at night. May be a bit over the top, but I think it could look quite good done relatively subtly.
                  As far as the handicap access, yes it does have to be a fully inclusive design, which I'm pretty confident I've got covered. There is access in the middle of the outside paving to the entrance which is level with natural ground, so no reason to ramp. Also an internal lift. There is also a disabled ramp down to the lowered outdoor paved area to the rear of the building, this isn't noted as a ramp, I will make this a bit clearer for the final presentation.
                    sepo
                    Could you tell us what soft did you use to render the images with?
                    BTW nice and clean presentation.
                    • B
                      benwheels
                      Hi Sepo,
                      Rendered in Kerkythea with Photoshop post. Plans drawn in Revit and coloured in photoshop, Just very basic 3d in revit to work out basic planning.
                      • DanielD
                        Daniel
                        I've sent you a PM regarding your accessibility.
                        Please post your final boards after you've tweaked them.
