    Animated section planes
    33 Posts 22 Posters 8.3k Views 22 Watching
      tomislavm
      Super!
      I like that and I think that animated section plane is one of the best in sketchup!
        I really enjoyed this. Fine model, well chosen style and of course, the whole presentation setup!
        And Richard is right; would be really cool not to see the "hollows". AFAIK TIG is working on some "super 'SectionCutFace' plugin" that could do this. Oh my, if that came to reality!
          matteo
          @richard said:
          Darn shame when you watch this, makes you realise how cool it would be to have SU's section plane auto fill closed volumes and also only consider shadow cast from the full model, uneffected by the section.
          me too!
          actually I consider this just a test video, since that section limit.
          I also tried to do it with Vue d'Esprit: it would be cool to keep the quality of the title rendering while animating down the section plane. I tried it by subtracting a big parallelepiped from the castle. Sadly, it doesn't work. Vue is not able to recognize the difference between empty and full spaces in the imported model: it's a surface that contains a really complex topological space. The result was something messed up like after a teletransport malfunction.
          I had a good time making the some subtraction inside sketchup with Booltools by Dale - this time the subtraction worked quite well: it's incredible how good that plugin works.
          Some screenshots and an explanation in italian can be found in my blog - as soon as I can, I'll translate the concept of Section Sphere to SCF too
          for a preview just click on the link under my signature: entry 033
          hire me: http://www.nonsolo3d.it/ !
          • FrederikF Offline
            Frederik
            Excellent stuff, Matteo... 👍
            You inspire me to test some ideas I have myself using section cuts and animation... 😄
            @solo said:
            Impressive model also, there is a lot of very fine detailing there. 👍
            Matteo actually made the Belasi castle available for others to render...
            You can get it from the [rendering/editing challenge] Belasi castle thread... 😉
            Cheers
            Kim Frederik
              Prisoner
              Impressive 😮 What a wonderful composition. This really is a big inspiration for me.
              I'm working with similar backgrounds and overlays... have to log out and do some section cut tests right now
              • N Offline
                nacholo
                Impresionant!
                Really original!
                Congatullations for you, Matteo
                Thanks by show it!
                Thanks and gretting
                  chango70
                  That is brilliant! 😮 How if anyone can develop an renderer that works with section planes... Droool....
                    chango70
                    I watched it again with sound switched on and the music was also really effective. What is it if you don't mind me asking?
                      matteo
                      thank you all for your warm appreciation sepo, solo, durant, olishea, pilou, richard, tomislavm, gaieus, frederik, prisoner, chango70! I didn't expect that 😄
                      @chango70: the music clip credits are in the end titles - I downloaded it from Jamendo (http://www.jamendo.com/)and it is released under creative commons.
                        matteo
                        If anyone is interested, the castle shell is now on the 3d Warehouse: waiting to be validated by the Google Earth team.
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                        since the surrounding forest hides part of the walls, I could not make all textures; then I decided to assign only flat colours to the whole structure.
                          @matteo said:
                          ...since the surrounding forest hides part of the walls, I could not make all textures; then I decided to assign only flat colours to the whole structure.
                          I am afraid (and really sorry to predict) that it will be rejected for "incomplete texturing" I'd rather fake those textures by heavy editing the trees out (or create wall textures from the plastering or anything "shot" elsewhere) because it would be a shame if this fine model was rejected - but probably it will be.
                          • MALAISEM Offline
                            MALAISE
                            Quite detailled and smooth animation, I like it, knowing how difficult it can be to manage. 👍
                            5 I did something similar using an ancient roman villa, but I'd never published it )
                            MALAISE
                            • urgenU Offline
                              urgen
                              ...nice and simple! ☀ thank you! 👍
                              --pupil forever...------
                                Seems Add Section Cut face + Slice model at section works
                                  matteo
                                  Gaieus, your prediction came true. The good thing about it is that it took only few days to be confirmed and not weeks or months like it happened for some of my past models.
                                  Then I textured it: the textures are tiny, really low-res, but that's more than enough for GE.
                                  Here the link to the re-textured model:
                                    Yes, I see. If they reject it again (although this way, I think it could get through), we'll find out something to trick them.
                                    IMO it also looks better this way than with pure colours but of course, you know hwo much better it is in real life.
                                    • FletchF Offline
                                      Fletch
                                      Great work, Matteo, I think the music really "sells" the animation... congrats on a job well-done. 👍
                                      Fletch
                                        And the pity is that you can't render that in a renderer! 😮
                                          davesec
                                          hi!
                                          what kind of line style are you using? it looks like sketchy edges, but i'm not sure which one (if any)
                                          thanks!
                                          • simon le bonS Offline
                                            simon le bon
                                            Magnifique film Mateo,,,
                                            and the use of animated sections seems to me really relevant to introduce the place.
                                            👍 👍 , simon
