    Let's talk about D.O.F
    57 Posts 25 Posters 9.9k Views 25 Watching
    • arail1A
      arail1
      I'm on the fence about DOF in larger images. Often it seems to put a blurry object too close to my viewpoint and I find that distracting. The tree to the left in this image is an example.
      Also, the DOF effect is only realistic when you're looking at the item that is in focus (the house in this case) but when you turn your attention to something else in the picture the effect reads 'wrong'. If I turn my attention to the tree in real life it doesn't appear to be out of focus because my eyes make the necessary adjustment. The fact that the picture doesn't do that makes DOF seem to be just an 'effect' and not a very successful one.
      Some way to diminish the intensity of the items surrounding the target image without making it look like there's vaseline on the camera lens would seem to be a worthwhile challenge.
        davidh
        I always use a form of depth of field but add in later in post processing.I like to have something in the foreground thats blurred but I also darken the blurred element using levels as this helps to frame the image and guide you to look at whats important.
        I find that rendering depth of field can take too long and it also reduces your options in post processing.
        I only use depth of field/blurring for objects right at the front of the image,again it helps to bring the main image forward.
        For someone like me who uses a lot of entourage elements in post processing, sometimes if the foreground I require/prefer is not high enough resolution,I can use blurring to soften it.
        • E
          Ecuadorian
          The image in the first post looks like a miniature, Pete. Sometimes exaggerated DOF is used for this purpose. but I think there is no reason not to always use a more moderate aperture. In fact, Skindigo won't let you choose a pinhole as the camera aperture, you always need a real aperture. This allows for cool effects when you choose different aperture shapes, which I think are also available in KT.
          Most point&shoot cameras have f/8 as the smallest aperture, and when shooting exteriors at noon the huge amount of light by the sun & sky forces the camera to use this setting. Now, if I understand correctly, (please a photographer correct me in this), all render programs's aperture and focal length parameters are in full-frame sensor terms, so unless you're using a full-frame SLR (that is, its sensor is the same size as a 35mm film frame) you would need to use a factor to convert your Point & Shoot settings. For this you would need to know the size of the sensor inside your camera.
          So my advice would be to use the same settings a real full-frame camera would.
          -Miguel Lescano
          • michaliszissiouM
            michaliszissiou
            I agree, using an f8 DOF doesn't look so dramatic in real photography. I can understand this DOF effect near camera but not in the background, not so real. I prefer the PP method BTW.
            Pete, your render looks great anyway 👍
            • tinanneT
              tinanne
              This is a great topic and I've learned a lot from the comments. I haven't done a rendering with DOF yet frankly because I haven't been very successful with my attempts. This topic is inspiring me to give it another try. Thanks, Pete.
              Executive Director : American Society of Architectural Illustrators
              AIP 30 Competition opens soon. ASAI.org
              Architectural Rendering
              • T
                tomsdesk
                We "look" with a DOF, much like a camera (or the camera like us, I guess), but we don't "see" with a DOF (even if we try, we can't really visualize its full extent)...our mind's eye fills the blurry edges with focused info. So to me, an image using much DOF almost always looks "wrong"...unless, of course, the subject isn't really the stuff of the image, but rather the mood, the "place" or "time", the atmosphere and experience of actually being in the space with that stuff in the image.
                So I guess I agree with those here who would apply DOF postpro...artistically calculated for effect, rather than mechanically calculated for "realism".
                2.5D Trees & Shrubs!
                • RichardR
                  Richard
                  I must admit I use a DOF effect in every render though very subtly for general exteriors - I feel images without it never look quite correct, unless you set the camera to f22 you will always get some level of DOF. I tend to use f8>f12 depending on the scene and the focal length chosen (tend to use 25>35mm - SU say 55>70 deg) and obviously proximity of the camera to the main object of focus.
                  When shooting scaled down scenes - like a physical model I tend to use a really heavy DOF to enhance the minature scale of the scene f1.4>f2, something that in pete's image above due to excessive use there has introduce, a tilt lense effect which is seemingly becoming an artform it's self these days!
                  In general I do find that renders done from apps that tend not to utilise true lens characteristics seem to have users shying away from applying DOF and thus some realism in their renders in lost.
                  Nice image BTW pete, though as I suggested DOF is a little excessive!
                  BUILTBRAND.COM.AU
                    Macker
                    I'm a great fan of DOF, but I think the effect has definately been over-done in your scene. DOF is something that must obey real-world laws to look correct imo, otherwise you end up with what looks like a toy-town finish to any shots taken from a distance.
                    For example, I have a 50mm f2.4 macro lens, which when shooting up close objects at f2.4 provides an INCREDIBLY shallow depth of field, probably only a few mm's of the image will be in focus - however, if I take a shot from a distance with the same lens at the same f stop, most of the image will be in focus - this is where a lot of people go wrong with DOF.
                    Also, it begs the question "does the shot need it?". The only time I ever see depth of field used in architectural photography is when the photographer is taking an up-close shot of a detail of the building, or something around the building such as a plant. Any longer shots are almost always crisp and clear shot at something like f16 to f22.
                    Just my 2 cents.
                    Check out my blog @ http://macviz.blogspot.co.uk
                      dacad
                      Hi everyone.
                      Nice topic Guys. I normally think people overuse dof in most render nowdays, either by using just to show off when the image don't even need it or by exagerating the dof effect. The well used dof will allways bring a really sense of realism to the scene, even if very subtle. About doing the dof in render or after in the post process, i'm in favor of doing it in the post, for 2 simple reasons: it's normally faster to render a image without dof and his depth pass; and second because the depth pass will give you much more control over the dof and you can even play with it doing unrealistic results but more suitable for the image, or just redo the post with a more strong or weak dof without having to re-render the image. The key here is control.
                      And if you don't mind the critic Solo, i think that in that image the dof is to strong, making it look a miniature; the colors should have a bigger contrast/saturation, vivid (is this the term? sorry about my english); and the image looks to blurred even in the mroe crisp parts of the dof. (hope you don't mind the critic 😄
                      For anyone interested in more about this (and other things) for realistc renders see this great texts compilations in this forum, there's everything you need to know about realistic render with tips and explantions for everything:
                      http://www.subdivisionmodeling.com/forums/showthread.php?t=13176
                      Check the link guys because believe me it's really worth it.
                      David
                      • soloS
                        Excellent responses guys, and I agree the top image just does not look right, I was not sure if the DOF was to strong or just wrong, to me it has a 'tilt shift' feel, just as you noticed David, it looks miniature.
                        I guess the reason I do not use DOF much is because I cannot be bothered with the extended render times and the lack of control of rendered DOF. So post processed DOF may be something I need to learn, unfortunately I have and probably will always be a Corel Paint Shop user, so if anyone knows a great tutorial in Paint Shop I'd really appreciate it.
                        • daleD
                          dale
                          Couldn't agree more.
                          I took a great workshop from when I was in art school. The instructor had just been fired for insisting students conform to his drawing method, which was to concentrate on the (for instance) still life object, and build up the shadowed areas very slowly that were on the periphery. It was absolutely amazing what would emerge as the drawing was "built" in this manner.
                          You can try this by simply concentrating on an object, any object, in the room you are in right now. If I look at the telephone on my desk, there is a bookshelf to the left of the telephone. My brain as Tomsdesk has stated, is telling me it's a bookshelf, but if I continue to concentrate on the phone and actually see the shapes that in my vision make up the bookshelf they are simply shapes formed by shadows and light.
                          It would be very difficult to render this way, perhaps it would be possible by slowly building up focal layers, I don't know, but I do know when you have seen or tried this process the artificial DOF will always just look out of focus and mechanical.
                            dacad
                            Hi Solo
                            That's a hard thing to ask (at least i couldn't find much info about that for Corel Paint Shop, sorry)
                            I'm more a Photoshop guy but i presume the workflow should be the same just changing the name and the position of the tools in the software. Anyway heres a basic dof tutorial in Corel Paint Shop but without the depth pass:
                            ERROR: The request could not be satisfied
                            (www.brighthub.com)
                            Honestly i advise to see this next tutorial that i'ts more turn to photoshop and uses 2 diferent methods for DOF (and i bet they can be adapt to paint shop). Again this one it's with photos and without using the depth pass:
                            http://www.minervity.com/news/2-ways-to-create-realistic-depth-of-field/
                            This last one is more complete and the final result it's just perfect. It's done in MAX but once you have the depth pass the workflow is the same. The final results and examples show a very good use of depth field in 3D:
                            http://www.onnovanbraam.com/index.php?tutorials/depth_of_field/
                            As i said this last one it's really really good and complete and aimed for 3D, but i advise to see the others too as they will give you a good understanding about the whole process (and possibly a better idea of how to adapt it to Paint Shop).
                            Hope it helps.
                            David
                            • daleD
                              dale
                              Great tut's DacaD. Thanks... The last one is about as good as it gets, although I think it is easier to get the realism on an object at close range.
                              • soloS
                                Thanks David, I noticed that paintshop pro X2 has depth of field, I have version X, so do I upgrade or not is the question?
                                I really need to learn Photoshop, but does my brain have space left to learn yet another app.
                                • brodieB
                                  brodie
                                  Funny you bring this up Pete. I did a DOF experiment over the weekend. This is a Maxwell Render image with no post processing.
                                  http://dl.getdropbox.com/u/384281/dof bed.jpg
                                  I think it turned out pretty well. I think you're right that it tends to work better on small items or studio setups (like the experiment above). One thing I've learned about DOF is that it's very difficult to get any at all on large ArchViz images, simply by nature of camera properties. However, sometimes I find it desirable. Sometimes if you've got trees going off into infinity, for example, it looks odd to have them perfectly crisp and detailed. Alternatively it's good for foreground trees as well so they don't become the focus. Here's an example from a recent project (the image is cropped to illustrate the DOF on the foreground tree).
                                  Without DOF
                                  http://dl.getdropbox.com/u/384281/DOF without.jpg
                                  With Postprocessed DOF
                                  http://dl.getdropbox.com/u/384281/DOF with.jpg
                                  I think you were on the right track with your DOF, Pete, but probably just over did it. Typically what I like to do is create a top layer with all of the merged information from the layers below. Then I'll apply my DOF effect pretty drastically and then decrease the opacity of that layer until it looks right. Usually I'll end up somewhere around 30%. I think it's an effect where you're better off going with too little than too much. Maxwell Render has the ability to create a Z-depth image which helps greatly with DOF in post process.
                                  -Brodie
                                  • RichardR
                                    Richard
                                    Mate PS is really fairly easy to pick up! The depth of what can be achieved though is beyond comprehension! I bought a really good book by - scott kelby, kerby, kelly, ??? Can't even remember the title, but got me straight into it! Great book in that it was just easy and graphic to follow!
                                    There are a ton of them - even a ton of mags in the newsagency dedicated to PS - has to suggest something!
                                    BUILTBRAND.COM.AU
                                    • RichardR
                                      Richard
                                      Brodes!
                                      Mate that first image is a perfect use of DOF, well depending on what you were aiming to show or sell I guess, selling the spread fabric for sure!!!! BTW great satin!!! (oh and chrome)(oh and very nice detailed model on the sheets and covers!).
                                      BUILTBRAND.COM.AU
                                      • soloS
                                        For the last two years I've toyed with the idea of getting PS and dedicating one week (unpaid) time to master it.
                                        But I always procrastinate based on all sorts of excuses like the economy cannot afford me to lose the time, the cost, the effort, etc.
                                        Personally I can do everything I need with Corel, maybe a 3rd party app that just does DOF?
                                        I can extract a depth image from a render, just how to use it?
                                        See image from original render.
                                        http://img4.imageshack.us/img4/8113/depthoffieldimage.jpg
                                        • brodieB
                                          brodie
                                          Here's a tutorial that includes info on how to use that image to create DOF in photoshop
                                          -Brodie
                                          • brodieB
                                            brodie
                                            I get the camera out and pick a subject that best emulates the render. I take a few shots of it starting with a very shallow depth at about f-1.8 to f-4...moving to a long depth at around f22 or higher. I decide which depth is going to work and I set the renderer to that f-stop. I do this every time. If it is set properly it seems to ad a level of realism that you cannot get without it.
                                            Wouldn't it be quicker to just do a few low res test renders?
                                            -brodie
                                            • 1 / 3
