    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Twilight render...
    113 Posts 37 Posters 30.7k Views 37 Watching
    • EdsonE Offline
      Edson
      @edson said:
      kim and fletch,
      your comments and descriptions left me with a watering mouth, not to mention a kind of murderous envy of all of you windows users.
      Edson, I am running it on a mac using VMware Fusion and all seems fine.
      yes, dylan, i know that. i started with podium that way. but it is obviously not the same thing. on the mac side i have sketchup pro, on the windows side free. ideally i would like to keep my workflow as it is. however, for testing it is ok to run it using fusion (which I own).
      edson mahfuz, architect| porto alegre โ€ข brasil
      http://www.mahfuz.arq.br
        Rob D
        (Removed. t'was a bit off topic ๐Ÿ˜ณ )
          Rob D
          Bit off topic so removed it ๐Ÿ˜ณ
          • FrederikF Offline
            Frederik
            No worries, Edson...
            Very soon a Mac version will be available... ๐Ÿ˜‰
            Cheers
            Kim Frederik
              Phil Rader AIA
              Just downloaded the demo....cooking my first twilight rendering. So far I really like the simplicity of this renderer and that it is fairly seamlessly integrated into SU. the intro price is such that I think I'd be silly not to buy it.
              Any plans for future material presets or in general is there a method for adding more material presets easily....I guess I should read the instructions first ...but heck I always just start playing with toys right out of the box before reading the manual..
              http://www.philrader.com
              • Paul RussamP Offline
                Paul Russam
                I must say I'm genuinely impressed.
                I spent 15 minutes last night before I went home tweaking some materials, picked '09 Internal' for the render setting and went home....
                Bear in mind that is is a 60Mb sketchup model that has failed (for me) to render whenever I've tried before.
                This is the origin SU scene:
                http://dl.getdropbox.com/u/373226/Twilight Tests/StPeters-03.jpg
                This is what I got after 14 hours
                http://dl.getdropbox.com/u/373226/Twilight Tests/StPeters-01.jpg
                This is what I got after changing the exposure under camera settings.
                http://dl.getdropbox.com/u/373226/Twilight Tests/StPeters-02.jpg
                More passes and better lighting would help, but damn! not bat for a 15 minute setup.
                Paul Russam
                English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                  dylan
                  Paul that looks fantastic!
                  Can you remember what template you used on the timber benches?
                  Impressive after 15mins playing with mats and stuff.
                  I think it's a real winner this Twilight ๐Ÿ˜„
                  http://dmdarchitecture.co.uk/
                    Paul Russam
                    I don't have SU open at the mo but the materials are something like this:
                    Windows: Architectural Glass - No shadows
                    Columns: Generic - Glossy
                    Wood: Generic - Soft? gloss
                    Chandelier: Metal-Copper
                    Ligtbulbs: 100watt
                    Glass Lamp shades:Frosted Glass
                    Floor: Generic - Soft? gloss
                    Paul Russam
                    • FrederikF Offline
                      Frederik
                      Ooohhh yes... ๐Ÿ˜„
                      And if you know a little about all the material libraries available for KT, you'll be happy to know that you can use all these together with the Twilight render... ๐Ÿ˜‰
                      @Paul...
                      http://www.kerkythea.net/users/Frederik/Anim-Icons/well-done.gif
                      http://www.kerkythea.net/users/Frederik/Anim-Icons/applause.gif
                      Cheers
                      Kim Frederik
                      • StinkieS Offline
                        Stinkie
                        How long does it generally take for orders to be processed?
                        • olisheaO Offline
                          olishea
                          no mac version ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                          oli
                          • FrederikF Offline
                            Frederik
                            The license processing takes place in the U.S. by an actual human being... hard to believe, I know... ๐Ÿ˜‰
                            I presume - but just in case - you followed the instructions properly...?
                            If so, I'm sure it will be along shortly... ๐Ÿ˜„
                            Not yet... But it will be available shortly... ๐Ÿ˜‰
                            In the meantime, I suggest that you follow the advice from Dylan...
                            But like I said... A Mac version will be available very soon...! ๐Ÿ˜‰
                            Cheers
                            Kim Frederik
                            • StinkieS Offline
                              Stinkie
                              Yes ... it is. You should include this info on the 'buy' page.
                              • FrederikF Offline
                                Frederik
                                Good point...
                                But if you had read the instructions you would have seen the following... ๐Ÿ˜‰
                                @chris said:
                                We will process your request and send you your license within 24 hours.
                                Cheers
                                Kim Frederik
                                • StinkieS Offline
                                  Stinkie
                                  Good point...
                                  Touchรฉ! ๐Ÿ˜†
                                  In any case, looking forward to using Twilight. Looks like it'll come in handy for fast 'n easy previz.
                                  Edit: just read the instructions. Guess I'll have to haul my Mac Pro downstairs to hook him (her? it?) up to the net. grumble grumble
                                  • 2 Offline
                                    2kemon
                                    Interesting product Frederik. It seems like you've taken Kerkythea and streamlined it for sketchup users. I guess I couldn't ask for more! Kerkythea has fascinated my since the first release with "the new" studio interface, but I never got the workflow down. And with the introductory price it's a good replacement for my former skindigo workflow.
                                    Is there any difference bewteen the portable version (zip archive) and the installer version?
                                    Spรฆndende app, Frederik. Det lader til i virkelig har stรธmlinet Kerkythea til sketchup brugere. Jeg har virkelig ledt efter en erstatning for min tidligere skindigo eksporter, sรฅ du kan godt regne med mig som kunde ๐Ÿ˜‰ Jeg har altid vรฆret fascineret af Kerkythea, men fik aldrig helt styr pรฅ programmets nuancer.
                                    Er der nogen forskel mellem installer versionen og den alternative zip version?
                                    • F Offline
                                      Fletch
                                      Paul, incredible rendering! 15mins set up time should make any architect happy. ๐Ÿ˜„
                                      Can't wait to see more from you! ๐Ÿ‘ ๐Ÿ‘
                                      and to the very off topic:
                                      @2kemon said:
                                      ... taken Kerkythea and streamlined it for sketchup users. I guess I couldn't ask for more! ...
                                      exactly. ๐Ÿ˜‰
                                      The Zip archive is for anyone that for some reason has troubles with the installer... otherwise... no, no difference.
                                      Looking forward to seeing your work.
                                      Fletch
                                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                        avariant
                                        Paul, WOW, absolutely wow. I hope to see that image on the TwilightRender.com gallery!
                                        • FrederikF Offline
                                          Frederik
                                          Great to see another Dane here... ๐Ÿ˜„
                                          No - there's no difference in the zip-archive vs. the installer version...
                                          If you are having issues with the self extracting installer, download the zip file and extract the contents to Google Sketchup 7 / Plugins, or Google Sketchup 6 / Plugins.
                                          Looking forward to see you as a future Twilight render user... ๐Ÿ˜‰
                                          Cheers
                                          Kim Frederik
                                            Come on, Majid,
                                            You know all ins and outs of Kerkythea - Twilight should of course be easy for you!
                                            ๐Ÿ˜„
                                            • 4 / 6
