    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    The Garden Pond
    14 Posts 8 Posters 1.2k Views 8 Watching
    • EarthMoverE Offline
      EarthMover
      This is a pond and waterfall I modeled as part of larger project. Rendered in Max & Vray, with a good bit of PP in PS.
      Content Creator at Skapeup
        smokinbakin
        That water looks very nice. Maybe you should add some displacement to those pebbles though, they look a bit flat. Also, if you do not mind, can we see the raw render?
        "Set your goals low, and hope you don't get lower"
        • plot-parisP Offline
          plot-paris
          the water is very good indeed. well done. (would love to have such a pond in my garden right now (the temperature is yet again climbing above 30 - in the mountains!) ๐Ÿ˜‰
            d12dozr
            Good image overall ๐Ÿ‘ , but I agree the rocks look off a little.
            http://goo.gl/f7ooYh
              liam887
              nice i would also like to see the raw render and iff possible the geometry of the model, if not its ok, is the flow actually modeled like cloth with a see through texture or is that all post production?
              VISIT MY ONLINE GALLERY
                EarthMover
                Thanks Guys.
                Here are the sketchup lines and a screenshot from Max, as well as a step by step to how I made the base waterfall mesh and the water. Unfortunately I saved over my raw render.
                There was quite a bit of PS on this one to smooth out some of the geometry for the rocks and add a few more. I also did the water effects in photoshop using a set of Ron's splash brushes.
                SU geometry
                3ds Max Screen Shot
                Drawn Base map for the waterfall
                Push Pulling the drops
                Run Subdivide and Smooth with 2 iterations.  Also add construction points to all the height changes
                Use Projection Tools v.2 to project the construction points on to a parallel surface.  Connect construction points with the line tool.  Use extrude lines along vector to pull out  the water surface from the consctruction points.  Use Joint Push Pull to add depth to the water.
                Move the water into place and use FFD to bend the water to follow the falls. Then add boulders around the perimeter.
                  liam887
                  wow thanks for posting that little explanation for me it really helped. Organic modeling ive always found harder but ill nail it one day, nice work anyway thanks.
                  • olisheaO Offline
                    olishea
                    yeah nice work dude, lovely image. how did u set the construction points at the height changes?
                    oli
                      kwistenbiebel
                      Nice tutorial and great looking result.
                      Thanks for that Earthmover! ๐Ÿ‘
                        EarthMover
                        Oli, I just used the "Insert Guide point" tool that comes with Projection Tools 2. Then just click where you want to add them.
                        Now that TIG made the Drape Cpoints Ruby for me, I'd probably use that for the water instead and cut down on the amount of steps to make the water.
                        • olisheaO Offline
                          olishea
                          thanks for your reply. sorry to be a pain in the almighty, but could you possibly post the link to projection tools? cant find it. cheers
                          oli
                            EarthMover
                            No Problem Oli! http://forums.sketchucation.com/viewtopic.php?f=180&t=20140
                            I've grown to really love these tools!
                            • olisheaO Offline
                              olishea
                              thanks......oh those projection tools. I feel bit stupid now.
                              nice image anyway, cant wait to see more.
                              oli
                              • E Offline
                                ENG. YASEEN
                                Its a great work Mr EarthMover
                                I love it ๐Ÿ˜„
                                My Website:
                                http://xyz4studio.blogspot.com/
