    [Plugin] Extrapolate Colors v1.0
    29 Posts 15 Posters 42.0k Views 15 Watching
      trillium
      thank you sooooooo much chris for all your wonderful rubies!!! i'm working on a pool with glass tile blend and this is just perfect!!! ☀
      • boofredlayB Offline
        boofredlay
        Nice one Chris.
        • Chris FullmerC Offline
          Thanks Dave, Trillium, and Eric.
          I already see places to tweak it and make it better.
          For example, currently if you have a face that is cut in 2, but the dividing line is hidden/smoothed, it still counts as 2 faces. I would prefer if the tool determined what a "face" was the same way that the selection tool does. It adds all faces together that have smoothed edges.....if that makes any sense.
          Anyhow, I know Fredo already provided me with a snippet that will help fix this. But it will take a little while to get it worked into my script. But I might do it today, because I could really use the fix for a project I'm working on 😄
          • EarthMoverE Offline
            EarthMover
            Thanks Chris this will be very helpful and a lot easier than the random painter method.
            Content Creator at Skapeup
              Aerilius
              This is great! It reminds me on an atlas: There exist also (complicated?) mathematical algorithms that prevent neighbouring faces from having the same color.
                @Aerilius - I had not considered it, but that would be an interesting idea. I'm not sure what the algorithm would be, but there is probably something online to describe it.
                @Adam - I was waiting for you to chime in. I think this script is useful for a lot of things that us landscape architects do. I hope you find it useful.
                The plan is to put it into a webdialog with a few more feautes, better control over the amount that materials should be applied, overwrite existing colored faces, redoing it (in case it comes out a little wrong the first time so you can quickly re-apply the textures), etc.
                Hopefully in time I'll get the mode in-depth version made.
                  Jim
                  I guess I am more curious about if the pavers shown in the video were hand-made, or made using a plugin?
                    I cut them with my lazer eye vision.
                    or I might have drawn them all by hand using the freehand tool, and lattice-izer to do the offsets for me. Then Shapebender to put a nice light bend to my path.
                    I am still thinking about ways to do procedural hatches in SU - for things like brick and stonweork and all sorts of hatches.
                      EarthMover
                      Chris,
                      As soon as I saw the plugin in use, I thought of procedural hatches as well and how nice it would work with them. I have a repeating flagstone pattern that I made and which I use to make a hatch manually for certain projects. I ran it through lattice-izer and then ran extrapolate colors on it and it work like a charm. I'm stoked about the results. Thanks again.
                        Awesome, that looks really good Adam! I hope this little script saves you time in the future. Its already saved me a bunch!
                          EarthMover
                          Chris...this is a stretch, but could the script be tweaked to also work with groups and subgroups? If you were to have a group of bricks consisting of each brick as it's own subgroup and you wanted to random texture each brick, would it be possible to extrapolate the colors from 3 or 4 groups and randomly distribute them to the other groups, doing so in a way that all geometry within the subgroup be textured with the same material, but randomly painted from one group to another?
                          Like I said, I know it's a stretch, but it would help me a lot.
                            Yeah, that is something I would like to add. My question is hsould the script only sample materials applied to the outside of groups? Or should it search all the geometry insde of groups and use all materials found?
                            Should it then apply materials to the geometry inside groups, or should it just apply materials to the outside of groups?
                            I was thinking that it would only sample materials applied to the outside of groups and components, and then only apply them to the outside of groups/components. This method would make it easier to apply a single material to all faces of a single group. But it would be impossible to apply different materials to each face in a single group.
                            I could theoretically add toggles and switched so that the user could specify each of these possible variables. It would have to be done in a web dialog, but that is my current project. So maybe I could try to work all these options into a single web dialog version of this script (which I'm working ont at the moment).
                              Aerilius
                              I found something about painting no two adjacent regions with the same color. I twas used in the past for maps when printing techniques did not allow a large color diversity.
                              http://en.wikipedia.org/wiki/Four_color_theorem
                              I think the script would need to check each face's neighbouring faces.
                                kwistenbiebel
                                Wow, great work there chris!
                                Indeed much easier to use than the randomize color plugin, which already was great by the way.
                                This is the first step to having Procedural texturing in Sketchup.
                                Fantastic!
                                  EarthMover
                                  I'd imagine applying to the outside would be much easier to code. That would work for me. Vray for Sketchup hates materials applied to the outside of groups, but I usually run Matt666's Remove CG Materials script to transfer those materials to the inside of the group before using VfSU anyway.
                                  The web dialog sounds promising. In Max, there is a material by element modifier that I use to do this task. It gives you a dialog with two options.....either Random Distribution, or By Frequency. The By Frequency option lists the materials according to their material ID # and lets you adjust a percentage number for each material to determine how frequently it shows up in the assigned mesh. You can also set the material ID # of each element (group) within a mesh and assure that that element will only get one material, while the others get random. In the example of bricks, the mortar joint would be set to an ID # that get's 100% frequency, while the bricks may get an ID set to 4 different textures distributed at 25% of each.
                                    Jim
                                    require 'Sketchup.rb'
                                    Come on, Chris! 😆
                                      Come on, Chris! 😆
                                      I'll try a little Jedi mind trick like ThomThom...
                                      You saw nothing wrong Jim. Redownload the script, you'll see there is no sloppy bad-coder typo there. There is nothing to see.
                                      -fixed and reuploaded, thanks Jim! That fixed a menu bug I was experiencing too.... 😕 Man I am bad at this programming stuff, and I think I'm getting worse!
                                        dominion
                                        Chris this plugin rocks however not being able to use it on components is causing me some serious difficulty if I explode all my component blocks to the outside edge in the render then the textures are no longer tiled correctly for some reason, any idea of a work around?
                                        Render
                                          Hmm, could you upload a model that is not working right? I'm sure I could get it to work for you.
                                            dominion
                                            Hi mate sorry it wont let me upload the model says its to big (5mb)
                                            can i email it to you?
