    Texture Position
    10 Posts 2 Posters 1.2k Views 2 Watching
    • E
      e-anima
      i imported a 3ds file into Sketchup. The result was the textured model, but the texture was kind of twosided. from the outside it was for example a wall and from the inside the same face had a texture of the roof. (model is 100% ok, passed STL check and has no double sided faces).
      The solution to fix this is to select every triangle go to texture-> position , do nothing and klick done. So my idea was to make a script that does this to every face. What i did is the following, i put every information in an array. Now iam searching for the functions to do this. ( something like face[1].setPosition(getcurrentPosition(face[1])) ).
      Maybe you can help me with some snippets.
      Thank you
      Marco
      model = Sketchup.active_model
      entities = model.active_entities
      selection = model.selection
      faces = []
      entities.each do |e|
      faces.push e if e.is_a? Sketchup::Face
      puts "Total Faces : " + faces.length.to_s
        Not sure what you're trying to do... Remove the texture from the backsides? Transfer them?
        Why do you need to do Texture->Position ?
        The API methods you want to look into in regards to position textures are:
        Face.position_material http://code.google.com/apis/sketchup/docs/ourdoc/face.html#position_material
        UVHelper http://code.google.com/apis/sketchup/docs/ourdoc/uvhelper.html
        TextureWriter http://code.google.com/apis/sketchup/docs/ourdoc/texturewriter.html
        I got two plugins that works with UV mapping. One is transferring front side to back side, and the other fits texture materials to quad-faces.
          Do you have a sample model?
          • E
            e-anima
            transfers front side to backside sounds nice. ill take a look. thank you
            installed your uv tools. selected a face and tried to transfer...nothing happened.
            i think somehow sketchup is not able to import a 3ds correctly with uv coordinates.
            what i was trying to to fixes the wrong "pseudo non existing double faces".
            if i understood right you use that method to transfer the uvs. hmm so what i want to do will not work, because the transfer does not work.
            your plugin is working if i first do a "fit texture to quad faces". problem is mine is triangulated and already textured correctly from the outside
            • E
              e-anima
              yes. heres some testwall with the test texture
              sketchup file
              texture
              • E
                e-anima
                have you seen what i meant?
                  The material was transferred to the backside fine - No problems or error. (SU7 - PC)
                  What version and OS are you using?
                    Did you select all the faces first?
                    • E
                      e-anima
                      I use
                      Sketchup 7.0.8657
                      Windows Vista Ultimate 64 bit
                      Is it only working if i select all faces (without edges) ?
                      i chose all faces and klciked FRONTFACE TO BACKFACE and nothing changed
                      Where did you get the output ?
                        It only transfer the material of the selected faces. (Doesn't matter if you select edges, they are ignored.)
                        Where?
                        The Backside of the faces will look like the Frontside.
