    Silvershadow's Eye Candy 3 - H.M.C.S SNOWBERRY
    117 Posts 85 Posters 99.8k Views 85 Watching
      silver_shadow
      yea i know. The ocean was a last minute thought. I modeled it, but actually had second thoughts of putting it with my boat in the final renders. After doing 244 renders, i decided to do 3 more, but i had so many of them already. I did test all the sides on a small scale and decided to do only these 3. But you're absolutely right.
        stevebo
        That is an incredible amount of work mate! Thank you for sharing this with the SU community!! You really have taken SU to the next five levels!
        I will definitely be taking a look at your model! (Then probably cry afterwards)
        Also, probably the best topic for me to be making my first post on these forums! ๐Ÿ˜„
        • daleD Offline
          dale
          Well, I went away for a couple of days, and came back to find the most amazing, incomparable modeling work I have ever seen.
          I really thank you also for the amount of effort you put in to posting this.
          I have learned a lot from studying your work and process.
          Thanks for sharing.
          • EarthMoverE Offline
            EarthMover
            Jacques, I can't believe you shared all your models with us. Amazingly generous of you. I will be studying these in depth and hope understand your process. Again, thank you sincerely my friend!!!!
            Content Creator at Skapeup
              cadmunkey
              Man, your dad would be proud, I'm speechless right now. Superb.
              • 1 Offline
                11zulu
                Bugger me I am in disppear... I was due to start on my 1st SU model & guess who steps up to steal my thunder but the Master.
                Question: I suspect it weighed in at 25+megs what was the poly count? [How on earth did SU not crash!!!]
                Very good work mate.
                  jopsa2
                  it's so weird orbiting around the models and seeing they're made of edges and faces, and not some other magic object ๐Ÿ˜„
                  I have a question though; I've read you use vray for rendering, but noticed you have plenty of components within components (and within components and within components...), when I do this vray simply ignores the objects more than one group "deep" and they dissapear. Is this only me, or am I missing something?
                  Thanks!!
                    MrWip
                    Silver_shadow... it's really hard to know how to write something that does reflect the true effect of your work on someone passionate by the beauty of modelisation...
                    ....so I guess THANKS will cover the wide range of sensation created by you're wonderful work...
                    http://www.wip-archi.com
                      Sharing this model is that we name "the great class" ๐Ÿ˜Ž
                      In this case why not put it in 3Dwarehouse? You will have more glory! ๐Ÿ˜Ž
                      And will have the top one! ๐Ÿ‘
                      and save your bandwidth ๐Ÿ˜‰
                      Ps It's me or there is no engine house? ๐Ÿ˜‰
                      • urgenU Offline
                        urgen
                        ....BRAVO
http://img248.imageshack.us/img248/300/appl.gif
                        --pupil forever...------
                          silver_shadow
                          Thank you
                          • holmes1977H Offline
                            holmes1977
                            Shadow is your wife happy to have her husband back ๐Ÿ˜‰
                            Exaggeration makes a dull story better.
                            • erikBE Offline
                              erikB
                              As Solo already mentioned earlier that it would be amazing, I can only fully agree it is a m a z i n g ! ๐Ÿ‘
                              greetings, erikB
                                JuanV.Soler
                                Beautiful, Refreshing, a Guide to learn
                                Congratulations ๐Ÿ˜„
                                and many thanks for sharing, Silver ยกยกยก
                                  mrtek
                                  ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ You're not a man. You SkyNet
                                    rcossoli
                                    impressive work ๐Ÿ‘ ๐Ÿ‘
                                    with that type of machine work to move such as complex geometry and models?
                                    THREEDIMENSIONSWEB dot COM
                                    • boofredlayB Offline
                                      boofredlay
                                      Again, brilliant work and thanks for sharing so much of it.
                                      Something I have always been curious about Jacques, did you model your avatar? If so, was it in SU or another app?
                                        beegee_tw
                                        amazing.....inspirational work.
                                          Sir
                                          Creating SilverShadows Eye Candy 3 - H.M.C.S. Snowberry, by Jacques Cleghorn.
                                          404 Not Found
                                          (www.sketchucation.com)
                                          cool! can you make the text about double the size tho?
                                            materialdb
                                            WOW ! .. THAT is extra-ordinary!! awesome detail in SU !
                                            I especially love those ropes and "random" stuff that's kinda organic.
                                            loving it!
                                            ๐Ÿ‘
                                            free vismat materials: http://www.material-db.com
                                            • 3 / 6
