    [IDEA] Platform / Street levelling / fixing script
    14 Posts 4 Posters 1.2k Views 4 Watching
    • G
      godswife
      i just wanted to add: if there is nobody which can realize such a script (which i would understand), does anybody have a hint how to do this kind of thing easier in any possible way to save some time? any suggestions are more than welcome!
        The terrain is generated from a 3D CAD drawing?
        • Extract the road edges.
        • Stitch together the road surface. (I think there's plugins that will help you do this)
        • Stamp the road onto the terrain. With optional radius
        • PixeroP
          Pixero
          I have a script JS Align that can kind of do this.
          Select edges and run plugin.
          There might be issues with non triangle surfaces and such so be sure you backup before use.
          http://www.pixero.com
          • G
            godswife
            thanks for your replies guys!
            @thomthom
            yep, the terrain was made from a 2d cad file (containing contours only). the streets are a seperate 2d file and don't have any kind of height information. the way you describe it would work for straight/level streets indeed, but not if there is any difference in height.
            @pixero
            your script is basically the perfect start for the script i am looking for. it just needs the calculation routine to be able to make slopes, additionally to just aligning it to one chosen level (max, mid, min). it does help me with the level roads though, same as thomthom's idea. actually, it solves the problem seen on my screenshots.
            both your methods work perfectly to get 100% level areas, but that doesn't occure as often as slopes in this terrain. i guess there is not ruby to get around that out yet.
            [edit] i see what you mean with your script might cause problems pixero. i just tried it as seen on the attached screenshots. it makes a nice and smooth road, but there are lots of faces lost afterwards. and in a weird way. they are not just deleted (which would leave empty, white holes), something still seems to be there, but i can't select anything.
            • PixeroP
              Pixero
              godswife, have you seen this thread?
              Road on terrain: http://forums.sketchucation.com/viewtopic.php?f=18&t=19522
              Thomthom, maybe you could tweak something useful out of my script.
              Like adding falloff based on a gauss curve and averaging the points position?
              (I'm in the middle of rendering a looong animation and dont have time to look into it at the moment.)
              • G
                godswife
                no, i haven't see that topic yet, but the tutorial in it describes almost the same way i am doing it now. for small areas okay, but if you have a terrain with a couple of square kilometers and lots of roads, it's a huge time consumer.
                it would be awesome if somebody could enhance your already nice script. i have not enough experience in coding to try myself πŸ˜• it sure would be a huge plus for the community.
                any idea why it messed up those faces when i tried your align ruby?
                • PixeroP
                  Pixero
                  I think it has to do with the fact that when used on lines/points it moves them one by one thus making polygons nonplanar even if its just while the script is running. There was another topic in this forum about how to move several items at the same time. I think that would help. Cant remember the name of the poster now.
                  • Chris FullmerC
                    It might have been a thread I was involved in. Use entities.transform_by_vectors to move multiple entities at the same time, but by different distances.
                    Error 404 (Not Found)!!1
                    (code.google.com)
                    You build an array that holds your entities and an array that holds a vector that describes the direction and distance to move each entity. The vector array needs to be in the same order as the entity array.
                    That makes SU move them all at the same time, making for a MUCH cleaner move.
                    • PixeroP
                      Pixero
                      Chris, I have done the transform_by_vectors changes and that seem to work fine.
                      However there still is the problem when using the script on edges inside a group. Then the face gets put outside the group and at 0,0,0. πŸ˜•
                      Any idea how to fix that?
                      • G
                        godswife
                        thanks, i understand the cause of the error now. initially i thought it does the same as i am doing (higher/lower each POINT, not LINE). is it going to work when i explode the group before i use your script? is it possible to change the script to the way that it only changes the height at the connecting points instead of working with the lines?
                        • PixeroP
                          Pixero
                          I think I have fixed it in the updated version here: http://forums.sketchucation.com/viewtopic.php?f=180&t=20080
                          • G
                            godswife
                            nicely done, works like a charm now! what i like even better: it's possible to undo it with one click (before it was undoing point by point). now we just have to find somebody, who can integrate the discussed functions to make it perfect.
                            • G
                              godswife
                              nobody got time for this at the moment? 😞
                              how hard is it to get this programmed on a scale from let's say 1 to 10? let me know and it might be easier to stay patient! πŸ™‚
