    [REQUEST] Plugin - Section moving tool
    1 Posts 1 Posters 662 Views 1 Watching
    • I
      idraft
      keeping you busy! Jim and idea for you.
      PLUGIN - Moving cross section tool.
      PLUGIN - SECTION MOVE TOOL
      An idea - for you mad Plugin freaks! maybe you can give this some heads up? 😎
      I'm continually frustrated with not being able to move the cross sections once place in SU, ( other than using the move tool - this is a PAIN!). You have to pan from your view, adjust the section plane, then pan back again, most of the time - for me anyway - going from the parallel view (where I view and generate my sections from) to perspective view , then back again.
      It would be great if better control over the section plane was possible. I wonder whether a plugin using the arrow keys in the Parallel view would allow you to adjust the location of the cross section position? eg left pan / right pan & forward and back pan? There may need to some kind of control on the speed of the pan or whether it pans in jumps (eg 1m or 2m). What do you reckon, Is it possible ❓
      Cheers Jeff.
