    Yet another SavePanel question
    5 Posts 3 Posters 496 Views 3 Watching
    • T
      talig
      Hi everyone,
      I have a savepanel question for you guys.
      Is there any way to tell from the code if a savepanel was closed using "Cancel" or using "Ok"? Tried the documentation, didn't find any access to that particular thing.
      Maybe you know if this sets some bit or something like that?
      Thanks a bundle,
      • TaliG
      Avatar: all rights reserved to Bryan Eppihimer
        The manual says it returns nil if the user cancels. Is that not so?
          Jim
          I think savepanel returns the selected path and filename as a String, or either false or nil when the Cancel button is used.
          file = UI.savepanel
          if file
            # maybe check for other possible bad input,
            # do something useful with file.
          else
            # use hit cancel
          • T
            talig
            I'm pretty sure I've tried these. I'll try it again...
              Test the return value. The manual has been wrong before. It might be false or en empty string.
