    UPDATE:poor mans joystick
    16 Posts 6 Posters 3.4k Views 6 Watching
      phy
      Oh nothings working for me now 😳 😢 😞 IT had been working. Put your other controllercommands in a safe place before installing.
      Does it work for any of you?
      Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
        MrPlanet
        Please, be proud of yourself, you have really outdone yourself! (And it works 😄 )
        I reject your reality and substitute my own.
        • W Offline
          Wacov
          Nothing big, but it's a good mod (People can finally stop complaining!!)
          After you download this, look at http://sketchup.google.com/3dwarehouse/details?mid=2089b6db29e339096cd8ad826e9017b8 ... it's one of my models that gets MUCH better when you can use the joypad-only features 😄
          Oh, and you'll be able to play the normal version of MotorSketch. Not that there's much difference.
            phy
            OK I musta messed something up after I uploaded it I'll keep trying to put more buttons on.
              phy
              Ok guys here's the file. NOTICE lb & rb do not work. the controls: joyRY=8&5, joyRX=4&6, a=7, b=9, x=1, y=3. That's all I got right now.
              Put this file in place of "controllercomands" in <plugins><sketchyphysics3>.
              CPhillips is it possible to get lb and rb working
              EDIT: the buttons a b x y weren't working in the update they do work.
              ControllerCommands.rb
                CPhillips
                Cool! Thanks for doing this. If everyone likes it I will make it part of the next release.
                  phy
                  Ok I'll soon have all the keys working. start,select, etc.
                    phy
                    The finished project Ahhhh. controls: joyRY=5&2, joyRX=1&3, a=4, b=7, x=8, y=9, lb=0, rb=6, back=minus(-), start=plus(+), leftb=divide(/), rightb=multiply(*) Woohoo 😍
                      phy
                      Tell me if something doesn't work right
                        CPhillips
                        Thanks Phy!! Could you do me one favor. Break out the changes you made so I can update the code. My version has changed so much I am not sure I see all your changes.
                        Thanks Again!
                          phy
                                  a=(@joystate.rgbButtons[0]/-128)+(key('numpad4'))
                                  b=(@joystate.rgbButtons[1]/-128)+(key('numpad7'))
                                  x=(@joystate.rgbButtons[2]/-128)+(key('numpad8'))
                                  y=(@joystate.rgbButtons[3]/-128)+(key('numpad9'))
                          For the a, b, x, and y keys I just added +key('numpad 4 7 8 9') to the script that was already there.
                          I used your joy('rightx') script for the joybutton('a b x y lb etc.).
                          def joybutton(name)
                                  name.downcase!
                                  deadzone=100
                                  case name
                                      when "a"
                                          if(@joystate.rgbButtons[0].abs>deadzone)
                                              return (@joystate.rgbButtons[0]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD4)?1;0.0)
                                      when "b"
                                          if(@joystate.rgbButtons[1].abs>deadzone)
                                              return (@joystate.rgbButtons[1]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD7)?1;0.0)
                                      when "x"
                                          if(@joystate.rgbButtons[2].abs>deadzone)
                                              return (@joystate.rgbButtons[2]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD8)?1;0.0)
                                      when "y"
                                          if(@joystate.rgbButtons[3].abs>deadzone)
                                              return (@joystate.rgbButtons[3]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD9)?1;0.0)
                                      when "lb"
                                          if(@joystate.rgbButtons[4].abs>deadzone)
                                              return (@joystate.rgbButtons[4]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD0)?1;0.0)
                                      when "rb"
                                          if(@joystate.rgbButtons[5].abs>deadzone)
                                              return (@joystate.rgbButtons[5]/-128)
                                          else
                                              return (getKeyState(VK_NUMPAD6)?1;0.0)
                                      when "back"
                                          if(@joystate.rgbButtons[6].abs>deadzone)
                                              return (@joystate.rgbButtons[6]/-128)
                                          else
                                              return (getKeyState(VK_SUBTRACT)?1;0.0)
                                      when "start"
                                          if(@joystate.rgbButtons[7].abs>deadzone)
                                              return (@joystate.rgbButtons[7]/-128)
                                          else
                                              return (getKeyState(VK_ADD)?1;0.0)
                                      when "leftb"
                                          if(@joystate.rgbButtons[8].abs>deadzone)
                                              return (@joystate.rgbButtons[8]/-128)
                                          else
                                              return (getKeyState(VK_SEPARATOR)?1;0.0)
                                      when "rightb"
                                          if(@joystate.rgbButtons[9].abs>deadzone)
                                              return (@joystate.rgbButtons[9]/-128)
                                          else
                                              return (getKeyState(VK_MULTIPLY)?1;0.0)
                          And for joyRX & joyRY I used this.
                            joyRX=0.5+(getKeyState(VK_NUMPAD3)?0.5;0.0)+(getKeyState(VK_NUMPAD1)?-0.5;0.0)
                                  joyRY=0.5+(getKeyState(VK_NUMPAD2)?0.5;0.0)+(getKeyState(VK_NUMPAD5)?-0.5;0.0)
                          There's probably some bad scripting in there somewhere.
                            phy
                            I have added numpad support on the newest version for joystick. The file is in the first post.
                            I think you can use a joy stick with the file too. Can one of you guys that have a joystick confirm that for me?
