    SketchyPhysics doesn't work!
    28 Posts 5 Posters 4.1k Views 5 Watching
      JaViXP
      Yeah, the installer is pointed right, but SP doesn't load now. Look at the attachemented picture.
      "Giving up is way harder than trying"
      JaViXP's Rendering
        CPhillips
        You have a seriously hosed install somehow. The function (file_loaded?) is part of Sketchup. If that isnt working nothing else will.
        I would suggest that you rename your google sketchup directory. Reinstall Sketchup then install SketchyPhysics using the installer. If that doesn't work then there must be a problem with your system.
          JaViXP
          I have reinstalled SU and Skethyphysics (all the other plugins too), I can make my own models and make them work, but Hobbnob's still isn't working...
          JaViXP's Rendering
            CPhillips
            So am I a clear; At first no models worked. But after reinstalling all except one work? And its throwing the same error?
            Which model fails?
              MrPlanet
              Why don't you try the .ZIP one?
              I reject your reality and substitute my own.
                JaViXP
                CPhillips, this is the model that doesn't work (link below).
                http://sketchup.google.com/3dwarehouse/details?mid=4befa4eb8414c37c6227cba038bf7c95
                Mr Planet, if it still like this, I will try with the .zip file. πŸ˜„
                JaViXP's Rendering
                  CPhillips
                  I dont know why that model is failing for you. It works fine for me.
                  Again is it true that all models used to throw the error and now just this one?
                    JaViXP
                    Well... I downloaded two models more and they didn't work, I can only make work my own models. Maybe it is because SketchUp.
                    JaViXP's Rendering
                      CPhillips
                      Are you trying to download the models from inside sketchup? You need to use a regular browser and download them to disk before opening.
                        JaViXP
                        Uh oh! Maybe that's the problem (I don't think it is my web browser (I have Firefox)), I hardly ever save a model in the HDD before opening (principally because it will keep saving instead of opening).
                        JaViXP's Rendering
                        • 2 / 2
