    SketchyPhysics doesn't work!
    28 Posts 5 Posters 4.5k Views 5 Watching
      JaViXP
      Hmmm... I won't format my PC (again), I did it like 3 times in two weeks.
      "Giving up is way harder than trying"
      JaViXP's Rendering
      • C
        CPhillips
        My guess is it is a conflict with some other plugin. What else do you have installed.
          JaViXP
          Tools on Surface, 1001 bit tools (it doesn't work though), Rounded Edges, Indigo, iRender, Loft, Skin, Loop Subdivision Smooth and SketchyPhysics. πŸ˜„
          JaViXP's Rendering
          • C
            CPhillips
            Ok there very well may be a conflict in there somewhere. Can you remove everything but SP and see if it works?
              JaViXP
              I did it and it looks like SP isn't installed... I'll reinstall it. πŸ˜„
              JaViXP's Rendering
              • C
                CPhillips
                That would do it. πŸ˜„ Make sure the installer is pointed to the right path.
                  JaViXP
                  Oh, what I did was copy and paste to other folders the .rb files (exluding the SketchyPhysics ones)... I am going to install it again. (Oh, and try to download Hobbnob's latest tank, it is the model I can't run).
                  JaViXP's Rendering
                    JaViXP
                    Yeah, the installer is pointed right, but SP doesn't load now. Look at the attachemented picture.
                    JaViXP's Rendering
                    • C
                      CPhillips
                      You have a seriously hosed install somehow. The function (file_loaded?) is part of Sketchup. If that isnt working nothing else will.
                      I would suggest that you rename your google sketchup directory. Reinstall Sketchup then install SketchyPhysics using the installer. If that doesn't work then there must be a problem with your system.
                        JaViXP
                        I have reinstalled SU and Skethyphysics (all the other plugins too), I can make my own models and make them work, but Hobbnob's still isn't working...
                        JaViXP's Rendering
                        • C
                          CPhillips
                          So am I a clear; At first no models worked. But after reinstalling all except one work? And its throwing the same error?
                          Which model fails?
                            MrPlanet
                            Why don't you try the .ZIP one?
                            I reject your reality and substitute my own.
                              JaViXP
                              CPhillips, this is the model that doesn't work (link below).
                              http://sketchup.google.com/3dwarehouse/details?mid=4befa4eb8414c37c6227cba038bf7c95
                              Mr Planet, if it still like this, I will try with the .zip file. πŸ˜„
                              JaViXP's Rendering
                              • C
                                CPhillips
                                I dont know why that model is failing for you. It works fine for me.
                                Again is it true that all models used to throw the error and now just this one?
                                  JaViXP
                                  Well... I downloaded two models more and they didn't work, I can only make work my own models. Maybe it is because SketchUp.
                                  JaViXP's Rendering
                                  • C
                                    CPhillips
                                    Are you trying to download the models from inside sketchup? You need to use a regular browser and download them to disk before opening.
                                      JaViXP
                                      Uh oh! Maybe that's the problem (I don't think it is my web browser (I have Firefox)), I hardly ever save a model in the HDD before opening (principally because it will keep saving instead of opening).
                                      JaViXP's Rendering
                                      • 2 / 2
