    Is it possible...
    13 Posts 3 Posters 1.1k Views 3 Watching
    • W Offline
      Wacov
      ...to create very simple geometry on-the-fly, with no modifications to SP's code? What I mean is, say in my cloth model, you could draw lines between the pieces every frame, to create a face. Paint it with a material, smooth it, and you have seamless cloth!
        Physicsguy1
        if you have a sticky object, yes. look at the example:
        cool thing.skp
        • W Offline
          Wacov
          That's pretty cool, but I've seen it before and won't do what I want πŸ˜„
          I'll probably be able to make this work, I know it's possible to draw lines from point to point. I just wonder if it'll make the faces, and how I can smooth them...
            CPhillips
            In theory it should be possible. But it really doesnt have much to do with SP. You would build it using the Sketchup Ruby API. But I warn you that skinning inst very easy. And doing vertex level operations (skinning) in Sketchup is really slow.
            • W Offline
              Wacov
              The cloth is effectively a 3x3 grid... so, 18 polys. Think that'll run at a reasonable rate? (And could you direct me to a basic API tutorial? πŸ˜„ )
                CPhillips
                I dont know of a Sketchup Ruby API tutorial. Mostly I just look at examples. Here is the API:
                http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-classes.html
                You probably want to look at Entities, Face and Edge
                Here is how you add a face for example:
                Sketchup.active_model.entities.add_face([[0,0,0],[10,0,0],[10,10,0],[0,10,0]])
                  Physicsguy1
                  Woah!!! I never knew i could make a face during the simulation. is it possible to make a component out of the faces during the sim?
                    CPhillips
                    grp=Sketchup.active_model.entities.add_group
                    grp.entities.add_face([[0,0,0],[10,0,0],[10,10,0],[0,10,0]])
                    Here is how you can make a cube.
                    face=grp.entities.add_face([[0,0,0],[10,0,0],[10,10,0],[0,10,0]])
                    face.pushpull(-10)
                      Physicsguy1
                      The only problem is that the objects created during the simulation are static until the next simulation.
                      • W Offline
                        Wacov
                        I thought of that... it should be possible to make the geometry at the first frame, then move each point to the desired position every frame afterwards... but, well, I need to find out how πŸ˜„
                        (I don't really see the point of making a group, when you can just use emitters?)
                          Physicsguy1
                          Wacov, I was able to create an endpoint editor. I was also wondering if there was a way to easily delete the extra faces created. Anybody have any suggestions?
                          node editing.skp
                            CPhillips
                            face=Sketchup.active_model.entities.add_face([[slider('X')*10,slider('Y')*10,0],[10,0,0],[10,10,0]])
                            face.back_material=[255,45,90]
                            face.erase!
                            Maybe instead only create the face once and then move the points rather than recreating the face.
                              Physicsguy1
                              I'm not sure how I would do that right now. Right now all I can do is set the desired position of the nodes and then press space to create the face.
