    Difficult kitchen Interior design ?!!
    14 Posts 7 Posters 1.3k Views 7 Watching
    • E
      ENG. YASEEN
      Thank's "lucifer1101" and "cadmunkey" of ur comment....
      I attached A DXF file of the plane
      Good Luck
      dxf file of akitchen
      My Website:
      http://xyz4studio.blogspot.com/
      • L
        lucifer1101
        here i have made it into a 3d model to make it easier to use if anyone wants to throw the op some designs...
        kitchen.skp
        Some of my 3d
          sepo
          One big no no...direct door from the kitchen to the bathroom. Can you swap store and bathroom.
          • FrederikF
            Frederik
            I was thingking the exact same as Sepo...
            But local rules might be different in some countries...
            Nevertheless I would never place a bathroom/toilet in direct connection with the kitchen...
            Cheers
            Kim Frederik
            • L
              lucifer1101
              interesting now that i think about what you pointed out it made sense but from what i have read i get the idea that the plan isnt meant to be changed just the kitchen, so in order to make it right hes going to need to put the dining over towards the bathroom then, a little reorganizing should do the trick....
              Some of my 3d
                sepo
                Also it is slightly confusing to have bathroom in the kitchen/dining area. I could understand tiolet and it should be next to entrance to the room if at all. The toilet should be really accessed from the corridor.
                Regardless of any building regulations it is something which kind of makes sense. Never sh*** where you eat πŸ˜‰
                • BepB
                  Bep
                  Some tip's
                  I would turn the oven 180 degrees, pointing towards the sink.
                  Have ergonomy in mind when designing a kitchen, because it is a working enviroment.
                  All stuff and working area's to prepeare food should be in short reach off each other, as also
                  all the controles of applainces that are used.
                  Avoid having to walk with heavy (and hot) pots and pans .
                  Avoid having to cross the kitchen with wet stuff (this causes slippery and messy floors)
                  Let someone with alot of cooking experience (for example your mother?)take a look at your design.
                  Greetings,
                  Bep van Malde
                  "History is written by the winners"
                  • BepB
                    Bep
                    Looking at sepo's and frederiks comments, I have to agree with them.
                    So I took lucifer1101's file and drew a few lines, creating a hall/entrance.
                    Than I switched the bathroom and storage.
                    The benefits for this:
                    • the storage is closer to the kitchen, easier to get stuff if your cooking
                    • No damp air coming from the bathroom into the diningroom/kitchen
                    Greetings,
                    Bert van Malde
                    Edited kitchen
                    • E
                      ENG. YASEEN
                      Sorry of all to be late...
                      I forget to tell u that u can't change any thing in a Ktchen Wall Design or on the Jop of aplaces , because it is built and Interior Design after that...
                      Also.. u must pot a Table for 6 people and be interest of fire place
                      My Website:
                      • E
                        ENG. YASEEN
                        This black design is not by me I had just an Inerior design without any changing in a black.. πŸ˜•
                        -Thanks"lucifer1101" for modeled a kitchen..
                        -"sepo" u can't swap it.. because it's built..
                        -"Frederik" Im with u of "never place a bathroom/toilet in direct connection with the kitchen" but here a bath just of Housewife..
                        -Thanks "Bep" for ur suggestion, I will take it
                        • "Bep" ur second suggestion is very good at a black design if we want chang it.. thanks too much Bep.
                        -"modelhead" thanks for ur comment..
                        thanks of all
                        My Website:
