    Candle render Challenge (all render engines)
    48 Posts 19 Posters 8.5k Views 19 Watching
      jmmad
      Ive seen realy fotorealistics renders of candles in this post
      Solo your candle animation whas Impresive
      did you model the flame in vue with a volumetric material?
      Majid your candle looks very realistic too
      Get Upa !
      • AdamBA Offline
        AdamB
        [Displacement activities.. you gotta love em]
        Here's a candle model I found on 3dwarehouse just now. Just added the flame and made the base shiny metal.
        The flame is animated in realtime but I can't upload the .mov file so I've put a 320x240 on Vimeo
        [flash=400,300:vcjxbftd]http://vimeo.com/moogaloop.swf?clip_id=4710188[/flash:vcjxbftd]
        Adam
          Is that animation LightUp, Adam? ๐Ÿ˜ฒ
          (I gotta try it once - I even have the "project" for it...)
          • AdamBA Offline
            AdamB
            Sure is.
            The all new, all dancing v1.5 is hopefully out tomorrow too. ๐Ÿ˜
            (Which is the version that has all this color/texture animation support)
            Adam
              sepo
              Is there also objects animation included. I seem too recall seeing that as well. Sure it looks very promissing.
                Don't rush, Adam, don't rush. Make it perfect instead ๐Ÿ˜‰
                (Unfortunately I have no time to try it ATM and it would only be a teaser ๐Ÿ˜’ )
                • E Offline
                  Eulgrand
                  Majid,
                  Your wax material is really great, would you share your settings ? KT's Sss is not the most documented topic...
                  ๐Ÿ˜‰
                  • FrederikF Offline
                    Frederik
                    It's not that difficult, Eulgrand... ๐Ÿ˜‰
                    I suggest that you go ahead and download the Transluscent.mat.zip from the KT Forum...
                    Take the "Milk" or the "Plastic transluscent" and play around with the colors and material settings... ๐Ÿ˜‰
                    Cheers
                    Kim Frederik
                    • E Offline
                      Eulgrand
                      Frederik,
                      You can bet I already did that, but something in my brain still has not get connected, and I can hardly figure out how Absorption, Emittance, Scatter and Falloff interact with each other (what do they control, is there a unit of measure for each of these parameters ?). All I could do until now was like throwing dice ๐Ÿ˜†
                      Thanks for your kind attention.
                      ๐Ÿ˜‰
                      • FrederikF Offline
                        Frederik
                        Have you taken a look at page 35 in the Kerkythea Material Editor Guide for KT2007...??
                        Although it was originally made for KT2007, basics remain identical for KT2008 and the explanation Patrick have made is much more accurate than what I can do... ๐Ÿ˜‰
                        Cheers
                        Kim Frederik
                          sepo
                          LightUp 1.5 has been released today.There are a lot of improvements. Very good upgrade and it is free, I mean for an existing owners of the LightUp.
                          • E Offline
                            Eulgrand
                            Thanks for the reminder Frederik ๐Ÿ˜‰
                            • EscapeArtistE Offline
                              EscapeArtist
                              Here's my attempt. May add a different one later, I'm not entirely happy with how dark it is. Sketchup and Kerkythea with flames added in GIMP.
                              Candles.  Sketchup + Kerkytea
                              • 3 / 3
