    Candle render Challenge (all render engines)
    48 Posts 19 Posters 8.9k Views 19 Watching
      steelers05
      solo: very impressive flame. liking it
        jmmad
        Ive seen realy fotorealistics renders of candles in this post
        Solo your candle animation whas Impresive
        did you model the flame in vue with a volumetric material?
        Majid your candle looks very realistic too
        Get Upa !
        • AdamBA Offline
          AdamB
          [Displacement activities.. you gotta love em]
          Here's a candle model I found on 3dwarehouse just now. Just added the flame and made the base shiny metal.
          The flame is animated in realtime but I can't upload the .mov file so I've put a 320x240 on Vimeo
          [flash=400,300:vcjxbftd]http://vimeo.com/moogaloop.swf?clip_id=4710188[/flash:vcjxbftd]
          Adam
            Is that animation LightUp, Adam? ๐Ÿ˜ฒ
            (I gotta try it once - I even have the "project" for it...)
            • AdamBA Offline
              AdamB
              Sure is.
              The all new, all dancing v1.5 is hopefully out tomorrow too. ๐Ÿ˜
              (Which is the version that has all this color/texture animation support)
              Adam
                sepo
                Is there also objects animation included. I seem too recall seeing that as well. Sure it looks very promissing.
                  Don't rush, Adam, don't rush. Make it perfect instead ๐Ÿ˜‰
                  (Unfortunately I have no time to try it ATM and it would only be a teaser ๐Ÿ˜’ )
                  • E Offline
                    Eulgrand
                    Majid,
                    Your wax material is really great, would you share your settings ? KT's Sss is not the most documented topic...
                    ๐Ÿ˜‰
                    • FrederikF Offline
                      Frederik
                      It's not that difficult, Eulgrand... ๐Ÿ˜‰
                      I suggest that you go ahead and download the Transluscent.mat.zip from the KT Forum...
                      Take the "Milk" or the "Plastic transluscent" and play around with the colors and material settings... ๐Ÿ˜‰
                      Cheers
                      Kim Frederik
                      • E Offline
                        Eulgrand
                        Frederik,
                        You can bet I already did that, but something in my brain still has not get connected, and I can hardly figure out how Absorption, Emittance, Scatter and Falloff interact with each other (what do they control, is there a unit of measure for each of these parameters ?). All I could do until now was like throwing dice ๐Ÿ˜†
                        Thanks for your kind attention.
                        ๐Ÿ˜‰
                        • FrederikF Offline
                          Frederik
                          Have you taken a look at page 35 in the Kerkythea Material Editor Guide for KT2007...??
                          Although it was originally made for KT2007, basics remain identical for KT2008 and the explanation Patrick have made is much more accurate than what I can do... ๐Ÿ˜‰
                          Cheers
                          Kim Frederik
                            sepo
                            LightUp 1.5 has been released today.There are a lot of improvements. Very good upgrade and it is free, I mean for an existing owners of the LightUp.
                            • E Offline
                              Eulgrand
                              Thanks for the reminder Frederik ๐Ÿ˜‰
                              • EscapeArtistE Offline
                                EscapeArtist
                                Here's my attempt. May add a different one later, I'm not entirely happy with how dark it is. Sketchup and Kerkythea with flames added in GIMP.
                                Candles.  Sketchup + Kerkytea
                                • 3 / 3
