    Swap between 2 lines
    12 Posts 5 Posters 859 Views 5 Watching
      arcano
      Hi to all. I need a plugin that make swap between 2 lines. The two lines aren't on the same plane.
      Thank you and sorry for my english.
        Swap what between two lines?
          arcano
          Swap as to make triangle for create a plane.
            AcesHigh
            I was going to create a topic requesting this... and I enter the forum and see your request...
            But... are you thinking about the same thing as I am? I was thinking about SWEEP TWO RAILS (thats the exact name of the Rhino 3D Tool)
            This is Sweep 2 Rails... you use TWO CURVES as rail lines and ONE CURVE as cross section.
            http://www.3dmax-tutorials.com/graphics/il_nurbs_sweep2.jpg
            this is actually the 3D Max Sweep 2 Rails... but it may give an idea... check the link, it shows some of the options used, descriptions, etc
            http://www.3dmax-tutorials.com/_2_Rail_Sweep_Surface.html
            I once created a thread asking for Sweep2Rail... but the answer I got was "get another 3d program" 😒 😆 http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16447
            2 more images
            http://www.studiorola.com/wp-content/uploads/2008/10/6a.jpg
            http://www.studiorola.com/wp-content/uploads/2008/10/7.jpg
            Of course, that thread was posted BEFORE Chris entered into his amazing ruby coding frenzy! Now, with Chris´ genius, we might see Sweep2Rail come to be!!
              arcano
              Wow...! 😄
              I can't see the last 2 images.
                arcano
                My problem it's this:
                I'v the edge of my plan. Can I make a face with this edge automatically? Whitout make with line tool hundred of triangle...
                PS. The edge are not on the same plane !!!
                  remus
                  this will do it: http://www.smustard.com/script/Flatten although it'll cost you $10.
                  you can then trace over one of the edges to fill in the face.
                    arcano
                    No, I don't need to flatten my edge on a z=0 plan but I need to create faces with my non complanar edges.
                    • Chris FullmerC Offline
                      Have you tried running the sandbox "From Contours" tool on it? That might do the trick.
                      Once you do get faces filled in, you know that you won't be able to pushpull them though, that only works with a single face. If possible, you'd be better off to flatten it.
                        arcano
                        Sure Colombo's egg!
                        Thank you very much!
                          AcesHigh
                          well, thus, it seems it was not a SWEEP 2 RAILS request at all! 😆 😆
                            arcano
                            No, but SWEEP 2 RAILS plugin will be very usefull for me!
