    Using the Registry - Any Gotchas?
    5 Posts 4 Posters 473 Views 4 Watching
      Jim
      Is there anything to watch for when using the Sketchup.write_default and Sketchup.read_default methods?
      I know it is a pain if you are trying to store Windows paths in the registry, i.e.
      C;\Program Files\Google\Google Sketchup 7
      because the '' character is special in strings.
      Is it a smart strategy to just encode (am i thinking of escape?) everything before it goes in? (and how might I do that?)
      • Chris FullmerC Offline
        There might be something in this thread, starting with the post I've linked to. Todd tried to explain it to me, but I don't know what hex encoding is.
        404 Not Found
        (www.sketchucation.com)
        Maybe a start?
          Could do a test with a set of characters and see if it's stored properly. Maybe the method encodes it before saving...
          • AdamBA Offline
            AdamB
            Yes, but Ruby 'knows' about unix forward slashes so I tend to always do a:
            a_filepath_string.gsub(/(\)/, '/')
            to everything regardless of platform which then works for PC & Mac.
            Adam
              Jim
              Thanks Adam, I was actually using the following:
               str.gsub!(/\\/, '\\\\')
              But I think simply changing it to '/' is a better solution, and will modify inputbox.rb I suppose it's possible for someone to want to use \ for some other string, though.
              I'm also escaping double-quotes:
              str.gsub!(/"/, '\"')
              Thanks.
