    Airplane Study
    105 Posts 46 Posters 20.1k Views 46 Watching
    • soloS
      LOL, you are getting OCD.
      Lovin it!! πŸ‘
      • G
        gasher
        This model looks beautiful! Great work.
        • boofredlayB
          boofredlay
          Thanks.
          I don't think I will make any propellers. The author of the source image wrote the following:
          i didnt want to do a propeller the engine should look like a mix between an old spark-ignition engine (i googled that translation πŸ˜„) and a modern jet-turbine-like-thing.
          However I am adding missiles...? We'll see. I may just make some landing gear as well. Now on to the rivets 😲
            Astonished model β˜€
            • C
              cadmunkey
              Fantastic modelling skills Eric!
              • marked001M
                marked001
                wow wow wow...this is so freakin awesome , eric! a ton of detail here... the cartoon style is really great... love it.
                http://www.revision21vis.com
                instagram: revi21on
                • T
                  teofas
                  wow, can wait to see it with textures and then render! amazing stuff, coangrats!!!
                  http://www.spazioarquitectura.com
                  • boofredlayB
                    boofredlay
                    As you should.
                    Thanks again all for the comments.
                    • boofredlayB
                      boofredlay
                      I added the rivets tonight. They were easier than I anticipated. What I found really interesting was viewing the rivets while hiding the rest of the model. I have added some shots for you to see. Pretty cool actually. My wife said it looked like The Invisible Man's airplane πŸ˜„
                      • L
                        lucifer1101
                        thats coming along very nicely, ilove the shots with the plane hidden just with the rivits LOL!...
                        Some of my 3d
                        • david57D
                          david57
                          Nice, looks like some parts came from the Space Shuttle. πŸ˜„ πŸ˜„ β˜€
                          • W
                            watkins
                            Dear Eric,
                            Perhaps you could take some of the trickier modelled parts and create a few 'how-to-do' tutorials. Perhaps some of the engine components?
                            Kind regards,
                            Bob
                            • soloS
                              Eric, you freak!!
                              business slow? as the detail is getting insane...but amazing.
                              If I may Inquire, whats the poly count and file size at this point?
                              This is going to look friggin amazing, this needs a great render and even an Animation (offering to do an animation if you willing to loan the final model out for a test flight)
                              • boofredlayB
                                boofredlay
                                I just may do that. I am at work now so I don't have the model, it is at home. Will check the poly and file size later.
                                I only hope I can do the model justice with a nice rendering and not make it look cheesy. Still learning.
                                And yes business is slow but I have done all this at home on my time, not at the office. I reserve office play time for stupid visual puns πŸ˜†
                                  mike d
                                  Eric
                                  that is looking amazing
                                  mike d
                                  The grass is always GREENER on the roof.
                                  • marked001M
                                    marked001
                                    damn....this is looking pretty crazy..any tricks for adding the rivets? or just hard work with copy and copy/rotate?
                                    instagram: revi21on
                                    • boofredlayB
                                      boofredlay
                                      Copy and rotate. I did make a component for half the airplane so I only had to do one side since it is symmetrical. The fuselage and tail section took the most time. The wings and engine were easy. I also made the rivets a bit long so I did not have to make sure the face matched perfectly in each spot.
                                      • boofredlayB
                                        boofredlay
                                        Ok Pete, the count so far is 229,799 faces at 6.13mb.
                                          silver_shadow
                                          you got my attention dude. Really nice model , love models with a lot of detail
                                          One always start off, very excited and during the time you get bored building it because it take soo long to model, till then you add detail and cant stop doing it because it makes the model come alive.
                                          You should make the cockpit window flip open, and a side panel next to it, to get easier into the plane. Also then you can see some inside panel detail, underneath the glass fixtures details and inside the cockpit itself which will look awesome. dont worry about poly count..su will handle it. I have a model over 3 mil poly count and su still holds.
                                          • T
                                            teofas
                                            this is really awsome like i told you before, its an insane model, i like it a lot, keep rocking bro!!
                                            • 2 / 6
