    Candle render Challenge (all render engines)
    48 Posts 19 Posters 8.1k Views 19 Watching
    • soloS Offline
      As suggested by Earthmover.
      Model your own candle and light it up using any technique neccesary, lets see what y'all can come up with.
      I guess realism is key, so minute details like flame, shadow, wax, sub surface scattering, molten wax, etc are important.
      Have fun.
      • soloS Offline
        Here is an old render I did using Podium version 1.0 (better results can be optained with version 1.6)
        http://img459.imageshack.us/img459/7761/2007080205561011m38sedilb5.jpg
          jhagan421
          Another oldie. I believe Podium 1.4
          • holmes1977H Offline
            holmes1977
            OH how far podium has come since then.
            Solo I love how you added diffenition to that paving texture before Podium introduced bumpmap. Brilliant
            Still.... for how long ago you did that the flame looks pretty good.
            Exaggeration makes a dull story better.
            • boofredlayB Offline
              boofredlay
              Here are a couple I did in a Modo tutorial a while back. I have not been able to finish the tutorial yet so no background 😳
              • soloS Offline
                http://img14.imageshack.us/img14/5823/candletest.jpg
                • EarthMoverE Offline
                  EarthMover
                  I did that tutorial too! It was Dan Ablan from 3DGarage.com, right? Signature Courseware for Modo 301. A must see for anyone trying to get into Modo. I have to go through that again one day. Lord knows if you don't use it, you definitely lose it!
                  Content Creator at Skapeup
                    EarthMover
                    Here's my first try. Modeled the wax using TOS, JPP and SDS. Drips could definitely be a lot better. I rendered using Vray for MAX. Wax is a Vray FastSSS material. The flame I modeled and used a Vray Light Material with a Gradient Ramp in the Opacity slot and flame texture for diffuse. In photoshop I overlayed the flame texture with minimum opacity, then used and outer glow from the effects menu, with a gaussian blur added on top of that.
                      boofredlay
                      Yep, yep... and yep. πŸ˜„
                      • brodieB Offline
                        brodie
                        Here's my crack at it in Maxwell. Didn't want to get into figuring out the flame so I made a simple candle model and then plopped a scaled down incandecent in the middle. Candle wax was just made through Maxwell's Wizard (SSS -> Candle Wax). Easy peasy.
                        -Brodie
                        • EscapeArtistE Offline
                          EscapeArtist
                          Maybe this is obvious, but does it need to be modeled in SU?
                          • brodieB Offline
                            brodie
                            I'd say no, as long as it's a rendering engine that accepts SU files. I think the main thing is to see how the various rendering engines do. But rendering a candle with Revit or some such thing would probably be less than helpful.
                            -Brodie
                            • N Offline
                              nomeradona
                              i have done this before but not yet satisfied.. i think i will do again a candle light render.
                              http://img519.imageshack.us/img519/88/kungfupandango3qd8.jpg
                                andre51
                                This one was also rendered in Maxwell. The flame is from the online materials library.
                                • brodieB Offline
                                  brodie
                                  Andre, very nice. I tried out that same flame material w/ about equal results. It seems like the sample image that was there with the mxm looked better somehow. I couldn't quite figure out what the difference was...
                                  love that wallpaper!
                                  -Brodie
                                  • soloS Offline
                                    Another Vue render, with line image of SU model.
                                    http://img11.imageshack.us/img11/9619/vuecandle.jpg
                                      boofredlay
                                      Wow, that is great.
                                        troyhome
                                        [attachment=0:2ful2lja]<!-- ia0 -->candle1.jpg<!-- ia0 -->[/attachment:2ful2lja]
                                        how do you do the flame? do you make a surface and apply the material to it and it just comes out like that, or do you model an actual flame and apply the material to that?
                                        IOviz.com
                                        SU Pro 2024 PC
                                        • brodieB Offline
                                          brodie
                                          You can just apply the texture to a rectangle. The material does the rest. It's basically a clip mapped emitter if I recall.
                                          -Brodie
                                            andre51
                                            Hi Troyhome
                                            Unfortunately this material works only 2d, ie I had to have 2 faces to cast the light in 2 directions.
                                            Would like to try and map to a flame model some time.
                                            cheers
                                            Andre
                                            • 1 / 3
