    Hinge (bearing) and Spring
    12 Posts 4 Posters 1.5k Views 4 Watching
      Thrundar
      I'm trying to attach working joints as shown and have the spring hooked up to the top arm and bottom arm. Only can get one joint at a time to work.
      Testing multiple joints
        phy
        You have the spring grouped two times. You can't group a joint more than once.
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          Thrundar
          Ok, then I am totally lost again. For a joint to work it needs to be grouped with the part/s it you want it to have an effect on, right?
            Physicsguy1
            You can, but i wouldn't use it. Here are some tips: A)you cannot make a group composed of only joints; it must have a non-joint entity. B)Joints cannot be grouped more than once. C)In order for a joint to be movable, you must group it with another object. You cannot change the properties of joints that affect the state, like ignore and static. I will post a fixed version of your model if i can. Hope this helps!
              Physicsguy1
              here is the file that i fixed. I wrote down what i did to fix it.
              PMM-3a.skp
                phy
                Thanks physicsguy I didn't now what to say.
                  Thrundar
                  I finally got back to this and downloaded. It must be that springs do not operate with an arc movement, only straight line of travel. Basically a bouncy linear slider?
                  Thanks for taking the time to look more into this physicsguy
                    phy
                    Yes that's true
                      CPhillips
                      If you want a rotating spring use a servo and set the accel high and damp low depending on how strong and how stiff you want the spring to be.
                        Thrundar
                        by CPhillips on Fri May 01, 2009 9:28 pm
                        I'm also having difficulties with changing the joint settings. I'd love to be able to adjust the spring. However I need a step by step walk through on how to do that. There is much with SU I don't know and have exhausted the newby tutorials I can find that are written and explained well.
                        Can you connect a joint to a joint without an object or part as the parent? I'm using SU7 with SUPRC31. I noticed in RC31 that I could switch to version 2...not sure if that would help or hurt things.
                        Thanks to everyone who is lending ideas here! 😄
