    Acceleration script (working)
    7 Posts 5 Posters 1.5k Views 5 Watching
    • W Offline
      Wacov
      I decided to make this when I realised my new vehicle didn't feel heavy enough; I wanted it to be fast, but I didn't want instant acceleration and decceleration. This script deals with both problems, and you can adjust the acceleration and braking to your needs by changing the local variables at the top... well, here it is:
      #Acceleration Script by Wacov
      accel=0.005
      deccel=0.015
      if frame==0; then;
      setVar("speed",0.5);
      end;
      if getVar("speed")>joyRY and getVar("speed")>0.5;
      setVar("speed",getVar("speed")-deccel);
      elsif getVar("speed")<joyRY and getVar("speed")<0.5;
      setVar("speed",getVar("speed")+deccel);
      end;
      if joyRY>0.5; then;
      setVar("speed",getVar("speed")+accel);
      end;
      if joyRY<0.5; then;
      setVar("speed",getVar("speed")-accel);
      end;
      if joyRY==0.5 and getVar("speed")<0.5;
      elsif joyRY==0.5 and getVar("speed")>0.5;
      end;
      It will not accelerate beyond the input, so the overall speed is controllable. To change the control, change all the 'joyRY's to whatever you want.
      To use, place in any onTick field. For a vehicle's motors, use:
      0.5-getVar("speed")
      In the motor's controler field. Hope this is useful!
      Have at look at: http://sketchup.google.com/3dwarehouse/details?mid=9047719249a2da26cd8ad826e9017b8&prevstart=0 To see it at work.
        phy
        Good, only thing is that when you hit something it doesn't slow you down. But it's very good.
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          MrPlanet
          So, you can control how fast it goes? 😄
          I reject your reality and substitute my own.
          • W Offline
            Wacov
            😄 Nah, how fast it accelerates. Normal cars don't go from 0-120 in half a second; the script fixes that
              Mitchieboy
              I don't fully get it....
                shareck
                Very good! But please tell me how did you achieve such a good grip??
                • W Offline
                  Wacov
                  My method is quite complicated, but it revolves around a thruster pinning the car to the ground. Try putting -5000 in the thruster setting for the car's body (you might get some odd results, though)
