    Needed: advice on night scenes of complex models
    28 Posts 8 Posters 3.0k Views 8 Watching
    • brodieB
      brodie
      I'd be interested in seeing how Ecuadorian's idea would work out. I've had the same idea before but haven't given it a shot. Here's how it goes in my head.
      Render interior with the building's 'skin' layer turned off. Use daylighting. the glass should probably be turned on though, not sure.
      Render your night shot with no interior lights
      Save an unrendered image from the same SU perspective in "color by layer" mode (all window glass must be on a separate layer)
      in Photoshop set up those 3 images on seperate layers with 'color by layer' on top and the skinless layer on bottom.
      use 'color by layer' to make a good selection of the window glass and use that selection to either delete or mask out the windows from the night shot layer (effectively revealing the interior shown on the layer below)
      Finally adjusting the brightness and hue of the interior until it looks right. A photo filter might be appropriate here so it looks like it's being lit by incandecents instead of sunlight (or instead of daylight you could have rendered it with 1 large incandecent type light)
      I'd probably also go back and unmask some of the windows so it doesn't look like ALL the lights are on.
      Like I said, it works in my head but I've never had the opportunity to test it out. If anyone has done something like this I'd love to see the results.
      -Brodie
      • EdsonE
        Edson
        hi brodie,
        thanks for the tips. as soon as i have the time i will put them to test.
        EDIT: my only doubt about your suggestions is that you never mention a step that includes artificial lighting. note that the main purpose of the scene is to show a brighly lit building seen from the outside.
        http://www.mahfuz.arq.br
        • brodieB
          brodie
          Great, can't wait to see the results! Note that one of the things I'm not sure about is how to handle the glass. If it's turned on in the "skinless" render and then adjusted in post-processing will it look right? I'm not sure.
          -Brodie
            mirjman
            how are you avoiding dark corners in the back of the interiors with this? see attached test model
            • soloS
              http://img529.imageshack.us/img529/1304/200904071607101m53s.jpg
              Default settings, no fancy tricks.
              Attached is the model with the SU settings.
              test int shadow.skp
                mirjman
                here's a quick hack at the method posted by brodie
                one flaw is that there is not realistic lighting in the depth of the window the way I showed it, perhaps if you keep the window lip in the daylight layer this would be more convincing
                • brodieB
                  brodie
                  hrm...interesting catch. Maybe you could do the window lip on both the daylight and night renders and use a low opacity eraser to erase the night rendered lip, thus uncovering the daylight lip until it looks right (otherwise you might end up with the opposite problem, the lip being too bright).
                  It does seem to be getting more complicated though doesn't it. My guess is that the trade off for manageable render times will be some realism. However, with podium or another biased renderer that might not matter quite so much.
                  -Brodie
                  • brodieB
                    brodie
                    Welp, I couldn't resist taking a crack at it. Here's my version
                    https://dl.getdropbox.com/u/384281/Night Lighting/Light test.jpg
                    Here are the associated files
                    https://dl.getdropbox.com/u/384281/Night Lighting/20090407213518_2m24s.jpg
                    https://dl.getdropbox.com/u/384281/Night Lighting/20090407214415_2m0s.jpg
                    The photoshop file
                    https://dl.getdropbox.com/u/384281/Night%20Lighting/Light%20test.psd
                    And the SU file
                    https://dl.getdropbox.com/u/384281/Night%20Lighting/test%20int%20shadow.skp
                    • brodieB
                      brodie
                      I haven't used Podium very much so there may be a better way to do some of the stuff (couldn't figure out how to get a dark scene, for example, without enclosing the whole model in a box). I used the Color by Layer image to save a selection of the glass and another of the window lip, then used those selections to make the appropriate masks (as you'll see in the photoshop file). Then I went back with either a black or white brush at varying opacities to reveal more or less of the lit areas on the bottom layer to give the effect that all the windows were lit to different intensities.
                      Also note that when you make the Color by Layer image (which you get to via the little arrow in the upper right corner of the Layers pallete) that you should also turn the edges off to get a better selection.
                      I also changed the color of the light emitter to a sort of brownish orange which if I recall affects the hue of light emitted so that it would look more incandescent.
                      Think that's about it. Glad I was able to finally give this a try. Now I'm interested to see how well this would work in something like Maxwell or another unbiased renderer...
                      -Brodie
                        mirjman
                        i still think there is something strange going on in the podium daylight renders (both yours and mine) - shouldn't all of the room boxes be equally lit? some of the ones in the center of yours are obviously darker which doesn't make much sense unless the light source is very close to the model.
                        edit: i notice the same thing happening in solo's post as well - check out the bottom box
                        • brodieB
                          brodie
                          Good call, that's exactly what the problem is with mine. I created a huge emitter plane and placed it in front of the "building". It's not that far behind the camera. So I was getting daylight bleeding around the edges of my emitter which made the boxes around the perimeter brighter. I noticed the same thing but couldn't figure it out until you brought it up. I should have turned by big box enclosure on for the "day" rendering too so I wasn't getting any sunlight, only the light from my emitter. That should have evened it out.
                          You can open up the SU model to see what I'm talking about.
                          -Brodie
                            mirjman
                            ah - thanks for posting the model. I gave it a shot with the big box trick and the lighting was much more even - good fix!
                            • EdsonE
                              Edson
                              this is becoming a very interesting thread. thanks to all for the contributions so far.
                              • brodieB
                                brodie
                                So is there a way to turn off the sun altogether in podium? I guess I was assuming there must be but I'm surprised no one has chimed in on that.
                                -Brodie
                                • EdsonE
                                  Edson
                                  -Brodie
                                  you do not do that in podium. the beauty of it is that you do almost everything in SUp. for a night scene in podium you turn off the sun in SUp and give the background a dark color.
                                  • brodieB
                                    brodie
                                    ahh, maybe the background was my fatal flaw. By turning off the sun you're saying just turn off SU shadows? I did that but it was still pretty well lit, I didn't change the background though so maybe that's the trick.
                                    -Brodie
                                    • tinanneT
                                      tinanne
                                      This is a great thread! More, more...
                                      Executive Director : American Society of Architectural Illustrators
                                      AIP 30 Competition opens soon. ASAI.org
                                      Architectural Rendering
                                      • 2 / 2
