    Needed: advice on night scenes of complex models
    28 Posts 8 Posters 2.6k Views 8 Watching
    • E Offline
      Ecuadorian
      You could a render of the interior illuminated by just the sun if you remove the outer skin, and use it as a layer below the night render of the outer skin. You could the adjust the levels of the lower layer to suit your needs.
      -Miguel Lescano
        remus
        Another render engine might be more appropriate, perhaps kerkythea or indigo? not sure which rendering method would be best for kerkythea, though.
          Roger
          Create a picture wall (vertical surface) inside the building and paste a photo on that false wall. Then light that wall as appropriate. In other words move the image in via pre production rather than post production. I run into this way too often. Clients want a rendering of a building they don't have tenants for which means they have no interior design. So they want to pay for a rendering, but then actually get some design because what goes on behind the windows has to be thought out. So I just cheat a bit and throw in photo fragments. When this happens even the family dog is pressed into service as are bits and pieces of friends homes and offices. I have even gone on photo runs in furniture stores to collect office entourage. Just a quirky little work around that worked for me.
          http://www.azcreative.com
          • EdsonE Offline
            Edson
            roger,
            even though my problem is slightly different (ie, how to light the interiors for a good night shot) your advice is welcome as i run into the "empty room" problem very often. thanks.
            http://www.mahfuz.arq.br
            • EdsonE Offline
              Edson
              remus,
              thanks, but i do not think it is a good solution for me to start using another application. the reason i use podium is its ease of use as my focus of interest is the project not the render. what i want to do is learn how to produce good night shots (for my own purpose, that is) with my rendering engine of choice.
                remus
                Very sensible, i find it hard enough trying to get indigo to do what i want, let alone having to worry about how other render engines work as well.
                • brodieB Offline
                  brodie
                  I'd be interested in seeing how Ecuadorian's idea would work out. I've had the same idea before but haven't given it a shot. Here's how it goes in my head.
                  Render interior with the building's 'skin' layer turned off. Use daylighting. the glass should probably be turned on though, not sure.
                  Render your night shot with no interior lights
                  Save an unrendered image from the same SU perspective in "color by layer" mode (all window glass must be on a separate layer)
                  in Photoshop set up those 3 images on seperate layers with 'color by layer' on top and the skinless layer on bottom.
                  use 'color by layer' to make a good selection of the window glass and use that selection to either delete or mask out the windows from the night shot layer (effectively revealing the interior shown on the layer below)
                  Finally adjusting the brightness and hue of the interior until it looks right. A photo filter might be appropriate here so it looks like it's being lit by incandecents instead of sunlight (or instead of daylight you could have rendered it with 1 large incandecent type light)
                  I'd probably also go back and unmask some of the windows so it doesn't look like ALL the lights are on.
                  Like I said, it works in my head but I've never had the opportunity to test it out. If anyone has done something like this I'd love to see the results.
                  -Brodie
                  • EdsonE Offline
                    Edson
                    hi brodie,
                    thanks for the tips. as soon as i have the time i will put them to test.
                    EDIT: my only doubt about your suggestions is that you never mention a step that includes artificial lighting. note that the main purpose of the scene is to show a brighly lit building seen from the outside.
                    • brodieB Offline
                      brodie
                      Great, can't wait to see the results! Note that one of the things I'm not sure about is how to handle the glass. If it's turned on in the "skinless" render and then adjusted in post-processing will it look right? I'm not sure.
                      -Brodie
                        mirjman
                        how are you avoiding dark corners in the back of the interiors with this? see attached test model
                        • soloS Offline
                          http://img529.imageshack.us/img529/1304/200904071607101m53s.jpg
                          Default settings, no fancy tricks.
                          Attached is the model with the SU settings.
                          test int shadow.skp
                            mirjman
                            here's a quick hack at the method posted by brodie
                            one flaw is that there is not realistic lighting in the depth of the window the way I showed it, perhaps if you keep the window lip in the daylight layer this would be more convincing
                            • brodieB Offline
                              brodie
                              hrm...interesting catch. Maybe you could do the window lip on both the daylight and night renders and use a low opacity eraser to erase the night rendered lip, thus uncovering the daylight lip until it looks right (otherwise you might end up with the opposite problem, the lip being too bright).
                              It does seem to be getting more complicated though doesn't it. My guess is that the trade off for manageable render times will be some realism. However, with podium or another biased renderer that might not matter quite so much.
                              -Brodie
                              • brodieB Offline
                                brodie
                                Welp, I couldn't resist taking a crack at it. Here's my version
                                https://dl.getdropbox.com/u/384281/Night Lighting/Light test.jpg
                                Here are the associated files
                                https://dl.getdropbox.com/u/384281/Night Lighting/20090407213518_2m24s.jpg
                                https://dl.getdropbox.com/u/384281/Night Lighting/20090407214415_2m0s.jpg
                                The photoshop file
                                https://dl.getdropbox.com/u/384281/Night%20Lighting/Light%20test.psd
                                And the SU file
                                https://dl.getdropbox.com/u/384281/Night%20Lighting/test%20int%20shadow.skp
                                • brodieB Offline
                                  brodie
                                  I haven't used Podium very much so there may be a better way to do some of the stuff (couldn't figure out how to get a dark scene, for example, without enclosing the whole model in a box). I used the Color by Layer image to save a selection of the glass and another of the window lip, then used those selections to make the appropriate masks (as you'll see in the photoshop file). Then I went back with either a black or white brush at varying opacities to reveal more or less of the lit areas on the bottom layer to give the effect that all the windows were lit to different intensities.
                                  Also note that when you make the Color by Layer image (which you get to via the little arrow in the upper right corner of the Layers pallete) that you should also turn the edges off to get a better selection.
                                  I also changed the color of the light emitter to a sort of brownish orange which if I recall affects the hue of light emitted so that it would look more incandescent.
                                  Think that's about it. Glad I was able to finally give this a try. Now I'm interested to see how well this would work in something like Maxwell or another unbiased renderer...
                                  -Brodie
                                    mirjman
                                    i still think there is something strange going on in the podium daylight renders (both yours and mine) - shouldn't all of the room boxes be equally lit? some of the ones in the center of yours are obviously darker which doesn't make much sense unless the light source is very close to the model.
                                    edit: i notice the same thing happening in solo's post as well - check out the bottom box
                                    • brodieB Offline
                                      brodie
                                      Good call, that's exactly what the problem is with mine. I created a huge emitter plane and placed it in front of the "building". It's not that far behind the camera. So I was getting daylight bleeding around the edges of my emitter which made the boxes around the perimeter brighter. I noticed the same thing but couldn't figure it out until you brought it up. I should have turned by big box enclosure on for the "day" rendering too so I wasn't getting any sunlight, only the light from my emitter. That should have evened it out.
                                      You can open up the SU model to see what I'm talking about.
                                      -Brodie
                                        mirjman
                                        ah - thanks for posting the model. I gave it a shot with the big box trick and the lighting was much more even - good fix!
                                        • EdsonE Offline
                                          Edson
                                          this is becoming a very interesting thread. thanks to all for the contributions so far.
                                          • brodieB Offline
                                            brodie
                                            So is there a way to turn off the sun altogether in podium? I guess I was assuming there must be but I'm surprised no one has chimed in on that.
                                            -Brodie
