    SketchyPhysics3 Release Candidate 1
    64 Posts 18 Posters 36.7k Views 18 Watching
      shareck
      can someone tell me how do i use image export option thats been added to sketchy replay?
        CPhillips
        No weight because objects dont have materials yet. Thats planned for SPIV.
        Image export is in the Plugins->SketchyReplay->Export animation dialog.
        Note Replay still doesnt support emitted objects.
          Alienizer
          I'm confused CPhillips. What do materials have to do with the weight of an object? If we make a box and assign 12lb to it, then it doesn't matter if it's solid or hollow, or what material it is, isn't it??
          I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
            CPhillips
            I wish I could just say I weigh 180 and have it be so. πŸ˜„
            In short the physics engine doesn't support absolute weighting of stuff.
            In physics as in real life the weight (mass) of something is determined by how much stuff in it and how dense it is. Steel is denser then wood so it weighs more. Thats why the physics engine uses materials.
            • W Offline
              Wacov
              I think mass is determined by density and volume, but weight is determined by mass and gravity. Objects in a weightless environment still have mass... but maybe you could insert a tool that tells you an object's weight, in the thruster power it would take to make it neutrally 'bouyant' in the air?
              Oh and can you make the camera reset remember the field of view setting?
                CPhillips
                Maybe. But I dont know how to change the fov.
                • W Offline
                  Wacov
                  Camera/Field of view
                  Drag like the zoom tool or type a number... but I'm not sure if that's what you mean...
                    CPhillips
                    I guess so. But when I do that the simulation resets. How does it get changed in the course of a simulation. I need to know so I know when to save it.
                    • W Offline
                      Wacov
                      It isn't! That's the problem! It resets to the default 30 degrees, when the simulation started at 70. This happens in MotorSketch Mesa, at least to me.
                        CPhillips
                        Ah. I see. Yeah Ill fix.
                          Physicsguy1
                          Is it possible to alter variables within the simulation? I mean being able to control it with keyboard or joystick. I don't want a consistent position. Is that possible? If so, can you give me a script example?
                            CPhillips
                            Be a little more specific..
                              Physicsguy1
                              I mean like the setvar and getvar scripts. Can it be alterable during the simulation?
                                CPhillips
                                Still not following. What is get/setVar not doing?
                                  Physicsguy1
                                  I might not be right. When you wrote that it will retrieve the variable, i thought you could change the variable, like on a control panel slider. it is like two joints controlled with the same name.
                                    Alienizer
                                    I understand what you are saying CPhillips, but without density, mass, weight or whatever we call it, some simulations can not be done properly. If you collide a ball of steel with a ball of wood, both of the same size (not mass), the simulation is very incorrect, they both propel in equal force, and that's way wrong. It doesn't matter for gravity as object of different weight will fall at the same speed, but when they collide, it's a new ball game. Material should not be used for this purpose, an object should have a "Mass,Density or whatever" attribute that we can set, regardless of what material we use. Material is for the look.
                                    Take a look at your demo of the car you just did. When the whole car hit the wheel of another, it breaks off, at the same rate as if a wheel hit that wheel. Not very realistic don't you think? Not just for your car demo, but for other simulations. Say, a pool table where the 9 ball is made of gold, then what? it act just as the rest of the balls, that's just not right! We should be able to drop a rock on a piece of wood and have it react realistically. I piece of wood can't just hit a rock and make it fly off the ground!
                                    • W Offline
                                      Wacov
                                      The physics material would be entirely separate from the SketchUp material; so you'd be able to set a box to behave like wood, but it could be painted as steel. These materials would be like templates, with settings you can modify, like density and friction. Maybe a material manager could be implemented? The UI's kinda crowded.
                                        Alienizer
                                        If it's going to work that way, then it'll be perfect, as long as we can make our own material of course. Do you know for sure that's how it'll be, or you're just guessing?
                                        • W Offline
                                          Wacov
                                          That's how it SHOULD be IF it's implemented. That's (I think) how it works in the newton physics playground, so the same kind of thing could be done with SP.
                                            Alienizer
                                            Makes perfect sense to me.
                                            • 1 / 4
