    Textures, games and camera rigs
    10 Posts 3 Posters 1.1k Views 3 Watching
    • W Offline
      Wacov
      Latest version of MotorSketch uses textures and grass sprites. Result is a good looking but still playable game; and thanks to the no collision state I've been able to keep the boost flame effect. I'm very happy with the camera rig, which can be rotated around the car and is springy, absorbing impacts and playing much more like a conventional game. Still alot of work to be done, especially on optimizing the file size... this is maybe half way through, but it's already topping off 9MB (This is reduced from an insane 15MB!). Textures need to be tiled properly and compressed, then used at a smaller scale on surfaces, but here is how it looks so far:
      Top down view
      Starting Mesa
      Grass and barrels
      • H Offline
        hobbnob
        what's motorsketch? is it a plugin for sketchup?
        My WIP Thread:Here
          Physicsguy1
          I think it is his new game.
          • W Offline
            Wacov
            You should know Hobbnob, you're the only person that's rated the first version 😄
            • H Offline
              hobbnob
              oh that, that waas good fun, i still don't know how you got the boost to work, it only went when you pressed the accelerator and the boost, which i think can only be done with an if function, buti have no idea how it works...
              My WIP Thread:Here
              • W Offline
                Wacov
                It's an if function, so if the accelerator is pressed a certain amount, then the force is a*2000, otherwise just 0.
                  Physicsguy1
                  Can you post an example of the code?
                  • W Offline
                    Wacov
                    Sure...
                    Thruster:
                    if(joyRY<0.3);a*2000;else;0;end
                    Emitter (flame effect):
                    if(joyRY<0.3);a*1;else;0;end
                    Rate and lifetime are both set to 1.
                    Motors:
                    if(joyRY>0.5);-0.2;elsif(joyRY<0.3);0.5-joyRY+a;else;0.5-joyRY;end
                    This is for slow reverse. The boost here is really just a relic from an old test.
                      Physicsguy1
                      this won't work. can't get a forward boost.
                      flying cannon.skp
                      • W Offline
                        Wacov
                        I'm not totally sure what you're trying to achieve there; the code is pretty specific to my particular vehicle. Also note that I had to take into account that joyRY is the wrong way round for driving use; the left trigger increases the value, while the right trigger decreases it.
